    Display logos?
    12 Posts 4 Posters 5.5k Views 4 Watching
      Bungle68 @Rags
      @Rags thanks, will give it a go
      B 1 Reply Last reply
        Bungle68 @Bungle68
        @Bungle68 this is my current set up in the config.js
              module: 'MMM-SimpleLog',
              position: 'top_left',      //This can be any of the regions.
         //The config property is optional.
              file: ["~/home/mipi/MagicMirror/modules/MMM-SimpleLogo/Pi.png"]
             width: '300px'      }
        However, it’s not showing any picture on the screen, or any errors? Has anyone used the SimpleLogo and can share the config?
          sdetweil @Bungle68
          @Bungle68 the file name is wrong
          ~ means /home/username (mipi?)
          then u have /home/mipi
          so I suspect /home/mipi/home/mipi does not exist…
            Bungle68 @sdetweil
            @sdetweil great, so I just need to drop the ~, as the rest is the path for the file 🤞
              sdetweil @Bungle68
              @Bungle68 correct. system is case sensitive. so make sure I deal with that if need be
                Bungle68 @sdetweil
                @sdetweil I’ve changed the path, but do I need the []either end?
                       module: ‘MMM-SimpleLogo’,
                       position: ‘top_left’,  //This can be any region.
                                file: [“~/MagicMirror/modules/MMM-SimpleLogo/Pi.png”],   // See config options.
                                width:     ‘300px’,
                  sdetweil @Bungle68
                  @Bungle68 i do not know… that is up to the module.
                  is it a list of filenames, even if only 1?
                    Bungle68 @sdetweil
                    @sdetweil it’s just an image I want to display on the screen. It’s not a module either, just code on the config.js
                    thgmirrorT S 2 Replies Last reply
                    • thgmirrorT
                      thgmirror @Bungle68
                      @Bungle68 I have good experiences with MMM-EasyPix.
                      You have to store your logo(s) in the subfolder “pix” of the module.
                        sdetweil @Bungle68
                        @Bungle68 it’s the module MMM-Simpke-Logo.
                        what does it expect for the file: parameter?
                        it’s actually fileUrl:
                        note that the image file must be IN the MagicMirror folder tree
                        Reply Quote -1
