    How to autorestart MM once a day
    6 Posts 5 Posters 5.3k Views 5 Watching
    • N Offline
      ninjabreadman @MaxPower
      @MaxPower It stacks every 1-2 days? I don’t quite understand what that means.
      In any case, what command are you using to restart? Are you trying to restart MM (recommended) or the RPi? If you have pm2 installed and managing your MM process, I suggest using pm2 restart mm. Whatever commend you choose, run it in Terminal first to ensure it will do what you intend.
      There are lots of videos and walkthroughs available online on how to use crontab.
      I recommend you then add the following crontab task:
      * 4 * * * pm2 restart mm
      This will restart MM every day at 4am (when I assume you’re not using it) so that it’s ready in the morning.
      MaxPowerM 1 Reply Last reply Reply Quote 1
      • MaxPowerM Offline
        MaxPower @ninjabreadman
        @ninjabreadman thank you for the help!
        Sorry, I meant that my twitter modul stucks every day or so. I’m not sure why, but every other say one twit stuck and stays there forever until I restart MM. Sometimes it can be after 2-3 days sometimes several hours. So the esiest way I found is to restart the mirror every day.
        Thanks for the script, I added it to the cron, I hope it will work.
        E D 2 Replies Last reply Reply Quote 0
        • E Offline
          E3V3A @MaxPower
          @MaxPower Sound like it would be better to file an issue with the module developer github, to fix the problem, rather than have to restart you pi.
          "Everything I do (here) is for free – altruism is the way!"
            DaveChild @MaxPower
            @MaxPower said in How to autorestart MM once a day:
            Sorry to bump this old topic, but I found this searching for how to restart MM automatically and the crontab line given isn’t quite correct. That line will restart MM every minute from 4am to 5am. The line to get it to run just once is something like:
            17 4 * * * pm2 restart mm
            That’ll run at 4:17 am only.
              sdetweil @DaveChild
              @DaveChild also need to run the cron task under the user id that created the pm2 task… usually pi
              running under root (default) will fail
