    Bathroom mirror: "Frameless, thin, gesture and voice controlled"
    16 Posts 10 Posters 19.3k Views 15 Watching
      Johans @Robert_K
      @Robert_K
      Really nice build !!!
      Working on more or less the same mirror concept, but I won’t be able to get it on 3,6 cm, will be somewhere 4,8.
      • bugsounetB
        bugsounet Banned
        Good job ;)
        • O
          OviOne @Robert_K
          @Robert_K Hi how did you waterproof it as you must get a lot of steam in that room with no window, nice mirror though.
          Robert_KR 1 Reply Last reply
          • slametpsS
            slametps
            awesome.
            regards,
            Slamet PS
            • Robert_KR
              Robert_K @OviOne
              @OviOne
              I used Plastidip. This is a rubberish spray which gave a nice seal/coating on all electric circuit boards. I left de RPI open but all others got sprayed with PlastiDip.
              The ventilation is right above the shower, so the mirror doesn’t get that damp actually. It’s nog fogging up like a normal mirror due to two things. Glass is colder than acrilic, and the LCD screen gives a bit of warmt.
              Regards Robert
              O 1 Reply Last reply
              • O
                OberfragGER @Robert_K
                @Robert_K great work! Cool Design.
                2 questions left.
                What are the 3 (same) “devices” below the RPI?
                You forget to mention the light-stripe. Its a regular RGB? how do you control it? Extra device?
                Hint from myself: I used the rest of APA102-5V-Stripes and installed Hyperion in parallel. No extra device needed and animations too. The animations work via Hyperion-App, homebridge and/ or automatisation via ioBroker.
                Very modern (Guest?-) Bathroom too!
                • Robert_KR
                  Robert_K
                  Thank you for the compliment.
                  The 3 “devices” are DC-DC converters. They are adjustable. The screen powerbord suplies 19V DC.
                  The Pi uses 5V, the LED’s uses 5V (but works better on 4V) and the audio bord uses 9V, however I didn’t use them. Both have a great power output (enought amps)
                  The LED’s are WS2801 programable (waterproof) LED’s for which I wrote two python scipts.
                  The Gesture module activates these python scripts.
                  Regards Robert
                    mkloth @Robert_K
                    @Robert_K
                    Hi Robert, that is a really cool mirror. What glass did you use? It looks very sharp and useful as a bathroom mirror ;-).
                    • Robert_KR
                      Robert_K @mkloth
                      @mkloth
                      If I recall correctly, I used this type of mirror:
                      https://plexiglasstunter.nl/plexiglas-xt-plaat-spiegel
                      T 1 Reply Last reply
                      • T
                        Tyfoon @Robert_K
                        @Robert_K Just noticed this project and looks similar to something I want to build (frameless).
                        I see you have used plexiglas, you could also have used real glas (although a bit more expensive like here). Was there a reason other then price to go for plexi? I’m a bit afraid of warping.
                        Now some time further: How does the frame hold to the mirror? No issues with the glue? Did you ever consider using sticky black vinyl instead of the paint? (like this? and then attach the frame to it (I was thinking of using that type of solution).
                        Anything else on the build you would have done different in retrospect?
                        • Robert_KR
                          Robert_K @Tyfoon
                          @Tyfoon
                          Goodmorning,
                          Hardware wise I have not a single issue. There is absolutly no warping in the plexiglass.
                          I choose plexiglass because that’s what I can get hold of easiliy. And with a industrial lasercutter at hand it’s easy to build products with plexi.
                          Things I would have don differently would only be software. The Google / Hotword is realy sensitive, and Google is gimmick but not really usefull. So I wouldn’t install it in a next version. It’s only to showoff but we’re not using it on a regular day. Besides that, it slows the mirror and internet connection down a lot. (but this could be a fault in my software)
                          Regards Robert
