    Display logos?
    12 Posts 4 Posters 4.5k Views 4 Watching
      Bungle68
      What’s the best module to display a logo or series of pictures?
        Rags @Bungle68
        @Bungle68 For images stored in a local folder i have used the module MMM-ImageSlideshow previously. However, i have now moved to using MMM-Google Photos which is excellent and photos can be refreshed quite easily via Google Photos app. For Logo try
        MMM-SimpleLogo. Though it currently not maintained.
          Bungle68 @Rags
          @Rags thanks, will give it a go
            Bungle68 @Bungle68
            @Bungle68 this is my current set up in the config.js
                  module: 'MMM-SimpleLog',
                  position: 'top_left',      //This can be any of the regions.
             //The config property is optional.
                  file: ["~/home/mipi/MagicMirror/modules/MMM-SimpleLogo/Pi.png"]
                 width: '300px'      }
            However, it’s not showing any picture on the screen, or any errors? Has anyone used the SimpleLogo and can share the config?
              sdetweil @Bungle68
              @Bungle68 the file name is wrong
              ~ means /home/username (mipi?)
              then u have /home/mipi
              so I suspect /home/mipi/home/mipi does not exist…
                Bungle68 @sdetweil
                @sdetweil great, so I just need to drop the ~, as the rest is the path for the file 🤞
                  sdetweil @Bungle68
                  @Bungle68 correct. system is case sensitive. so make sure I deal with that if need be
                    Bungle68 @sdetweil
                    @sdetweil I’ve changed the path, but do I need the []either end?
                           module: ‘MMM-SimpleLogo’,
                           position: ‘top_left’,  //This can be any region.
                                    file: [“~/MagicMirror/modules/MMM-SimpleLogo/Pi.png”],   // See config options.
                                    width:     ‘300px’,
                      sdetweil @Bungle68
                      @Bungle68 i do not know… that is up to the module.
                      is it a list of filenames, even if only 1?
                        Bungle68 @sdetweil
                        @sdetweil it’s just an image I want to display on the screen. It’s not a module either, just code on the config.js
                        thgmirrorT S 2 Replies Last reply Reply Quote 0
                        • thgmirrorT Offline
                          thgmirror @Bungle68
                          @Bungle68 I have good experiences with MMM-EasyPix.
                          You have to store your logo(s) in the subfolder “pix” of the module.
                            sdetweil @Bungle68
                            @Bungle68 it’s the module MMM-Simpke-Logo.
                            what does it expect for the file: parameter?
                            it’s actually fileUrl:
                            note that the image file must be IN the MagicMirror folder tree
                            1 Reply Last reply Reply Quote -1
