    MMM-futar - how to add modules multiple time?
    24 Posts 3 Posters 8.3k Views 3 Watching
      sdetweil @0livia
      @0livia git clone module new_foldername
      in new_foldername
      rename all.old things to the new_foldername
      edit the new_foldername.js
      change the register() to use the new_foldername
      and use new_foldername as the module name in config.js
      0 1 Reply Last reply
      • 0
        0livia @sdetweil
        @sdetweil ok thank you for pinging me to my issue. To double check that I got it right - what you are saying is basicly I have to copy (i dont use git) the moudule again in a different name for example mmm-futar1 and in that folder need to rename all the the mmm-futar to mmm-futar1, and in config js need to the the same thing. Is this correct?
        I’m on my way to Aalsmeer (NL) as I’m a trucker :) I 'll be back on wednesday so give it a try next week. I ll give you feedack how it goes.
          sdetweil @0livia
          @0livia yes correct. you can git clone
          just add the new output foldername to the end of the command
          and inside the one file have to change it too
          • 0
            0livia @sdetweil
            @sdetweil Hi I have contacted the DevGuy and he said no need to clone the modules multiple times, I tried and do not work that way.
            The solution what he told is not working for me either.
            Here is what he said - you need to add the modules into the config.js file like this way.
            module: “MMM-Futar”,
            position: “top_left”,
            header: ‘Közvágóhíd -> Ráckeve’,
            stopId: ‘BKK_009628’, // Közvágóhíd
            routeId: 'BKK_H6,
            header: ‘Ráckeve -> Közvágóhíd’,
            stopId: ‘BKK_007947’, // Ráckeve
            routeId: ‘BKK_H6’,
            I tried this way and it gives me a blank screen
            here is my config
            https://pastebin.com/bwrTtisP
            Anyone has any idea about this issue of mine?
            thgmirrorT S 2 Replies Last reply
            • thgmirrorT
              thgmirror @0livia
              Hi @0livia, I had some trouble when I tried to locate modules at the same region…so I would use first to set one occurrence to top_left and the second to top_right.
                sdetweil @0livia
                @0livia black screen is because of a missing library
                see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/1
                • 0
                  0livia @sdetweil
                  @sdetweil I started my mirror with the config a linked earlier.
                  This is my error in the terminal
                  [09.12.2022 15:57.24.612] [LOG] Initializing new module helper …
                  [09.12.2022 15:57.24.612] [LOG] Module helper loaded: MMM-Futar
                  [09.12.2022 15:57.24.625] [ERROR] WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: Cannot read properties of undefined (reading ‘split’)
                    sdetweil @0livia
                    @0livia can u show a few more lines? the stacktrace is there which will show the line causing the error
                      @sdetweil in your config posted above, u are missing a trailing quote mark
                            stopId: 'BKK_009628', // Közvágóhíd
                            routeId: 'BKK_H6,   <-----
                      but other than that your config works for me…
                      did you do npm install in the module folder?
                      did u add the request module as I noted before ?
                      • 0
                        0livia @sdetweil
                        @sdetweil said in MMM-futar - how to add modules multiple time?:
                        trailing quote mark
                        I did find the trailing quote mark was missing :)
                        when i first installed the module i did npm install in the module folder.
                        Should I do it again after modifying the config js?
                        I do not have this request module thingy i already done that, the mirror actually works fine evewn with the mmm-futar modul(just only one single item) as I want to add more 2 with the provided example just black screen
                          sdetweil @0livia
                          @0livia can u post the exact config for these modules?
                          please use the code mark wrapper
                          paste your text
                          select it all
                          hit the button above the editor that looks like </>
                          • 0
                            0livia @sdetweil
                            @sdetweil it is on pastebin but i can put ot here if you like.
                            /* MagicMirror² Config Sample
                             * By Michael Teeuw https://michaelteeuw.nl
                             * MIT Licensed.
                             * see https://docs.magicmirror.builders/configuration/introduction.html
                             * and https://docs.magicmirror.builders/modules/configuration.html
                            let config = {
                            	address: "localhost", 	// Address to listen on, can be:
                            	port: 8080,
                            	basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                            	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                            	language: "hu",
                            	locale: "hu-HU",
                            	timeFormat: 24,
                            	units: "metric",
                            			module: "alert",
                            			module: "updatenotification",
                            			position: "top_bar"
                            			module: "clock",
                            			position: "top_left"
                            			header: "US Holidays",
                            						symbol: "calendar-check",
                            						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                            			module: "compliments",
                            			position: "lower_third"
                            			module: "weather",
                            				type: "current",
                            				locationID: "3044475", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                            				apiKey: "001ffggghjkd4958e701a4e2a8340bbc"
                            			module: "weather",
                            			header: "Weather Forecast",
                            				type: "forecast",
                            			module: "newsfeed",
                            			position: "bottom_bar",
                            				feeds: [
                            						title: "HVG TECH TUDOMÁNY HÍREK",
                            						url: "http://hvg.hu/rss/tudomany"
                            						title: "BBC VILÁG HÍREK",
                            						url: "http://feeds.bbci.co.uk/news/world/rss.xml"
                            						title: "TELEX HÍREK",
                            						url: "https://www.index.hu/kulfold/rss"
                            				showSourceTitle: true,
                            				showPublishDate: true,
                            				broadcastNewsFeeds: true,
                            				broadcastNewsUpdates: true
                                   module: "MMM-network-signal",
                                   position: "top_center",
                                       // Configuration of the module goes here
                                    module: 'MMM-Futar',
                                    position: 'top_center',
                                    stopId: 'BKK_044033',
                                    routeId: '',
                                    header: 'Ráckeve -> Közvágóhíd',
                                    stopId: 'BKK_007947',  // Ráckeve
                                    routeId: 'BKK_H6',
                                    module: "MMM-Futar",
                                    header: 'Közvágóhíd -> Ráckeve',
                                    routeId: 'BKK_H6',
                                    minutesAfter: 50,
                                    hideStopTimesInNextMinutes: 0,
                                    updateInterval: 60000, // 1 minute in milliseconds
                                    showHead: true, // true | false
                                    showSymbolInHead: true, // true | false
                                    showSymbolInStopTime: false, // true | false
                                    showRouteNameInStopTime: false, // true | false
                                    maxNumberOfItems: 3,
                                    align: 'left', // 'left' | 'right'
                                    fade: true,
                                    fadePoint: 0.25,
                                    coloredSymbolInHead: true, // true | false
                                    coloredTextInHead: true, // true | false
                                    coloredSymbolInStopTime: true, // true | false
                                    coloredRouteNameInStopTime: true, // true | false
                                    symbolColors: {
                                      tram: '#ffcf42', // yellow-ish
                                      bus: '#1a9fed', // blue-ish
                                      subway: '#b3090c', // red-ish
                                      trolleybus: '#931517', // dark red-ish
                                      rail: '#5cbc82', // green-ish
                                      ferry: '#1a52ed' // dark-blue-ish
                                    alerts: {
                                      showHeaderInStopTime: true, // true | false
                                      showSymbolInStopTime: true, // true | false
                                      color: '#ffcf42', // 'auto' or any CSS color
                                      language: 'hu' // 'en' or 'hu' supported only by the Futár API
                              sdetweil @0livia
                              @0livia said in MMM-futar - how to add modules multiple time?:
                              minutesAfter: 50,
                              align: ‘left’, // ‘left’ | ‘right’
                              fade: true,
                              fadePoint: 0.25,
                              symbolColors: {
                              tram: ‘#ffcf42’, // yellow-ish
                              bus: ‘#1a9fed’, // blue-ish
                              subway: ‘#b3090c’, // red-ish
                              trolleybus: ‘#931517’, // dark red-ish
                              rail: ‘#5cbc82’, // green-ish
                              ferry: ‘#1a52ed’ // dark-blue-ish
                              your three modules work perfectly
                              the ‘problem’ is this config, as it has no ‘module’ or ‘position’ or ‘config’:{} section
                              • 0
                                0livia @sdetweil
                                @sdetweil so what do i need to modify?
                                  sdetweil @0livia
                                  @0livia the section I copied is incomplete…
                                  what module is that for?
                                  where do you want it (position:)
                                  and I ‘guess’ all that should be inside the config: {} section
                                  a module is
                                      module:  name,
                                      position: xxxx,
                                       ...  module specific config
                                  please read the topics listed in my signature, they will help a lot… I didn’t write them
                                  • 0
                                    0livia @sdetweil
                                    @sdetweil i do not know hwat do you mean sorry.
                                    if you have read the config js evrything is there, the module name position etc
                                            routeId: '',
                                            routeId: 'BKK_H6',
                                            routeId: 'BKK_H6',
                                      sdetweil @0livia
                                      @0livia it is NOT the Futar module setup… its the stuff AFTER
                                      this stuff
                                              minutesAfter: 50,
                                              fade: true,
                                              fadePoint: 0.25,
                                              symbolColors: {
                                      • 0
                                        0livia @sdetweil
                                        @sdetweil yes that is correct.
                                          sdetweil @0livia
                                          @0livia it MUST have more info to be in the modules:[] list
                                          it is missing the REQUIRED module: , position: and config: {} sections
                                          • 0
                                            0livia @sdetweil
                                            @sdetweil sorry i do not understand you
