    Analog + Digital Clock module
    38 Posts 5 Posters 52.7k Views 5 Watching
    • KirAsh4K
      KirAsh4 Moderator
      @Kevin, as a side note, if there’s a particular clock face that you like me to create for you, let me know. If you have an example, that will greatly help.
      • pugslyP
        pugsly
        Works great, just one question. I want to put the analog clock in the top_center and don’t want to show the date because I have the digital clock in the top_right position. How do I turn off the date from showing on a 2nd clock module?
        • KirAsh4K
          KirAsh4 Moderator
          At the moment, it’s hard coded in. I’d have to add a config option so it can be turned off when used as a separate module.
          • KirAsh4K
            KirAsh4 Moderator
            Ok, I have it in my dev branch, but I won’t push it up just yet. I’ll wait a bit to see if there are other things that people will request or fixes. But if you must get rid of it now, you can manually edit the 'clock.js' file and delete line 173:
            169:    } else if (this.config.displayType === 'analog') {
            170:        // Display only an analog clock
            171:        dateWrapper.style.textAlign = "center";
            172:        dateWrapper.style.paddingBottom = "15px";
            173:        wrapper.appendChild(dateWrapper);             <===== that line
            174:        wrapper.appendChild(clockCircle);
            175:    } else {
            It will only affect the analog clock when used as a separate module as a single clock.
            • KirAsh4K
              KirAsh4 Moderator
              I should point out that this is just a temporary thing, so you can get rid of it. The updated code will give you a config option to disable it, show it above, or below the clock.
              • KirAsh4K
                KirAsh4 Moderator
                @pugsly, I forgot to mention this: new code has been added to the 'develop' branch that allows you to turn off the date display when using the module in analog mode only. Options are 'top' (default) to have it displayed at the top of the clock, 'bottom' to show it on the bottom, or 'false' to completely turn it off.
                • T
                  trividar
                  someone know why this happend to me after updating MM:
                  alt text
                  everything looks fine just the analag clock.
                  N 1 Reply Last reply
                  • N
                    nagaculun @trividar
                    @trividar said in Analog + Digital Clock module:
                    alt text
                    Happened to me too. It was fine yesterday.
                    • N
                      nobita @nagaculun
                      @nagaculun you can adjust resize analogSize: “200px”, to smaller ex 150px
                      N T 2 Replies Last reply
                      • N
                        nagaculun @nobita
                        @nobita it works. Thanks
                        • T
                          trividar @nobita
                          @nobita with max. 300px it works, but before the update I had 550px and it works also but no more. Do someone know why?
                          • MichMichM
                            MichMich
                            Should be fixed in the develop branch now: https://github.com/MichMich/MagicMirror/issues/611#issuecomment-272714388
