    MMM-futar - how to add modules multiple time?
    24 Posts 3 Posters 6.5k Views 3 Watching
    • 0 Offline
      0livia
      MMM-futar
      https://github.com/balassy/MMM-Futar
      In the description says that the module displays only a single stop and route data. But also has the ability to use more than one stop and route data. Which I would like to use.
      Unfortunately I do not get what the dev thought about when he wrote the instructions how to do that. It says - on your mirror, add this module multiple times.
      how to ad modul multiple times? Should I copy the module multiple times in the modules folder?
      I did but it is just did not work. Also the module name has to be different, if its not, than overwrite each other or gives the same name with (“copy” at the end) in this case the core system wont work just black screen.
      It is working somehow as it has got screenshoot on github but no example instructions how to add the module multiple times.
      https://github.com/balassy/MMM-Futar/blob/master/doc/screenshot-colors.png
      Anyone has an idea how can I solve this issue of mine?
      P.s
      Also if you want to install the module you do not need to ad this see below.
      var config = {
      Also change the uppercase letter “F” to lowercase “f” in the module name.
      • 0 Offline
        0livia @sdetweil
        @sdetweil when removed the bit you suggested it is working now.
        The thing is what i do not understand that it worked before removing the section from the config.js just only with one single item. Anyway thank you for your help guys!
          sdetweil @0livia
          @0livia git clone module new_foldername
          in new_foldername
          rename all.old things to the new_foldername
          edit the new_foldername.js
          change the register() to use the new_foldername
          and use new_foldername as the module name in config.js
          0 1 Reply Last reply Reply Quote 0
          • 0 Offline
            0livia @sdetweil
            @sdetweil ok thank you for pinging me to my issue. To double check that I got it right - what you are saying is basicly I have to copy (i dont use git) the moudule again in a different name for example mmm-futar1 and in that folder need to rename all the the mmm-futar to mmm-futar1, and in config js need to the the same thing. Is this correct?
            I’m on my way to Aalsmeer (NL) as I’m a trucker :) I 'll be back on wednesday so give it a try next week. I ll give you feedack how it goes.
              sdetweil @0livia
              @0livia yes correct. you can git clone
              just add the new output foldername to the end of the command
              and inside the one file have to change it too
              • 0 Offline
                0livia @sdetweil
                @sdetweil Hi I have contacted the DevGuy and he said no need to clone the modules multiple times, I tried and do not work that way.
                The solution what he told is not working for me either.
                Here is what he said - you need to add the modules into the config.js file like this way.
                module: “MMM-Futar”,
                position: “top_left”,
                header: ‘Közvágóhíd -> Ráckeve’,
                stopId: ‘BKK_009628’, // Közvágóhíd
                routeId: 'BKK_H6,
                header: ‘Ráckeve -> Közvágóhíd’,
                stopId: ‘BKK_007947’, // Ráckeve
                routeId: ‘BKK_H6’,
                I tried this way and it gives me a blank screen
                here is my config
                https://pastebin.com/bwrTtisP
                Anyone has any idea about this issue of mine?
                thgmirrorT S 2 Replies Last reply Reply Quote 1
                • thgmirrorT Offline
                  thgmirror @0livia
                  Hi @0livia, I had some trouble when I tried to locate modules at the same region…so I would use first to set one occurrence to top_left and the second to top_right.
                    sdetweil @0livia
                    @0livia black screen is because of a missing library
                    see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1
                    • 0 Offline
                      0livia @sdetweil
                      @sdetweil I started my mirror with the config a linked earlier.
                      This is my error in the terminal
                      [09.12.2022 15:57.24.612] [LOG] Initializing new module helper …
                      [09.12.2022 15:57.24.612] [LOG] Module helper loaded: MMM-Futar
                      [09.12.2022 15:57.24.625] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read properties of undefined (reading ‘split’)
                        sdetweil @0livia
                        @0livia can u show a few more lines? the stacktrace is there which will show the line causing the error
                          @sdetweil in your config posted above, u are missing a trailing quote mark
                                stopId: 'BKK_009628', // Közvágóhíd
                                routeId: 'BKK_H6,   <-----
                          but other than that your config works for me…
                          did you do npm install in the module folder?
                          did u add the request module as I noted before ?
