Solved JSON request module
I correct myself, it is displayed but thus, having created the custom.css file in css:
Here is my config file:
// AFFICHAGE { module: "MMM-ValuesByNotification", position: "top_right", header: "TEMPERATURE MAISON", config: { updateInterval: 10, reuseCount: 100, addClassesRecursive: true, groups: [ { items: [ { notification: "TEMPSALLE", itemTitle: "Salle ", classes: "withIcons", values: [ { valueUnit: " °C", valueFormat: "Number(${value}).toFixed(2)", jsonpath: "data", }, ] }, { notification: "TEMPBUREAU", itemTitle: "Bureau ", values: [ { valueUnit: " °C", valueFormat: "Number(${value}).toFixed(2)", jsonpath: "data", }, ] }, ] }, ] }, },
@ELMAGO
Today, with my notebook ready things are getting easier.
I styled the module like the example you provided…
Let’s look at the steps to do this now:
First we tell the
itemWrapper? to display the items in rows and not columns and set the line height to the regular value
1.0` to avoid a great space in between:.MMM-ValuesByNotification .vbn .itemWrapper { flex-direction: row; line-height: 1.0; }
Next we tell the
itemsWrapper
to set a small space of5px
between the rows:.MMM-ValuesByNotification .vbn .itemsWrapper:first-child, .MMM-ValuesByNotification .vbn .itemsWrapper { gap: 5px; }
We then remove some margins of the title if items, remove the underlining and set the min-with to
60px
to get a straight lining of the values:.MMM-ValuesByNotification .vbn .itemTitle { margin-top: 0px; margin-bottom: 0px; min-width: 60px; text-decoration: unset; color: white; }
If you do not like the gray border around the items you can remove it with:
.MMM-ValuesByNotification .vbn .groupWrapper { border-style: none; }
If you copy all these contents to the
MagicMirror/css/custom.css
file and restore the originalvaluesByNotification.css
you should the style of above. -
@wishmaster270
good evening
thank you for your return, for the config file I put back yours or mine is good? I would test this tomorrow morning, tonight it’s rugby.
good evening and thank you again -
Good evening,
I couldn’t wait…it’s almost great, I just have to find how to align the text on the left and the temperatures on the right.
Thank you very much for your help
@ELMAGO
Do you mean something like this…
We first define a width for the most outer wrapper. I choose 200px but can adjust it to the value you want:
.MMM-ValuesByNotification .vbn .groupsWrapper{ width: 200px; }
Then we configure the next two deeper wrappers to expand to the maximum width:
.MMM-ValuesByNotification .vbn .groupWrapper, .MMM-ValuesByNotification .vbn .itemsWrapper { width: 100%; }
And we tell the itemWrapper to expand to maximum width and justify its content by putting space around the items equally:
.MMM-ValuesByNotification .vbn .itemWrapper { flex-direction: row; line-height: 1.0; width: 100%; justify-content: space-between; }
The rest stays the same as before:
.MMM-ValuesByNotification .vbn .itemTitle { margin-top: 0px; margin-bottom: 0px; min-width: 60px; text-decoration: unset; color: white; } .MMM-ValuesByNotification .vbn .groupWrapper { border-style: none; }
Hello
sorry to bother you again but is it possible to display an answer following the answer of the request.
example :
The JSON request returns false I would like to display “NON” -
@ELMAGO Sorry, but i do not understand exactly what you mean. You can override the “na” value which is the one displayed if no value could be parsed in the JSON.
The config option is:
naValue: "NON"
There might also be a chance to do add a
valueFormat
which checks for the “false” value in the JSON but that would be a little more complex and i need to know the exact format of the output. -
@wishmaster270
HelloNo, not al all.
the returned value will be “false” or “true” and I would like to replace it with “Non” or “Oui” in French. -
@ELMAGO
You can usevalueFormat
for this purpose.valueFormat: "\"${value}\".replace(\"false\",\"Non\").replace(\"true\",\"Oui\")",
This will convert the value to a string (if needed) and replaces all “false” with “Non” and “true” with “Oui”.
