    Factory Reset button
    9 Posts 5 Posters 2.0k Views 5 Watching
    • K Offline
      kpl4184
      Magic Mirror beginner here, has anyone tried to install a factory reset button externally using the GPIO pins? Any idea how to do this? Is there a module that would work for this application? Any input would be appreciated.
        sdetweil @kpl4184
        @kpl4184 what do you mean ‘factory reset’?
        machine is a PI, with its own OS and config
        MM is an app, with its own os (node js) config
        what do you want to reset, and why?
        thgmirrorT 1 Reply Last reply Reply Quote 0
        • K Offline
          kpl4184
          Currently have a Magic Mirror running with basic modules. Still tinkering with fonts and layouts. Because it is installed in a frame on the wall. The factory reset button would allow for me to easily start over from were I left off. Instead of a complete de-install if a crash happens during configuration modifications. As a fell safe, if you will. It sounded like a good idea at the time.
          • thgmirrorT Online
            thgmirror @sdetweil
            @kpl4184
            You can add
            dtoverlay=gpio-shutdown,gpio_pin=3, active_low=1,gpio_pull=up
            in the /boot/config.txt
            Connect a pushbutton with gpio 3 and GND
            …one push will shutdown the RPI, a second will restart it.
            …and use it on your own risk:-)
            • K Offline
              kpl4184
              OK, thanks. I’ll give it a go. Stay tuned.
              • JalibuJ Offline
                Jalibu Module Developer
                Or you can just unplug it and plug it back in again :-D :detective:
                • thgmirrorT Online
                  thgmirror @Jalibu
                  @kpl4184 …or use the app Raspcontroller to manage your PI.
                    sdetweil @kpl4184
                    @kpl4184 if you make backups of the two key files, recovery is easy
                    config.js and custom.css
                    never edit any files in the module folders
                    • T Offline
                      Thierry7100 @kpl4184
                      @kpl4184
                      Hi, I have a small module which restart the mirror with a short press or shutdown the RPi with a long press.
                      I use this module on my own mirror.
                      The code could be found here : https://github.com/thierry7100/Reset_Py
