    Default Calendar: Display Birthdays, Anniversaries
    11 Posts 4 Posters 4.5k Views 4 Watching
      Rags @sdetweil
      @sdetweil Ok but newer entries to contacts will not show up.
      Could you guide me on how.? to configure the config.js entry pointing to the downloaded file. ALso,
        sdetweil @Rags
        @Rags put it in the calendar module folder
        the the url
        is
        http://localhost:8080/modules/default/calendar/????.ics
        ??? is whatever u named it
        the 8080 is whatever u have configured for port: in mm config.js
          sdetweil @Rags
          @Rags newer entries… it will have to be downloaded again.
          somebody/something has to use the public url.
          the owner of the calendar could give u the private url. I have one like this. daughter owns it
          I don’t see the ‘secret’ of the secret url if I can send it to you and you can use it without logging on as me… same as public
            Rags @sdetweil
            I used the export option on google calendar to download the file.
            The downloaded file looks like this;
            Birthdays_addressbook#contacts@group.v.calendar.google.com.ics
            The config file looks like this;
            'http://localhost:8080/modules/default/calendar/Birthdays_addressbook#contacts@group.v.calendar.google.com.ics
            I get a display of “an error in the calendar module, check log for more details”
            the Module is unable to read this format. What needs to be done?
            S F 3 Replies Last reply Reply Quote 0
              sdetweil @Rags
              @Rags I do not know what the export option format looks like. just use the public url in this
              curl  -sL url  > somefile.ics
              thn examine the somefile.ics
              it is just a text file
              that is the format required
                sdetweil @Rags
                @Rags that url string might need to treat special chars differently (escape them, or use the hex equivalent). I would rename it using simple text
                • O Offline
                  OberfragGER @Rags
                  @Rags
                  Im uskng MMM-GooglebirthdayProvider. I alreday installed it and have the key for it. work fine.
                  Problem- Google disavled the old authentification.
                  https://github.com/PalatinCoder/MMM-GoogleBirthdaysProvider
                  Just in case…
                  • F Offline
                    Fantasmic78 @Rags
                    @Rags sorry to ask a maybe stupid question: but how do I export the birthday calendar from my Google calendars?
                    The key here is, that the birthday calendar it not a “normal” calendar with an ics file, so when looking into the calendar options, it doesn’t offer an export option (while it does for all my normal calendars).
                    Thx, Chris
                    • F Offline
                      Fantasmic78 @Fantasmic78
                      Update: found it how to export also the birthday calendar (this only works by exporting ALL your calendars at once, but not on the birthday calendar itself).
                      And anyhow - that didn’t solve my issue - because the exported birthday calendar has each of the birthdays as 3 single events (birthday from last, current and next year), but it’s not a yearly event-series. So using this exported file once wouldn’t help much on my MM - after 2 years all the birthdary events would be gone again.
                      I will use a workaround now: I will create a separate calendar, where I enter all the birthdays manually (as yearly events). This calendar will then have a public address, and I can include it as separate calendar in MM.
