    JSON request module
    41 Posts 3 Posters 19.3k Views 4 Watching
    • wishmaster270W
      wishmaster270 Module Developer @ELMAGO
      @ELMAGO
      Do you mean something like this…
      We first define a width for the most outer wrapper. I choose 200px but can adjust it to the value you want:
      .MMM-ValuesByNotification .vbn .groupsWrapper{
        width: 200px;
      Then we configure the next two deeper wrappers to expand to the maximum width:
      .MMM-ValuesByNotification .vbn .groupWrapper,
      .MMM-ValuesByNotification .vbn .itemsWrapper {
        width: 100%;
      And we tell the itemWrapper to expand to maximum width and justify its content by putting space around the items equally:
      .MMM-ValuesByNotification .vbn .itemWrapper {
        flex-direction: row;
        line-height: 1.0;
        width: 100%;
        justify-content: space-between;
      The rest stays the same as before:
      .MMM-ValuesByNotification .vbn .itemTitle {
        margin-top: 0px;
        margin-bottom: 0px;
        min-width: 60px;
        text-decoration: unset;
        color: white;
      .MMM-ValuesByNotification .vbn .groupWrapper {
        border-style: none;
      E 2 Replies Last reply
      • E
        ELMAGO @wishmaster270
        @wishmaster270
        Re Goodnight
        It’s awesome, it’s exactly what I wanted.
        Thank you so much.
        • E
          @wishmaster270
          Hello
          sorry to bother you again but is it possible to display an answer following the answer of the request.
          example :
          The JSON request returns false I would like to display “NON”
          wishmaster270W 1 Reply Last reply
          • wishmaster270W
            @ELMAGO Sorry, but i do not understand exactly what you mean. You can override the “na” value which is the one displayed if no value could be parsed in the JSON.
            The config option is:
            naValue: "NON"
            There might also be a chance to do add a valueFormat which checks for the “false” value in the JSON but that would be a little more complex and i need to know the exact format of the output.
            E 1 Reply Last reply
            • E
              @wishmaster270
              Hello
              No, not al all.
              the returned value will be “false” or “true” and I would like to replace it with “Non” or “Oui” in French.
              • wishmaster270W
                @ELMAGO
                You can use valueFormat for this purpose.
                valueFormat: "\"${value}\".replace(\"false\",\"Non\").replace(\"true\",\"Oui\")",
                This will convert the value to a string (if needed) and replaces all “false” with “Non” and “true” with “Oui”.
                • E
                  @wishmaster270
                  great, thank you.
                  Is there a “lexicon” with these commands?
                  • wishmaster270W
                    @ELMAGO
                    I added some to the [documentation] (https://github.com/Tom-Hirschberger/MMM-ValuesByNotification/blob/main/doc/value.md) of the module.
                    As there can be used any build-in JavaScript function in valueFormat there are nearly endless possibilities.
                    • E
                      @wishmaster270
                      good evening,
                      I tested the replace function:
                      		module: "MMM-ValuesByNotification",
                      		header: "INFORMATION MÉGANE",
                      			updateInterval: 300,
                      			reuseCount: 100,
                      			addClassesRecursive: true,
                      			groups: [
                      					items: [
                      							notification: "AUTBATTMEGANE",
                      							itemTitle: "Autonomie  ",
                      							values: [
                      									valueUnit: " Km",
                      									valueFormat: "Number(${value}).toFixed(2)",
                      									jsonpath: "data",
                      							notification: "BATTMEGANE",
                      							itemTitle: "Charge batterie  ",
                      							values: [
                      									valueUnit: " %",
                      									jsonpath: "data",
                      							notification: "PLUGMEGANE",
                      							itemTitle: "Voirture branchée ",
                      							classes: "withIcons",
                      							values: [
                      									jsonpath: "data",
                      But unfortunately it doesn’t work.
                      Would you know why?
                      • wishmaster270W
                        @ELMAGO As valueFormat settings further down in the hierarchy override setting further up you only have to much valueFormat settings.
                        This config should do the trick:
                        			reuseCount: 100,
                        			groups: [
                        					items: [
                        							values: [
                        									valueUnit: " Km",
                        									jsonpath: "data",
                        							values: [
                        									valueUnit: " %",
                        									jsonpath: "data",
                        							values: [
                        									jsonpath: "data",
                        • E
                          ELMAGO
                          Hi @wishmaster270
                          I come back here, it will be simpler.
                          My code is:
                          //INFORMATION HOMEY EUFY
                             module: "MMM-CommandToNotification",
                             disabled: false,
                              commands: [
                                     script: "/usr/bin/curl",
                                     args: "-s  http://192.168.100.244:3000/ETATEUFY",
                                     timeout: 1000,
                                     notifications: [
                                      "ETATEUFY",
                                     args: "-s  http://192.168.100.244:3000/CAMSALLE",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMSALLE",
                                     args: "-s  http://192.168.100.244:3000/CAMPALIER",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMPALIER",
                                     args: "-s  http://192.168.100.244:3000/CAMARRIERE",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMARRIERE",
                                     args: "-s  http://192.168.100.244:3000/CAMGARAGE",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMGARAGE",
                                     args: "-s  http://192.168.100.244:3000/CAMGAUCHE",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMGAUCHE",
                                     args: "-s  http://192.168.100.244:3000/CAMAVANT",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMAVANT",
                                args: "-s  http://192.168.100.244:3000/TEMPSALLE",
                                timeout: 1000,
                                notifications: [
                                 "TEMPSALLE",
                                     args: "-s  http://192.168.100.244:3000/TEMPBUREAU",
                                     timeout: 1000,
                                     notifications: [
                                      "TEMPBUREAU",
                                     args: "-s  http://192.168.100.244:3000/TEMPCHELENA",
                                     timeout: 1000,
                                     notifications: [
                                      "TEMPCHELENA",
                                     args: "-s  http://192.168.100.244:3000/TEMPCHLOUCA",
                                     timeout: 1000,
                                     notifications: [
                                      "TEMPCHLOUCA",
                                     args: "-s  http://192.168.100.244:3000/TEMPCHALAN",
                                     timeout: 1000,
                                     notifications: [
                                      "TEMPCHALAN",
                                     args: "-s  http://192.168.100.244:3000/TEMPCHPARENT",
                                     timeout: 1000,
                                     notifications: [
                                      "TEMPCHPARENT",
                                	args: "-s  http://192.168.100.244:3000/AUTBATTMEGANE",
                                	timeout: 1000,
                                	notifications: [
                                 	"AUTBATTMEGANE",
                                     args: "-s  http://192.168.100.244:3000/BATTMEGANE",
                                     timeout: 1000,
                                     notifications: [
                                      "BATTMEGANE",
                                     args: "-s  http://192.168.100.244:3000/PLUGMEGANE",
                                     timeout: 1000,
                                     notifications: [
                                      "PLUGMEGANE",
                                     args: "-s  http://192.168.100.244:3000/CHARGEMEGANE",
                                     timeout: 1000,
                                     notifications: [
                                      "CHARGEMEGANE",
                          So I think it launches all requests at the same time, because my server which must answer crashes.
                          I wanted to split it like this:
                             disabled: false,
                              commands: [
                                     timeout: 1000,
                                     notifications: [
                                      "ETATEUFY",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMSALLE",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMPALIER",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMARRIERE",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMGARAGE",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMGAUCHE",
                                     timeout: 1000,
                                     notifications: [
                                      "CAMAVANT",
                          and
                             disabled: false,
                              commands: [
                                timeout: 1000,
                                notifications: [
                                 "TEMPSALLE",
                                     timeout: 1000,
                                     notifications: [
                                      "TEMPBUREAU",
                                     timeout: 1000,
                                     notifications: [
                                      "TEMPCHELENA",
                                     timeout: 1000,
                                     notifications: [
                                      "TEMPCHLOUCA",
                                     timeout: 1000,
                                     notifications: [
                                      "TEMPCHALAN",
                                     timeout: 1000,
                                     notifications: [
                                      "TEMPCHPARENT",
                          and :
                             disabled: false,
                              commands: [
                                	timeout: 1000,
                                	notifications: [
                                 	"AUTBATTMEGANE",
                                     timeout: 1000,
                                     notifications: [
                                      "BATTMEGANE",
                                     timeout: 1000,
                                     notifications: [
                                      "PLUGMEGANE",
                                     timeout: 1000,
                                     notifications: [
                                      "CHARGEMEGANE",
                          But it doesn’t work, only the last element appears.
                          • wishmaster270W
                            @ELMAGO Hi,
                            thats right. The module does not support multi instance configurations.
                            You will need to copy the complete module folder and change some things to get it work.
                            But to me it looks like your server is stressed with the 16 calls straight after each other. So you do not need more parallelism but less.
                            So i will check if i can at a configurable delay after each command to stretch the time the calls get made to your server a little bit.
                            E S 2 Replies Last reply
                            • E
                              @wishmaster270
                              good morning
                              I don’t mind doing it by hand if you explain to me what I need to change
                              • wishmaster270W
                                @ELMAGO Hi,
                                i just released a new version of the module which has a new option delayNext that can be added to each command.
                                The module then starts the command and waits this amount of milliseconds before the next one is processed.
                                So in your case you can add a delayNext: 1000 to each of the commands to give your server some time between the calls.
                                  sdetweil @wishmaster270
                                  @wishmaster270 you could make it support multi instance easily
                                  in the modulename.js when u sendSocketNotification… add the module id to the data
                                  in the node_helper, send the id back
                                  in the modulename.js in receiveSocketNotification
                                  check that the returned id matches this instances id
                                  sendSocketNotification from the node_helper is a broadcast , all instances get it at the same time, thus the need for the check.
                                  • wishmaster270W
                                    wishmaster270 Module Developer @sdetweil
                                    @sdetweil Hi Sam, I will check that for the next release.
                                    I already added something similar to one of my other modules but did not know that there is a module id already and added a uuid instead.
                                      @wishmaster270 this.indentifier
                                      https://docs.magicmirror.builders/development/core-module-file.html#available-module-instance-properties
                                      • E
                                        @wishmaster270
                                        ok, i test
                                        • BKeyportB BKeyport referenced this topic on
                                        • 2 / 3
