    Magic Mirror Module Development - Powershell embeded
    4 Posts 3 Posters 1.5k Views 3 Watching
    • N
      nkc
      Hi All, How are you.
      Please note I am not a developer, My question is … How can I embed and run a powershell script or code from a Magic Mirror module and return its result to a payload(or data).
      I have a pwershell script which I’d like to convert to a Magic Mirror module and since my background is not too technical , I need help or any suggestions or ideas.
      Thank you.
      Regards.
        sdetweil @nkc
        @nkc so you need the node_helper side of the module to execute the PowerShell script and capture it’s output. then send that output up to the browser side to display
        you can look at/enhance my python print to call PowerShell instead of python
        https://github.com/sdetweil/MMM-PythonPrint
        this runs a python script, captures it’s output and sends it up to the browser side to display.
        mm is all javascript
        • wishmaster270W
          wishmaster270 Module Developer @sdetweil
          @nkc Hi,
          i think you can use my MMM-CommandToNotification module to call the script periodically and send it’s output as a notification.
          You then can use my MMM-ValuesByNotification module to display the value of the notification.
            sdetweil @wishmaster270
            @wishmaster270 I was going to recommend your modules but strayed into notifications , and I think that took him off path
