    MMM-MQTTbridge
    Scheduled Pinned Locked Moved Unsolved System
    44 Posts 14 Posters 26.6k Views 15 Watching
    • K
      KSumwalt
      I installed the module on Aug 18, 2020 and have it connecting to my broker. Either I have something off or the module always sends out the notification’s payload and I cannot over-ride such. My notiDictionary.js file looks like this:
      var notiHook = [
          notiId: "USERS_LOGIN",
          notiPayload: [
              payloadValue: '',
              notiMqttCmd: ["Command 1"]
          notiId: "SHOW_ALERT",
          notiPayload: [
              payloadValue: '',
              notiMqttCmd: ["Command 2"]
          notiId: "NEWS_FEED",
          notiPayload: [
              payloadValue: '',
              notiMqttCmd: ["Command 3"]
      var notiMqttCommands = [
          commandId: "Command 1",
          mqttTopic: "mirror/profile",
          mqttMsgPayload: 'george'
       //    mqttMsgPayload: '{state:"OFF"}'
          commandId: "Command 2",
          mqttTopic: "mirror/alert/set",
          mqttMsgPayload: 'on'
          commandId: "Command 3",
          mqttTopic: "mirror/alert/test",
          mqttMsgPayload: 'go'
      module.exports = { notiHook, notiMqttCommands };
      When an alert is shown, the SHOW_ALERT send an MQTT Topic of mirror/alert/set but the payload according to MQTT Snooper and my HomeSeer system is [object Object]. I expected it to be a string of on. NEWS_FEED does noth8ing, as expected from the config. USERS_LOGIN is from the MMM-Face-Reco-DNN module. It has a string value of the person who’s face it recognizes. When it recognizes me, the payload for the MQTT topic is Karl both when I have no value and when I have George in the payload setting as shown above.
      This is how I have the module configured in the config.js file:
      			module: 'MMM-MQTTbridge',
      //			disabled: false,
      				mqttServer: "mqtt://192.168.1.2:1883",
      				mqttConfig:
      					listenMqtt: true,
      					interval: 300000,
      				notiConfig:
      					listenNoti: true,
      					ignoreNotiId: ["CLOCK_MINUTE", "NEWS_FEED"],
      					ignoreNotiSender: ["system", "NEWS_FEED"],
      				// set "NOTIFICATIONS -> MQTT" dictionary at /dict/notiDictionary.js
      				// set "MQTT -> NOTIFICATIONS" dictionary at /dict/mqttDictionary.js
      What might I be doing wrong?
      Note that for an IP address and no username/password I had to set the server to mqttServer: “mqtt://192.168.1.2:1883”, dropping the colon (:) prior to the IP address. I had it in there based on the provided settings for the localhost version.
      SergeS 3 Replies Last reply
      • SergeS
        Serge @KSumwalt
          Mrtrol2013
          Can I use this module to manage MMM-pages?
          • SergeS
            Serge @KSumwalt
            @KSumwalt
            the module is working. try to reinstall it and check the configuration once more.
            Here is the community member says that he uses module perfectly https://forum.magicmirror.builders/topic/13726/mmm-ledstripcontrol-control-a-led-strip-with-optional-pong-game-support
            @Mrtrol2013 said in MMM-MQTTbridge:
            Yes.
            See
            • that part of MMM-pages’s readme here https://github.com/edward-shen/MMM-pages#regarding-notifications and
            • that part of MMM-MQTTbridge’s readme here https://github.com/sergge1/MMM-MQTTbridge#mqtt-to-notifications-dictionary-section
            • SergeS
              Serge @KSumwalt
              @KSumwalt please update the module and try once more. If the problem will exist, send here your logs
              • F
                fribse
                • Cr4z33C
                  Cr4z33
                  I’ve got a BTicino F20T60A power consumption meter connected by MQTT so can someone please help me to show power usage only on MagicMirror by using this MM module?
                  Feel free to ask me MQTT / Home Assistant details to provide (as I don’t know right now what you need 😅)!
                  wishmaster270W 1 Reply Last reply
                  • wishmaster270W
                    wishmaster270 Module Developer @Cr4z33
                    @Cr4z33 Hi, I am working on a module which will be called MMM-ValuesByNotification (https://github.com/Tom-Hirschberger/MMM-ValuesByNotification) and will perfectly fit your needs.
                    If the payload of the notification is a valid json string the values can be selected with the JsonPath syntax.
                    If needed the values can be reformatted.
                    I am using it to display the temperature and humidity of different sensors in my house and the level of my watertank.
                    Screenshot
                    The module is functional already but not documented yet. The configuration can be a little bit tricky but I am planning to add a lot of examples to the readme in the next weeks.
                    Cr4z33C 1 Reply Last reply
                    Reply Quote 2
                    • Cr4z33C
                      Cr4z33 @wishmaster270
                      @wishmaster270 that’s great news I’ve added your repo and will wait then for the instructions once they come out.
                      • wishmaster270W
                        wishmaster270 Module Developer @Serge
                        @Serge Hi,
                        as i am unable to modify the first post to announce new release i will start a new thread. Maybe you can link to it in the first post.
                        SergeS 1 Reply Last reply
                        • SergeS
                          Serge @wishmaster270
                          @wishmaster270 done.
                          • 3 / 3
