MMM-Fritz-Box-Callmonitor: Notification formatting
31 Posts 7 Posters 13.0k Views 7 Watching
    Jan 0
    I’m referring to this module (https://github.com/paviro/MMM-FRITZ-Box-Callmonitor). Although it is quite outdated, I still like it and I was able to transfer it to an python3 environment. However, since some update (don’t know which one), the notification (“alert”) is not formatted properly.
    The reason seems to be in line 85 of the file MMM-FRITZ-Box-Callmonitor.js:
    	// Override socket notification handler.
    		if (notification === "call") {
    			//Show alert on UI
    			this.sendNotification("SHOW_ALERT", {
    				title: this.translate("title"),
    				message: "<span style='font-size:" + this.config.numberFontSize.toString() + "px'>" + payload + "<span>",
    				imageFA: "phone"
    			//Set active Alert to current call
    			this.activeAlert = payload;
    There are two problems: 1) the title is not translated but printed, 2) the message is not formatted but the formatting information is printed verbosely.
    Unfortunately, I’m neither an expert in the MagicMirror syntax nor in javascript. Could somebody give me a hint how I need to adopt the code?
    C 2 Replies Last reply Feb 5, 2023, 7:18 AM Reply Quote 0
      coernel @Jan 0
      @Jan-0 Can you please fork the updated module? I also tried to make it run under Python3 but failed.
      I will then install and have a look at the formatting - though I am no expert either I will give my best.
        coernel @Jan 0
        @Jan-0 Please publish your fork and I will have a look at the formatting!
          Jan 0
          Thanks @coernel
          Here is the fork and the development branch: https://github.com/drtorchwood/MMM-FRITZ-Box-Callmonitor-py3/tree/code_update_2023
          C 1 Reply Last reply Feb 7, 2023, 9:22 PM Reply Quote 0
            coernel @Jan 0
            @Jan-0 I will have a look tomorrow!
              coernel
              I tried to install it but the MagicMirror stays blank after that. I noticed that you don’t use a pyhton-3 shebang in your Python file. Could this be the cause? I will try later to add that!
              This is my config:
              			module: 'MMM-FRITZ-Box-Callmonitor-py3',
              			position: 'bottom_left',	// This can be any of the regions. Best results in left or right regions.
              			header: "Verpasste Anrufe", // This is optional
              				username: "foo",
              				password: "bar",
              				reloadContactsInterval: 24*60,
              J 1 Reply Last reply Feb 10, 2023, 8:30 PM Reply Quote 0
                Jan 0 @coernel
                @coernel Perhaps, my renaming of the module is the problem. On my computer, the module is stilled named “MMM-FRITZ-Box-Callmonitor”. I only renamed it for the branch.
                I will check this in the next days.
                Does python3 fritz-access.py -u '<username>' -p '<password>' work?
                S C 2 Replies Last reply Feb 10, 2023, 9:01 PM Reply Quote 0
                  sdetweil @Jan 0
                  @Jan-0 if you rename a module, you have to rename the folder and the filename AND EDIT the file and change it’s register clause w the right name.
                  modulename - folder
                  modulename.js
                  edit modulename.js and change 1 line of code
                    coernel @Jan 0
                    After changing some lines as suggested by sdetweil the MagicMirror loads again.
                    @Jan-0 said in MMM-Fritz-Box-Callmonitor: Notification formatting:
                    python3 fritz-access.py -u ‘’ -p ‘’
                    The filename is fritz_access.py. So after executing it I got
                     print json.dumps({"filename": file, "content": content})
                    SyntaxError: invalid syntax
                    This was easily solded by changing it to print (json.dumps({"filename": file, "content": content})) (Just adding round brackets) - that was a change from Python2 to Python3.
                    However it was followed by the next error urllib2 does not work in Python 3. According to stackoverflow urllib.error and urllib.request must be used for Python3.
                    Are you sure you uploaded the right code to github? It seems you accidentally uploaded th old python2 code!
                    W 1 Reply Last reply Feb 14, 2023, 8:53 PM Reply Quote 0
                    • W Offline
                      wishmaster270 Module Developer @coernel
                      @coernel
                      @Jan-0
                      Additional to the wrong rename the fritz_access.py had the mentioned wrong urllib2 imports. I fixed the python script and the import of the PythonShell module in node_helper.js.
                      I created a pull request a few seconds ago.
                      J C 2 Replies Last reply Feb 15, 2023, 9:15 PM Reply Quote 1
                      • 1 / 4
                      1 / 4
