Unsolved NowPlayingOnSpotify authentication error
@MadeInMaine no, clearly something you are doing
Do you know why it would say “site can’t be reached” when doing http://localhost:8888 ?
I tried to go to proxy settings, but couldn’t change anything
@MadeInMaine there are two choices
you are doing that on a browser on a machine different than where MagicMirror is installed
you didn’t start the auth app per the documentation, before you tried to connect to it, from a browser on the same system
For #2, I’ll start over from scratch, maybe that will help.
For #1, i am using the browser that that opens from the status bar on the RaspberryPi, chromium.
Can i use the electron browser? If so, and if I should be using that, where do I find it on the rapsberryPi?Thank you again
@MadeInMaine you don’t need to try to use electron.
when you start the auth app you should see
Listening on 8888
@MadeInMaine the authorization app prints that message to the console.
no ‘meaning’ , does it appear?
No
@MadeInMaine so you did
from the module folder
cd authorization node app
to start the auth app… right?
per the instructions
