    Default Calendar: Display Birthdays, Anniversaries
    11 Posts 4 Posters 5.4k Views 4 Watching
      Rags
      Is it possible to integrate Google Birthday, Anniversary calendar(Calendar ID: addressbook#contacts@group.v.calendar.google.com) in MM config without using public ical url? This calendar does not have a secret ical url.
      S O 2 Replies Last reply Reply Quote 0
        sdetweil @Rags
        @Rags no, sorry. the calendar depends on the ics file
        you could downloaded it manually and use the file . I assume it doesn’t change much
          Rags @sdetweil
          @sdetweil Ok but newer entries to contacts will not show up.
          Could you guide me on how.? to configure the config.js entry pointing to the downloaded file. ALso,
            sdetweil @Rags
            @Rags put it in the calendar module folder
            the the url
            is
            http://localhost:8080/modules/default/calendar/????.ics
            ??? is whatever u named it
            the 8080 is whatever u have configured for port: in mm config.js
              sdetweil @Rags
              @Rags newer entries… it will have to be downloaded again.
              somebody/something has to use the public url.
              the owner of the calendar could give u the private url. I have one like this. daughter owns it
              I don’t see the ‘secret’ of the secret url if I can send it to you and you can use it without logging on as me… same as public
                Rags @sdetweil
                I used the export option on google calendar to download the file.
                The downloaded file looks like this;
                Birthdays_addressbook#contacts@group.v.calendar.google.com.ics
                The config file looks like this;
                'http://localhost:8080/modules/default/calendar/Birthdays_addressbook#contacts@group.v.calendar.google.com.ics
                I get a display of “an error in the calendar module, check log for more details”
                the Module is unable to read this format. What needs to be done?
                S F 3 Replies Last reply Reply Quote 0
                  sdetweil @Rags
                  @Rags I do not know what the export option format looks like. just use the public url in this
                  curl  -sL url  > somefile.ics
                  thn examine the somefile.ics
                  it is just a text file
                  that is the format required
                    sdetweil @Rags
                    @Rags that url string might need to treat special chars differently (escape them, or use the hex equivalent). I would rename it using simple text
                    • O
                      OberfragGER @Rags
                      @Rags
                      Im uskng MMM-GooglebirthdayProvider. I alreday installed it and have the key for it. work fine.
                      Problem- Google disavled the old authentification.
                      https://github.com/PalatinCoder/MMM-GoogleBirthdaysProvider
                      Just in case…
                      • F
                        Fantasmic78 @Rags
                        @Rags sorry to ask a maybe stupid question: but how do I export the birthday calendar from my Google calendars?
                        The key here is, that the birthday calendar it not a “normal” calendar with an ics file, so when looking into the calendar options, it doesn’t offer an export option (while it does for all my normal calendars).
                        Thx, Chris
                        • F
                          Fantasmic78 @Fantasmic78
                          Update: found it how to export also the birthday calendar (this only works by exporting ALL your calendars at once, but not on the birthday calendar itself).
                          And anyhow - that didn’t solve my issue - because the exported birthday calendar has each of the birthdays as 3 single events (birthday from last, current and next year), but it’s not a yearly event-series. So using this exported file once wouldn’t help much on my MM - after 2 years all the birthdary events would be gone again.
                          I will use a workaround now: I will create a separate calendar, where I enter all the birthdays manually (as yearly events). This calendar will then have a public address, and I can include it as separate calendar in MM.
