    default calendar module - vacation length
    7 Posts 2 Posters 1.5k Views 2 Watching
      pauabaer
      Hi guys, i hope it is the right section here…
      … i have a question about the default calendar module:
      I want to show the vacation from an ics-file. Within this file you can find both start and end date. But i can’t get it worked to show me the end.
      I prefer an output like:
      Summer KW27 - KW33
      The [KW] is not that problem. My Output so far is just the beginning of the vacation. Is it possible to show the length at all?
      Thanks for your help.
      pauabaer
        sdetweil @pauabaer
        @pauabaer do you have
        showEnd:true,
        set?
        also, you may have to fiddle with the dateFormat, fullDateFormat
        as well…
        there are a LOT of config options.
          pauabaer @sdetweil
          thanks for the quick response. I have tried that way. See my config below:
          			header: "Berliner Ferien 2023",
          				fullDayEventDateFormat: "[KW]ww",
          				dateEndFormat: "[KW]ww",
          						symbol: "suitcase-rolling",
          						url: "https://www.ferienwiki.de/exports/ferien/2023/de/berlin",
          						maximumEntries: "4"
            sdetweil @pauabaer
            @pauabaer
            showEnd: true
            is not set
              pauabaer @sdetweil
              when i set this - i think its not neccessary because default=true - no change in the output. That’s why I am asking here.
                sdetweil @pauabaer
                @pauabaer the default is false in the code
                	showEnd: false,
                its case sensitive
                ,and must be in the config:{} section, NOT in the calendars:[] section
                  pauabaer @sdetweil
                  I‘ve already set this beneath the dateFormat in the config-section. But without success.
