    JSON request module
    41 Posts 3 Posters 19.3k Views 4 Watching
    • E
      ELMAGO @wishmaster270
      @wishmaster270 said in JSON request module:
      Good evening
      (I am in France)
      Thanks for your answer but I still have the same result.
      //TEMPERATURE MAISON
         module: "MMM-CommandToNotification",
         disabled: false,
          updateInterval: 10,
          commands: [
            script: "/usr/bin/curl",
            args: "-vs  http://192.168.100.244:3000/TEMPSALLE",
            timeout: 5,
            notifications: [
             "TEMPSALLE",
      // AFFICHAGE
         module: "MMM-ValuesByNotification",
         header: "TEMPERATURE MAISON",
          groups: [
            items: [
              notification: "TEMPSALLE",
              itemTitle: "TEMPSALLE",
              values: [
                valueTitle: "TEMPSALLE",
      		valueUnit: "C",
      		jsonpath: "data",
      I have to miss something but I don’t see what
      wishmaster270W 1 Reply Last reply
      • wishmaster270W
        wishmaster270 Module Developer @ELMAGO
        @ELMAGO Hi, no problem let’s dive deeper. Can you please run the curl command manually on the console and paste the result here, please.
        E 1 Reply Last reply
        • E
          @wishmaster270
          There she is
          • wishmaster270W
            @ELMAGO
            Sorry, my fault.
            Can you please remove the v option of the curl command. It needs to be curl -s ....
            • E
              @wishmaster270
              It’s same
                 disabled: false,
                  updateInterval: 10,
                  commands: [
                    args: "-s  http://192.168.100.244:3000/TEMPSALLE",
                    timeout: 5,
                    notifications: [
                     "TEMPSALLE",
              // AFFICHAGE
                  groups: [
                    items: [
                      values: [
              		valueUnit: "C",
              		jsonpath: "data",
              • wishmaster270W
                @ELMAGO
                Sorry, took me a moment to set up a test environment…
                I think if your webserver is not very very fast you need to increase the timeout value in the command module.
                The timeout is in milliseconds and you configured 5. I guess it should be 5000.
                This config works fine in my development environment.
                			disabled: false,
                			 updateInterval: 60,
                			 commands: [
                			   timeout: 5000,
                			   notifications: [
                				"TEMPSALLE",
                			 groups: [
                			   items: [
                				 values: [
                				 valueUnit: "C",
                				 jsonpath: "data",
                Edit: I increased the updateInterval to 60
                • E
                  @wishmaster270
                  You are phenomenal…but I still have three problems:
                  1 - When I look for several values, it only shows me the first one.
                  2- The Celsius symbol does not seem to be accepted
                  3- 3- If I may abuse…is it possible to do the same formatting as this one. CSS and me…
                  Here is my code :
                     disabled: false,
                      updateInterval: 60,
                      commands: [
                        timeout: 5000,
                        notifications: [
                         "TEMPSALLE",
                     disabled: false,
                      updateInterval: 60,
                      commands: [
                        args: "-s  http://192.168.100.244:3000/TEMPBUREAU",
                        timeout: 5000,
                        notifications: [
                         "TEMPBUREAU",
                  // AFFICHAGE
                      groups: [
                        items: [
                          values: [
                            valueTitle: "SALLE A MANGER",
                  		valueUnit: "°C",
                  		jsonpath: "data",
                          notification: "TEMPBUREAU",
                          values: [
                            valueTitle: "BUREAU",
                  		valueUnit: "°C",
                  		jsonpath: "data",
                  Once again thank you for everything.
                  • wishmaster270W
                    @ELMAGO Step by Step closer to the goal😉
                    1: You can/need to use one instance of the command module to fetch the data of the to urls.
                    2: I use the Celsius sign in my setup without any problems but it may depend of the encoding of your operating system and Browser. You can try to use the html encoding ° instead.
                       disabled: false,
                        updateInterval: 60,
                        commands: [
                          timeout: 5000,
                          notifications: [
                           "TEMPSALLE",
                               timeout: 5000,
                               notifications: [
                                "TEMPBUREAU",
                    // AFFICHAGE
                        groups: [
                          items: [
                            values: [
                    		valueUnit: "°C",
                    		jsonpath: "data",
                            values: [
                    		valueUnit: "°C",
                    		jsonpath: "data",
                    3: I provided a lot examples with screenshots in the modules doc directory (screenshots). You will find the corresponding config and css of each screenshot in the configs. Maybe there is a styling included you like. If not feel free to ask again.
                    E 2 Replies Last reply
                    • E
                      • E
                        valueTitle
                        I’m really sorry but I’m really bad at this.
                        I did this:
                        config:
                           disabled: false,
                            updateInterval: 60,
                            commands: [
                              timeout: 5000,
                              notifications: [
                               "TEMPSALLE",
                                   timeout: 5000,
                                   notifications: [
                                    "TEMPBUREAU",
                        // AFFICHAGE
                        			updateInterval: 10,
                        			reuseCount: 100,
                        			addClassesRecursive: true,
                        			groups: [
                        					items: [
                        							itemTitle: "Salle: ",
                        							classes: "withIcons",
                        							values: [
                        									valueIcon: "fa fa-thermometer-full",
                        									valueUnit: "°C",
                        									valueFormat: "Number(${value}).toFixed(2)",
                        									jsonpath: "data",
                        									valueUnit: "%rH",
                        									valueFormat: "Number(${value}).toFixed(1)",
                        									jsonpath: "humidity",
                        							itemTitle: "Bureau ",
                        							values: [
                        									valueUnit: "°CC",
                        									jsonpath: "data",
                        									valueUnit: "%rH",
                        And use css :
                        .MMM-ValuesByNotification .vbn .itemWrapper {
                          flex-direction: row;
                        .MMM-ValuesByNotification .vbn .itemTitle {
                          min-width: 105px;
                          text-decoration: none;
                        .MMM-ValuesByNotification .vbn .itemTitle.withIcons {
                          margin-top: 17px;
                        .MMM-ValuesByNotification .vbn .itemWrapper.withIcons {
                          line-height: 22px;
                        .MMM-ValuesByNotification .vbn .itemWrapper:not(.withIcons) {
                          line-height: 10px;
                        and nothing is displayed
                        • wishmaster270W
                          @ELMAGO
                          Great to see the data beeing displayed. We get the styling, too.
                          Please do not edit files in the module folder. You can modify/override all css in the custom.css file in the css directory of MagicMirror.
                          The examples only overrides the things needed.
                          Currently I only have my mobile and can not test any things. Maybe I can look at it tomorrow.
                          • E
                            @wishmaster270
                            The custom file?
                            there is no problem, you help me already it is a lot.
                            There is nothing urgent, I just have this display to do on a whole home automation installation.
                            I await your return and thank you again.
                              sdetweil @ELMAGO
                              @ELMAGO the CSS design is a stack, top down
                              css/custom.css
                              module_provided_css (in the module folder)
                              css/main.css (provided by MM).
                              so a search for a css setting starts with custom.css and stops at the 1st occurrence.
                              • E
                                @wishmaster270 @sdetweil
                                I correct myself, it is displayed but thus, having created the custom.css file in css:
                                Here is my config file:
                                // AFFICHAGE
                                			updateInterval: 10,
                                			reuseCount: 100,
                                			groups: [
                                					items: [
                                							itemTitle: "Salle  ",
                                							values: [
                                									valueUnit: " °C",
                                									jsonpath: "data",
                                							values: [
                                									valueUnit: " °C",
                                									jsonpath: "data",
                                • wishmaster270W
                                  @ELMAGO
                                  Today, with my notebook ready things are getting easier.
                                  I styled the module like the example you provided…
                                  Let’s look at the steps to do this now:
                                  First we tell the itemWrapper? to display the items in rows and not columns and set the line height to the regular value 1.0` to avoid a great space in between:
                                    line-height: 1.0;
                                  Next we tell the itemsWrapper to set a small space of 5px between the rows:
                                  .MMM-ValuesByNotification .vbn .itemsWrapper:first-child,
                                    gap: 5px;
                                  We then remove some margins of the title if items, remove the underlining and set the min-with to 60px to get a straight lining of the values:
                                    margin-top: 0px;
                                    margin-bottom: 0px;
                                    min-width: 60px;
                                    text-decoration: unset;
                                    color: white;
                                  If you do not like the gray border around the items you can remove it with:
                                  .MMM-ValuesByNotification .vbn .groupWrapper {
                                    border-style: none;
                                  If you copy all these contents to the MagicMirror/css/custom.css file and restore the original valuesByNotification.css you should the style of above.
                                  • E
                                    @wishmaster270
                                    good evening
                                    thank you for your return, for the config file I put back yours or mine is good? I would test this tomorrow morning, tonight it’s rugby.
                                    good evening and thank you again
                                    • E
                                      ELMAGO @ELMAGO
                                      @ELMAGO
                                      Good evening,
                                      I couldn’t wait…it’s almost great, I just have to find how to align the text on the left and the temperatures on the right.
                                      Thank you very much for your help
                                      • wishmaster270W
                                        @ELMAGO
                                        Do you mean something like this…
                                        We first define a width for the most outer wrapper. I choose 200px but can adjust it to the value you want:
                                        .MMM-ValuesByNotification .vbn .groupsWrapper{
                                          width: 200px;
                                        Then we configure the next two deeper wrappers to expand to the maximum width:
                                        .MMM-ValuesByNotification .vbn .groupWrapper,
                                        .MMM-ValuesByNotification .vbn .itemsWrapper {
                                          width: 100%;
                                        And we tell the itemWrapper to expand to maximum width and justify its content by putting space around the items equally:
                                          line-height: 1.0;
                                          width: 100%;
                                          justify-content: space-between;
                                        The rest stays the same as before:
                                          margin-top: 0px;
                                          margin-bottom: 0px;
                                          min-width: 60px;
                                          color: white;
                                          border-style: none;
                                        • E
                                          @wishmaster270
                                          Re Goodnight
                                          It’s awesome, it’s exactly what I wanted.
                                          Thank you so much.
                                          • E
                                            @wishmaster270
                                            Hello
                                            sorry to bother you again but is it possible to display an answer following the answer of the request.
                                            example :
                                            The JSON request returns false I would like to display “NON”
