    Issue with setting height as a percentage
    3 Posts 3 Posters 958 Views 3 Watching
    • Z Offline
      zack949
      I am trying to set the height of MMM-EmbedYoutube to 75% but when I do it uses the default 315px as specified in the modules configuration. If I use a 750 as the height it works fine. I can specify width with a percentage, but not height. Any help is appreciated.
      • H Offline
        Hualm @zack949
        @zack949
        @zack949 said in Issue with setting height as a percentage:
        'hey did you find a solution of this problem . I need to fix the same issue
          sdetweil @Hualm
          @Hualm the module is expecting the number of pixels high and wide.
          and hard codes that into the iframe tag properties.
          I don’t know if u can override that w css
          in custom.css
          .MMM-EmbedYoutube iframe {
               height: 75%;
               width: 75%;
