    JSON request module
    41 Posts 3 Posters 18.6k Views 4 Watching
    • E Offline
      ELMAGO @wishmaster270
      @wishmaster270 said in JSON request module:
      valueTitle
      I’m really sorry but I’m really bad at this.
      I did this:
      config:
      //TEMPERATURE MAISON
         module: "MMM-CommandToNotification",
         disabled: false,
          updateInterval: 60,
          commands: [
            script: "/usr/bin/curl",
            args: "-s  http://192.168.100.244:3000/TEMPSALLE",
            timeout: 5000,
            notifications: [
             "TEMPSALLE",
                 args: "-s  http://192.168.100.244:3000/TEMPBUREAU",
                 timeout: 5000,
                 notifications: [
                  "TEMPBUREAU",
      // AFFICHAGE
      		module: "MMM-ValuesByNotification",
      		header: "TEMPERATURE MAISON",
      			updateInterval: 10,
      			reuseCount: 100,
      			addClassesRecursive: true,
      			groups: [
      					items: [
      							notification: "TEMPSALLE",
      							itemTitle: "Salle: ",
      							classes: "withIcons",
      							values: [
      									valueIcon: "fa fa-thermometer-full",
      									valueUnit: "°C",
      									valueFormat: "Number(${value}).toFixed(2)",
      									jsonpath: "data",
      									valueUnit: "%rH",
      									valueFormat: "Number(${value}).toFixed(1)",
      									jsonpath: "humidity",
      							notification: "TEMPBUREAU",
      							itemTitle: "Bureau ",
      							values: [
      									valueUnit: "°CC",
      									jsonpath: "data",
      									valueUnit: "%rH",
      And use css :
      .MMM-ValuesByNotification .vbn .itemWrapper {
        flex-direction: row;
      .MMM-ValuesByNotification .vbn .itemTitle {
        min-width: 105px;
        text-decoration: none;
      .MMM-ValuesByNotification .vbn .itemTitle.withIcons {
        margin-top: 17px;
      .MMM-ValuesByNotification .vbn .itemWrapper.withIcons {
        line-height: 22px;
      .MMM-ValuesByNotification .vbn .itemWrapper:not(.withIcons) {
        line-height: 10px;
      and nothing is displayed
      • wishmaster270W Offline
        wishmaster270 Module Developer @ELMAGO
        @ELMAGO
        Great to see the data beeing displayed. We get the styling, too.
        Please do not edit files in the module folder. You can modify/override all css in the custom.css file in the css directory of MagicMirror.
        The examples only overrides the things needed.
        Currently I only have my mobile and can not test any things. Maybe I can look at it tomorrow.
        E 2 Replies Last reply Reply Quote 0
        • E Offline
          @wishmaster270
          The custom file?
          there is no problem, you help me already it is a lot.
          There is nothing urgent, I just have this display to do on a whole home automation installation.
          I await your return and thank you again.
            sdetweil @ELMAGO
            @ELMAGO the CSS design is a stack, top down
            css/custom.css
            module_provided_css (in the module folder)
            css/main.css (provided by MM).
            so a search for a css setting starts with custom.css and stops at the 1st occurrence.
            • E Offline
              @wishmaster270 @sdetweil
              I correct myself, it is displayed but thus, having created the custom.css file in css:
              Here is my config file:
              // AFFICHAGE
              			updateInterval: 10,
              			reuseCount: 100,
              			groups: [
              					items: [
              							itemTitle: "Salle  ",
              							values: [
              									valueUnit: " °C",
              									jsonpath: "data",
              							values: [
              									valueUnit: " °C",
              									jsonpath: "data",
                @ELMAGO
                Today, with my notebook ready things are getting easier.
                I styled the module like the example you provided…
                Let’s look at the steps to do this now:
                First we tell the itemWrapper? to display the items in rows and not columns and set the line height to the regular value 1.0` to avoid a great space in between:
                  line-height: 1.0;
                Next we tell the itemsWrapper to set a small space of 5px between the rows:
                .MMM-ValuesByNotification .vbn .itemsWrapper:first-child,
                  gap: 5px;
                We then remove some margins of the title if items, remove the underlining and set the min-with to 60px to get a straight lining of the values:
                  margin-top: 0px;
                  margin-bottom: 0px;
                  min-width: 60px;
                  text-decoration: unset;
                  color: white;
                If you do not like the gray border around the items you can remove it with:
                .MMM-ValuesByNotification .vbn .groupWrapper {
                  border-style: none;
                If you copy all these contents to the MagicMirror/css/custom.css file and restore the original valuesByNotification.css you should the style of above.
                • E Offline
                  @wishmaster270
                  good evening
                  thank you for your return, for the config file I put back yours or mine is good? I would test this tomorrow morning, tonight it’s rugby.
                  good evening and thank you again
                  • E Offline
                    ELMAGO @ELMAGO
                    @ELMAGO
                    Good evening,
                    I couldn’t wait…it’s almost great, I just have to find how to align the text on the left and the temperatures on the right.
                    Thank you very much for your help
                      @ELMAGO
                      Do you mean something like this…
                      We first define a width for the most outer wrapper. I choose 200px but can adjust it to the value you want:
                      .MMM-ValuesByNotification .vbn .groupsWrapper{
                        width: 200px;
                      Then we configure the next two deeper wrappers to expand to the maximum width:
                      .MMM-ValuesByNotification .vbn .groupWrapper,
                      .MMM-ValuesByNotification .vbn .itemsWrapper {
                        width: 100%;
                      And we tell the itemWrapper to expand to maximum width and justify its content by putting space around the items equally:
                        line-height: 1.0;
                        width: 100%;
                        justify-content: space-between;
                      The rest stays the same as before:
                        margin-top: 0px;
                        margin-bottom: 0px;
                        min-width: 60px;
                        color: white;
                        border-style: none;
                      • E Offline
                        @wishmaster270
                        Re Goodnight
                        It’s awesome, it’s exactly what I wanted.
                        Thank you so much.
                        • E Offline
                          @wishmaster270
                          Hello
                          sorry to bother you again but is it possible to display an answer following the answer of the request.
                          example :
                          The JSON request returns false I would like to display “NON”
                            @ELMAGO Sorry, but i do not understand exactly what you mean. You can override the “na” value which is the one displayed if no value could be parsed in the JSON.
                            The config option is:
                            naValue: "NON"
                            There might also be a chance to do add a valueFormat which checks for the “false” value in the JSON but that would be a little more complex and i need to know the exact format of the output.
                            • E Offline
                              @wishmaster270
                              Hello
                              No, not al all.
                              the returned value will be “false” or “true” and I would like to replace it with “Non” or “Oui” in French.
                                @ELMAGO
                                You can use valueFormat for this purpose.
                                valueFormat: "\"${value}\".replace(\"false\",\"Non\").replace(\"true\",\"Oui\")",
                                This will convert the value to a string (if needed) and replaces all “false” with “Non” and “true” with “Oui”.
                                • E Offline
                                  @wishmaster270
                                  great, thank you.
                                  Is there a “lexicon” with these commands?
                                    @ELMAGO
                                    I added some to the [documentation] (https://github.com/Tom-Hirschberger/MMM-ValuesByNotification/blob/main/doc/value.md) of the module.
                                    As there can be used any build-in JavaScript function in valueFormat there are nearly endless possibilities.
                                    • E Offline
                                      @wishmaster270
                                      good evening,
                                      I tested the replace function:
                                      		header: "INFORMATION MÉGANE",
                                      			updateInterval: 300,
                                      			reuseCount: 100,
                                      			groups: [
                                      					items: [
                                      							notification: "AUTBATTMEGANE",
                                      							itemTitle: "Autonomie  ",
                                      							values: [
                                      									valueUnit: " Km",
                                      									jsonpath: "data",
                                      							notification: "BATTMEGANE",
                                      							itemTitle: "Charge batterie  ",
                                      							values: [
                                      									valueUnit: " %",
                                      									jsonpath: "data",
                                      							notification: "PLUGMEGANE",
                                      							itemTitle: "Voirture branchée ",
                                      							values: [
                                      									jsonpath: "data",
                                      But unfortunately it doesn’t work.
                                      Would you know why?
                                        @ELMAGO As valueFormat settings further down in the hierarchy override setting further up you only have to much valueFormat settings.
                                        This config should do the trick:
                                        			reuseCount: 100,
                                        			groups: [
                                        					items: [
                                        							values: [
                                        									valueUnit: " Km",
                                        									jsonpath: "data",
                                        							values: [
                                        									valueUnit: " %",
                                        									jsonpath: "data",
                                        							values: [
                                        									jsonpath: "data",
                                        • E Offline
                                          ELMAGO
                                          Hi @wishmaster270
                                          I come back here, it will be simpler.
                                          My code is:
                                          //INFORMATION HOMEY EUFY
                                             disabled: false,
                                              commands: [
                                                     args: "-s  http://192.168.100.244:3000/ETATEUFY",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "ETATEUFY",
                                                     args: "-s  http://192.168.100.244:3000/CAMSALLE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMSALLE",
                                                     args: "-s  http://192.168.100.244:3000/CAMPALIER",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMPALIER",
                                                     args: "-s  http://192.168.100.244:3000/CAMARRIERE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMARRIERE",
                                                     args: "-s  http://192.168.100.244:3000/CAMGARAGE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMGARAGE",
                                                     args: "-s  http://192.168.100.244:3000/CAMGAUCHE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMGAUCHE",
                                                     args: "-s  http://192.168.100.244:3000/CAMAVANT",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMAVANT",
                                                timeout: 1000,
                                                notifications: [
                                                 "TEMPSALLE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "TEMPBUREAU",
                                                     args: "-s  http://192.168.100.244:3000/TEMPCHELENA",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "TEMPCHELENA",
                                                     args: "-s  http://192.168.100.244:3000/TEMPCHLOUCA",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "TEMPCHLOUCA",
                                                     args: "-s  http://192.168.100.244:3000/TEMPCHALAN",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "TEMPCHALAN",
                                                     args: "-s  http://192.168.100.244:3000/TEMPCHPARENT",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "TEMPCHPARENT",
                                                	args: "-s  http://192.168.100.244:3000/AUTBATTMEGANE",
                                                	timeout: 1000,
                                                	notifications: [
                                                 	"AUTBATTMEGANE",
                                                     args: "-s  http://192.168.100.244:3000/BATTMEGANE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "BATTMEGANE",
                                                     args: "-s  http://192.168.100.244:3000/PLUGMEGANE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "PLUGMEGANE",
                                                     args: "-s  http://192.168.100.244:3000/CHARGEMEGANE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CHARGEMEGANE",
                                          So I think it launches all requests at the same time, because my server which must answer crashes.
                                          I wanted to split it like this:
                                             disabled: false,
                                              commands: [
                                                     timeout: 1000,
                                                     notifications: [
                                                      "ETATEUFY",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMSALLE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMPALIER",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMARRIERE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMGARAGE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMGAUCHE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CAMAVANT",
                                          and
                                             disabled: false,
                                              commands: [
                                                timeout: 1000,
                                                notifications: [
                                                 "TEMPSALLE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "TEMPBUREAU",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "TEMPCHELENA",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "TEMPCHLOUCA",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "TEMPCHALAN",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "TEMPCHPARENT",
                                          and :
                                             disabled: false,
                                              commands: [
                                                	timeout: 1000,
                                                	notifications: [
                                                 	"AUTBATTMEGANE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "BATTMEGANE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "PLUGMEGANE",
                                                     timeout: 1000,
                                                     notifications: [
                                                      "CHARGEMEGANE",
                                          But it doesn’t work, only the last element appears.
                                            @ELMAGO Hi,
                                            thats right. The module does not support multi instance configurations.
                                            You will need to copy the complete module folder and change some things to get it work.
                                            But to me it looks like your server is stressed with the 16 calls straight after each other. So you do not need more parallelism but less.
                                            So i will check if i can at a configurable delay after each command to stretch the time the calls get made to your server a little bit.
                                            E S 2 Replies Last reply Reply Quote 0
                                            • 2 / 3
