default calendar module - vacation length
Hi guys, i hope it is the right section here…
… i have a question about the default calendar module:I want to show the vacation from an ics-file. Within this file you can find both start and end date. But i can’t get it worked to show me the end.
I prefer an output like:
Summer KW27 - KW33The [KW] is not that problem. My Output so far is just the beginning of the vacation. Is it possible to show the length at all?
Thanks for your help.
pauabaer -
@pauabaer do you have
showEnd:true,
set?also, you may have to fiddle with the dateFormat, fullDateFormat
as well…there are a LOT of config options.
thanks for the quick response. I have tried that way. See my config below:{ module: "calendar", header: "Berliner Ferien 2023", position: "top_left", config: { fullDayEventDateFormat: "[KW]ww", dateEndFormat: "[KW]ww", calendars: [ { symbol: "suitcase-rolling", url: "https://www.ferienwiki.de/exports/ferien/2023/de/berlin", maximumEntries: "4" } ] } }, -
when i set this - i think its not neccessary because default=true - no change in the output. That’s why I am asking here. -
@pauabaer the default is false in the code
showEnd: false,its case sensitive
,and must be in the config:{} section, NOT in the calendars:[] section -
I‘ve already set this beneath the dateFormat in the config-section. But without success.
