    JSON request module
    41 Posts 3 Posters 17.0k Views 4 Watching
    • E Offline
      ELMAGO @sdetweil
      @sdetweil thank.
      • wishmaster270W Offline
        wishmaster270 Module Developer @ELMAGO
        @ELMAGO Hi,
        You can use a simple curl command to fetch the data and get the data send as notification with my MMM-CommandToNotification module. The module supports to call commands periodically.
        As you do have the data as payload of a notification then you can use my MMM-ValuesByNotification module to display it. This module is very powerful, allows parsing the payload as Json, selecting values in the Json with JSONPath syntax and even reformatting.
        • E Offline
          ELMAGO @wishmaster270
          @wishmaster270
          Thank you for your reply.
          So I installed the two modules and configured my config as follows:
          //TEMPERATURE MAISON
             module: "MMM-CommandToNotification",
             disabled: false,
              updateInterval: 10,
              commands: [
                script: "http://192.168.100.244:3000/TEMPSALLE",
                args: "-10 10",
                timeout: 5,
                notifications: [
                 "TEMPSALLE",
          // AFFICHAGE
             module: "MMM-ValuesByNotification",
             header: "Module-1",
              groups: [
                items: [
                  notification: "TEMPSALLE",
                  itemTitle: "Item-1",
                  values: [
                    valueTitle: "Value-1",
          		valueUnit: "°C",
          		jsonpath: "data",
          and i get :
          Can you help me ?
            @ELMAGO You can NOT enter the url directly into the Command module. You need to call a valid Shell Command.
            In your case I will suggest curl.
            The full command will be:
            curl -vs  http://192.168.100.244:3000/TEMPSALLE2
            So the command configuration should be something like:
               disabled: false,
                updateInterval: 10,
                commands: [
                  script: "/usr/bin/curl",
                  args: "-vs  http://192.168.100.244:3000/TEMPSALLE2",
                  timeout: 5,
                  notifications: [
                   "TEMPSALLE",
            As a result the output of the curl command will be send as notification “TEMPSALE”.
            You can test the curl command in a terminal.
            • E Offline
              @wishmaster270 said in JSON request module:
              Good evening
              (I am in France)
              Thanks for your answer but I still have the same result.
                 disabled: false,
                  updateInterval: 10,
                  commands: [
                    args: "-vs  http://192.168.100.244:3000/TEMPSALLE",
                    timeout: 5,
                    notifications: [
                     "TEMPSALLE",
              // AFFICHAGE
                 header: "TEMPERATURE MAISON",
                  groups: [
                    items: [
                      itemTitle: "TEMPSALLE",
                      values: [
                        valueTitle: "TEMPSALLE",
              		valueUnit: "C",
              		jsonpath: "data",
              I have to miss something but I don’t see what
                @ELMAGO Hi, no problem let’s dive deeper. Can you please run the curl command manually on the console and paste the result here, please.
                • E Offline
                  @wishmaster270
                  There she is
                    @ELMAGO
                    Sorry, my fault.
                    Can you please remove the v option of the curl command. It needs to be curl -s ....
                    • E Offline
                      @wishmaster270
                      It’s same
                         disabled: false,
                          updateInterval: 10,
                          commands: [
                            args: "-s  http://192.168.100.244:3000/TEMPSALLE",
                            timeout: 5,
                            notifications: [
                             "TEMPSALLE",
                      // AFFICHAGE
                          groups: [
                            items: [
                              values: [
                      		valueUnit: "C",
                      		jsonpath: "data",
                        @ELMAGO
                        Sorry, took me a moment to set up a test environment…
                        I think if your webserver is not very very fast you need to increase the timeout value in the command module.
                        The timeout is in milliseconds and you configured 5. I guess it should be 5000.
                        This config works fine in my development environment.
                        			disabled: false,
                        			 updateInterval: 60,
                        			 commands: [
                        			   timeout: 5000,
                        			   notifications: [
                        				"TEMPSALLE",
                        			 groups: [
                        			   items: [
                        				 values: [
                        				 valueUnit: "C",
                        				 jsonpath: "data",
                        Edit: I increased the updateInterval to 60
                        • E Offline
                          @wishmaster270
                          You are phenomenal…but I still have three problems:
                          1 - When I look for several values, it only shows me the first one.
                          2- The Celsius symbol does not seem to be accepted
                          3- 3- If I may abuse…is it possible to do the same formatting as this one. CSS and me…
                          Here is my code :
                             disabled: false,
                              updateInterval: 60,
                              commands: [
                                timeout: 5000,
                                notifications: [
                                 "TEMPSALLE",
                             disabled: false,
                              updateInterval: 60,
                              commands: [
                                args: "-s  http://192.168.100.244:3000/TEMPBUREAU",
                                timeout: 5000,
                                notifications: [
                                 "TEMPBUREAU",
                          // AFFICHAGE
                              groups: [
                                items: [
                                  values: [
                                    valueTitle: "SALLE A MANGER",
                          		valueUnit: "°C",
                          		jsonpath: "data",
                                  notification: "TEMPBUREAU",
                                  values: [
                                    valueTitle: "BUREAU",
                          		valueUnit: "°C",
                          		jsonpath: "data",
                          Once again thank you for everything.
                            @ELMAGO Step by Step closer to the goal😉
                            1: You can/need to use one instance of the command module to fetch the data of the to urls.
                            2: I use the Celsius sign in my setup without any problems but it may depend of the encoding of your operating system and Browser. You can try to use the html encoding ° instead.
                               disabled: false,
                                updateInterval: 60,
                                commands: [
                                  timeout: 5000,
                                  notifications: [
                                   "TEMPSALLE",
                                       timeout: 5000,
                                       notifications: [
                                        "TEMPBUREAU",
                            // AFFICHAGE
                                groups: [
                                  items: [
                                    values: [
                            		valueUnit: "°C",
                            		jsonpath: "data",
                                    values: [
                            		valueUnit: "°C",
                            		jsonpath: "data",
                            3: I provided a lot examples with screenshots in the modules doc directory (screenshots). You will find the corresponding config and css of each screenshot in the configs. Maybe there is a styling included you like. If not feel free to ask again.
                            E 2 Replies Last reply Reply Quote 0
                            • E Offline
                              • E Offline
                                valueTitle
                                I’m really sorry but I’m really bad at this.
                                I did this:
                                config:
                                   disabled: false,
                                    updateInterval: 60,
                                    commands: [
                                      timeout: 5000,
                                      notifications: [
                                       "TEMPSALLE",
                                           timeout: 5000,
                                           notifications: [
                                            "TEMPBUREAU",
                                // AFFICHAGE
                                			updateInterval: 10,
                                			reuseCount: 100,
                                			addClassesRecursive: true,
                                			groups: [
                                					items: [
                                							itemTitle: "Salle: ",
                                							classes: "withIcons",
                                							values: [
                                									valueIcon: "fa fa-thermometer-full",
                                									valueUnit: "°C",
                                									valueFormat: "Number(${value}).toFixed(2)",
                                									jsonpath: "data",
                                									valueUnit: "%rH",
                                									valueFormat: "Number(${value}).toFixed(1)",
                                									jsonpath: "humidity",
                                							itemTitle: "Bureau ",
                                							values: [
                                									valueUnit: "°CC",
                                									jsonpath: "data",
                                									valueUnit: "%rH",
                                And use css :
                                .MMM-ValuesByNotification .vbn .itemWrapper {
                                  flex-direction: row;
                                .MMM-ValuesByNotification .vbn .itemTitle {
                                  min-width: 105px;
                                  text-decoration: none;
                                .MMM-ValuesByNotification .vbn .itemTitle.withIcons {
                                  margin-top: 17px;
                                .MMM-ValuesByNotification .vbn .itemWrapper.withIcons {
                                  line-height: 22px;
                                .MMM-ValuesByNotification .vbn .itemWrapper:not(.withIcons) {
                                  line-height: 10px;
                                and nothing is displayed
                                  @ELMAGO
                                  Great to see the data beeing displayed. We get the styling, too.
                                  Please do not edit files in the module folder. You can modify/override all css in the custom.css file in the css directory of MagicMirror.
                                  The examples only overrides the things needed.
                                  Currently I only have my mobile and can not test any things. Maybe I can look at it tomorrow.
                                  • E Offline
                                    @wishmaster270
                                    The custom file?
                                    there is no problem, you help me already it is a lot.
                                    There is nothing urgent, I just have this display to do on a whole home automation installation.
                                    I await your return and thank you again.
                                      sdetweil @ELMAGO
                                      @ELMAGO the CSS design is a stack, top down
                                      css/custom.css
                                      module_provided_css (in the module folder)
                                      css/main.css (provided by MM).
                                      so a search for a css setting starts with custom.css and stops at the 1st occurrence.
                                      • E Offline
                                        @wishmaster270 @sdetweil
                                        I correct myself, it is displayed but thus, having created the custom.css file in css:
                                        Here is my config file:
                                        // AFFICHAGE
                                        			updateInterval: 10,
                                        			reuseCount: 100,
                                        			groups: [
                                        					items: [
                                        							itemTitle: "Salle  ",
                                        							values: [
                                        									valueUnit: " °C",
                                        									jsonpath: "data",
                                        							values: [
                                        									valueUnit: " °C",
                                        									jsonpath: "data",
                                          @ELMAGO
                                          Today, with my notebook ready things are getting easier.
                                          I styled the module like the example you provided…
                                          Let’s look at the steps to do this now:
                                          First we tell the itemWrapper? to display the items in rows and not columns and set the line height to the regular value 1.0` to avoid a great space in between:
                                            line-height: 1.0;
                                          Next we tell the itemsWrapper to set a small space of 5px between the rows:
                                          .MMM-ValuesByNotification .vbn .itemsWrapper:first-child,
                                            gap: 5px;
                                          We then remove some margins of the title if items, remove the underlining and set the min-with to 60px to get a straight lining of the values:
                                            margin-top: 0px;
                                            margin-bottom: 0px;
                                            min-width: 60px;
                                            text-decoration: unset;
                                            color: white;
                                          If you do not like the gray border around the items you can remove it with:
                                          .MMM-ValuesByNotification .vbn .groupWrapper {
                                            border-style: none;
                                          If you copy all these contents to the MagicMirror/css/custom.css file and restore the original valuesByNotification.css you should the style of above.
                                          • E Offline
                                            @wishmaster270
                                            good evening
                                            thank you for your return, for the config file I put back yours or mine is good? I would test this tomorrow morning, tonight it’s rugby.
                                            good evening and thank you again
