    JSON request module
    41 Posts 3 Posters 19.3k Views 4 Watching
    • E
      ELMAGO @wishmaster270
      • E
        @wishmaster270 said in JSON request module:
        valueTitle
        I’m really sorry but I’m really bad at this.
        I did this:
        config:
        //TEMPERATURE MAISON
           module: "MMM-CommandToNotification",
           disabled: false,
            updateInterval: 60,
            commands: [
              script: "/usr/bin/curl",
              args: "-s  http://192.168.100.244:3000/TEMPSALLE",
              timeout: 5000,
              notifications: [
               "TEMPSALLE",
                   args: "-s  http://192.168.100.244:3000/TEMPBUREAU",
                   timeout: 5000,
                   notifications: [
                    "TEMPBUREAU",
        // AFFICHAGE
        		module: "MMM-ValuesByNotification",
        		header: "TEMPERATURE MAISON",
        			updateInterval: 10,
        			reuseCount: 100,
        			addClassesRecursive: true,
        			groups: [
        					items: [
        							notification: "TEMPSALLE",
        							itemTitle: "Salle: ",
        							classes: "withIcons",
        							values: [
        									valueIcon: "fa fa-thermometer-full",
        									valueUnit: "°C",
        									valueFormat: "Number(${value}).toFixed(2)",
        									jsonpath: "data",
        									valueUnit: "%rH",
        									valueFormat: "Number(${value}).toFixed(1)",
        									jsonpath: "humidity",
        							notification: "TEMPBUREAU",
        							itemTitle: "Bureau ",
        							values: [
        									valueUnit: "°CC",
        									jsonpath: "data",
        									valueUnit: "%rH",
        And use css :
        .MMM-ValuesByNotification .vbn .itemWrapper {
          flex-direction: row;
        .MMM-ValuesByNotification .vbn .itemTitle {
          min-width: 105px;
          text-decoration: none;
        .MMM-ValuesByNotification .vbn .itemTitle.withIcons {
          margin-top: 17px;
        .MMM-ValuesByNotification .vbn .itemWrapper.withIcons {
          line-height: 22px;
        .MMM-ValuesByNotification .vbn .itemWrapper:not(.withIcons) {
          line-height: 10px;
        and nothing is displayed
        wishmaster270W 1 Reply Last reply
        • wishmaster270W
          wishmaster270 Module Developer @ELMAGO
          @ELMAGO
          Great to see the data beeing displayed. We get the styling, too.
          Please do not edit files in the module folder. You can modify/override all css in the custom.css file in the css directory of MagicMirror.
          The examples only overrides the things needed.
          Currently I only have my mobile and can not test any things. Maybe I can look at it tomorrow.
          E 2 Replies Last reply
          • E
            @wishmaster270
            The custom file?
            there is no problem, you help me already it is a lot.
            There is nothing urgent, I just have this display to do on a whole home automation installation.
            I await your return and thank you again.
              sdetweil @ELMAGO
              @ELMAGO the CSS design is a stack, top down
              css/custom.css
              module_provided_css (in the module folder)
              css/main.css (provided by MM).
              so a search for a css setting starts with custom.css and stops at the 1st occurrence.
              • E
                @wishmaster270 @sdetweil
                I correct myself, it is displayed but thus, having created the custom.css file in css:
                Here is my config file:
                // AFFICHAGE
                			updateInterval: 10,
                			reuseCount: 100,
                			groups: [
                					items: [
                							itemTitle: "Salle  ",
                							values: [
                									valueUnit: " °C",
                									jsonpath: "data",
                							values: [
                									valueUnit: " °C",
                									jsonpath: "data",
                • wishmaster270W
                  @ELMAGO
                  Today, with my notebook ready things are getting easier.
                  I styled the module like the example you provided…
                  Let’s look at the steps to do this now:
                  First we tell the itemWrapper? to display the items in rows and not columns and set the line height to the regular value 1.0` to avoid a great space in between:
                    line-height: 1.0;
                  Next we tell the itemsWrapper to set a small space of 5px between the rows:
                  .MMM-ValuesByNotification .vbn .itemsWrapper:first-child,
                    gap: 5px;
                  We then remove some margins of the title if items, remove the underlining and set the min-with to 60px to get a straight lining of the values:
                    margin-top: 0px;
                    margin-bottom: 0px;
                    min-width: 60px;
                    text-decoration: unset;
                    color: white;
                  If you do not like the gray border around the items you can remove it with:
                  .MMM-ValuesByNotification .vbn .groupWrapper {
                    border-style: none;
                  If you copy all these contents to the MagicMirror/css/custom.css file and restore the original valuesByNotification.css you should the style of above.
                  E 1 Reply Last reply
                  • E
                    @wishmaster270
                    good evening
                    thank you for your return, for the config file I put back yours or mine is good? I would test this tomorrow morning, tonight it’s rugby.
                    good evening and thank you again
                    • E
                      ELMAGO @ELMAGO
                      @ELMAGO
                      Good evening,
                      I couldn’t wait…it’s almost great, I just have to find how to align the text on the left and the temperatures on the right.
                      Thank you very much for your help
                      • wishmaster270W
                        @ELMAGO
                        Do you mean something like this…
                        We first define a width for the most outer wrapper. I choose 200px but can adjust it to the value you want:
                        .MMM-ValuesByNotification .vbn .groupsWrapper{
                          width: 200px;
                        Then we configure the next two deeper wrappers to expand to the maximum width:
                        .MMM-ValuesByNotification .vbn .groupWrapper,
                        .MMM-ValuesByNotification .vbn .itemsWrapper {
                          width: 100%;
                        And we tell the itemWrapper to expand to maximum width and justify its content by putting space around the items equally:
                          line-height: 1.0;
                          width: 100%;
                          justify-content: space-between;
                        The rest stays the same as before:
                          margin-top: 0px;
                          margin-bottom: 0px;
                          min-width: 60px;
                          color: white;
                          border-style: none;
                        • E
                          @wishmaster270
                          Re Goodnight
                          It’s awesome, it’s exactly what I wanted.
                          Thank you so much.
                          • E
                            @wishmaster270
                            Hello
                            sorry to bother you again but is it possible to display an answer following the answer of the request.
                            example :
                            The JSON request returns false I would like to display “NON”
                            • wishmaster270W
                              @ELMAGO Sorry, but i do not understand exactly what you mean. You can override the “na” value which is the one displayed if no value could be parsed in the JSON.
                              The config option is:
                              naValue: "NON"
                              There might also be a chance to do add a valueFormat which checks for the “false” value in the JSON but that would be a little more complex and i need to know the exact format of the output.
                              • E
                                @wishmaster270
                                Hello
                                No, not al all.
                                the returned value will be “false” or “true” and I would like to replace it with “Non” or “Oui” in French.
                                • wishmaster270W
                                  @ELMAGO
                                  You can use valueFormat for this purpose.
                                  valueFormat: "\"${value}\".replace(\"false\",\"Non\").replace(\"true\",\"Oui\")",
                                  This will convert the value to a string (if needed) and replaces all “false” with “Non” and “true” with “Oui”.
                                  • E
                                    @wishmaster270
                                    great, thank you.
                                    Is there a “lexicon” with these commands?
                                    • wishmaster270W
                                      @ELMAGO
                                      I added some to the [documentation] (https://github.com/Tom-Hirschberger/MMM-ValuesByNotification/blob/main/doc/value.md) of the module.
                                      As there can be used any build-in JavaScript function in valueFormat there are nearly endless possibilities.
                                      • E
                                        @wishmaster270
                                        good evening,
                                        I tested the replace function:
                                        		header: "INFORMATION MÉGANE",
                                        			updateInterval: 300,
                                        			reuseCount: 100,
                                        			groups: [
                                        					items: [
                                        							notification: "AUTBATTMEGANE",
                                        							itemTitle: "Autonomie  ",
                                        							values: [
                                        									valueUnit: " Km",
                                        									jsonpath: "data",
                                        							notification: "BATTMEGANE",
                                        							itemTitle: "Charge batterie  ",
                                        							values: [
                                        									valueUnit: " %",
                                        									jsonpath: "data",
                                        							notification: "PLUGMEGANE",
                                        							itemTitle: "Voirture branchée ",
                                        							values: [
                                        									jsonpath: "data",
                                        But unfortunately it doesn’t work.
                                        Would you know why?
                                        • wishmaster270W
                                          @ELMAGO As valueFormat settings further down in the hierarchy override setting further up you only have to much valueFormat settings.
                                          This config should do the trick:
                                          			reuseCount: 100,
                                          			groups: [
                                          					items: [
                                          							values: [
                                          									valueUnit: " Km",
                                          									jsonpath: "data",
                                          							values: [
                                          									valueUnit: " %",
                                          									jsonpath: "data",
                                          							values: [
                                          									jsonpath: "data",
                                          • E
                                            ELMAGO
                                            Hi @wishmaster270
                                            I come back here, it will be simpler.
                                            My code is:
                                            //INFORMATION HOMEY EUFY
                                               disabled: false,
                                                commands: [
                                                       args: "-s  http://192.168.100.244:3000/ETATEUFY",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "ETATEUFY",
                                                       args: "-s  http://192.168.100.244:3000/CAMSALLE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMSALLE",
                                                       args: "-s  http://192.168.100.244:3000/CAMPALIER",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMPALIER",
                                                       args: "-s  http://192.168.100.244:3000/CAMARRIERE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMARRIERE",
                                                       args: "-s  http://192.168.100.244:3000/CAMGARAGE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMGARAGE",
                                                       args: "-s  http://192.168.100.244:3000/CAMGAUCHE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMGAUCHE",
                                                       args: "-s  http://192.168.100.244:3000/CAMAVANT",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMAVANT",
                                                  timeout: 1000,
                                                  notifications: [
                                                   "TEMPSALLE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "TEMPBUREAU",
                                                       args: "-s  http://192.168.100.244:3000/TEMPCHELENA",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "TEMPCHELENA",
                                                       args: "-s  http://192.168.100.244:3000/TEMPCHLOUCA",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "TEMPCHLOUCA",
                                                       args: "-s  http://192.168.100.244:3000/TEMPCHALAN",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "TEMPCHALAN",
                                                       args: "-s  http://192.168.100.244:3000/TEMPCHPARENT",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "TEMPCHPARENT",
                                                  	args: "-s  http://192.168.100.244:3000/AUTBATTMEGANE",
                                                  	timeout: 1000,
                                                  	notifications: [
                                                   	"AUTBATTMEGANE",
                                                       args: "-s  http://192.168.100.244:3000/BATTMEGANE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "BATTMEGANE",
                                                       args: "-s  http://192.168.100.244:3000/PLUGMEGANE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "PLUGMEGANE",
                                                       args: "-s  http://192.168.100.244:3000/CHARGEMEGANE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CHARGEMEGANE",
                                            So I think it launches all requests at the same time, because my server which must answer crashes.
                                            I wanted to split it like this:
                                               disabled: false,
                                                commands: [
                                                       timeout: 1000,
                                                       notifications: [
                                                        "ETATEUFY",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMSALLE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMPALIER",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMARRIERE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMGARAGE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMGAUCHE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CAMAVANT",
                                            and
                                               disabled: false,
                                                commands: [
                                                  timeout: 1000,
                                                  notifications: [
                                                   "TEMPSALLE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "TEMPBUREAU",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "TEMPCHELENA",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "TEMPCHLOUCA",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "TEMPCHALAN",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "TEMPCHPARENT",
                                            and :
                                               disabled: false,
                                                commands: [
                                                  	timeout: 1000,
                                                  	notifications: [
                                                   	"AUTBATTMEGANE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "BATTMEGANE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "PLUGMEGANE",
                                                       timeout: 1000,
                                                       notifications: [
                                                        "CHARGEMEGANE",
                                            But it doesn’t work, only the last element appears.
                                            • 2 / 3
