    Display logos?
    12 Posts 4 Posters 5.4k Views 4 Watching
      Rags @Bungle68
      @Bungle68 For images stored in a local folder i have used the module MMM-ImageSlideshow previously. However, i have now moved to using MMM-Google Photos which is excellent and photos can be refreshed quite easily via Google Photos app. For Logo try
      MMM-SimpleLogo. Though it currently not maintained.
        Bungle68 @Rags
        @Rags thanks, will give it a go
          Bungle68 @Bungle68
          @Bungle68 this is my current set up in the config.js
                module: 'MMM-SimpleLog',
                position: 'top_left',      //This can be any of the regions.
           //The config property is optional.
                file: ["~/home/mipi/MagicMirror/modules/MMM-SimpleLogo/Pi.png"]
               width: '300px'      }
          However, it’s not showing any picture on the screen, or any errors? Has anyone used the SimpleLogo and can share the config?
            sdetweil @Bungle68
            @Bungle68 the file name is wrong
            ~ means /home/username (mipi?)
            then u have /home/mipi
            so I suspect /home/mipi/home/mipi does not exist…
              Bungle68 @sdetweil
              @sdetweil great, so I just need to drop the ~, as the rest is the path for the file 🤞
                sdetweil @Bungle68
                @Bungle68 correct. system is case sensitive. so make sure I deal with that if need be
                  Bungle68 @sdetweil
                  @sdetweil I’ve changed the path, but do I need the []either end?
                         module: ‘MMM-SimpleLogo’,
                         position: ‘top_left’,  //This can be any region.
                                  file: [“~/MagicMirror/modules/MMM-SimpleLogo/Pi.png”],   // See config options.
                                  width:     ‘300px’,
                    sdetweil @Bungle68
                    @Bungle68 i do not know… that is up to the module.
                    is it a list of filenames, even if only 1?
                      Bungle68 @sdetweil
                      @sdetweil it’s just an image I want to display on the screen. It’s not a module either, just code on the config.js
                      thgmirrorT S 2 Replies Last reply Reply Quote 0
                      • thgmirrorT
                        thgmirror @Bungle68
                        @Bungle68 I have good experiences with MMM-EasyPix.
                        You have to store your logo(s) in the subfolder “pix” of the module.
                          sdetweil @Bungle68
                          @Bungle68 it’s the module MMM-Simpke-Logo.
                          what does it expect for the file: parameter?
                          it’s actually fileUrl:
                          note that the image file must be IN the MagicMirror folder tree
                          1 Reply Last reply Reply Quote -1
