Unsolved MMM-PIR-Sensor-Lite does not switch HDMI off
@Laz
I have exactly the same Problem using MMM-PIR-Sensor-Lite in combination with MMM-RTSPStream and even by using MMM-PIR-Sensor-Lite in combination with MMM-iFrame.I have no idea…
Tell me which command to restart MagicMirror? I want to try after turning on the screen to reboot the program itself.
Not raspberries, but mirror programs. Maybe it will help return the stream picture to the right place…? -
pm2 restart /home/vova/MagicMirror/installers/mm.sh
This command overloaded the program MM2 and returned the video stream to the right place in the RTSP frame…)
@Laz pm2 status
will show u the apps that pm2 manages
pm2 restart xxxx
where xxx is the name or the number of the row
pm2 restart MagicMirror
or
pm2 restart 0or if u have more that one app, like I do, pm2 restart all
on Linux, a convention is that passing --help to a command will show u it’s options
pm2 --help
@sdetweil Thank you !!! ))))
Maybe there is an alternative using MMM-RTSPStream for showing a live stream from the own webcam…???
