    MMM-Growatt
    26 Posts 3 Posters 8.0k Views 5 Watching
    • mumblebajM Online
      mumblebaj Module Developer
      MMM-Growatt
      Module that displays data from your Growatt Inverter.
      Module Dependencies:
      • growatt v0.3.0
      • Requires an account on server.growatt.com
      Module Config:
                 module: "MMM-Growatt",
                 position: "middle_center", //Works best at middle_center. May not display all that well in other positions
                 disabled: false,
                     username: "username",
                     password: "password",
                     plantId: "plantId", // Can be obtained from the Growatt site by checking your Plant information. This can be accessed from the left side of the screen
                     updateInterval: 1000*60*30 ,//Update every 30 minutes
                     deviceSerial: "deviceSerial" //This is the device serial number. Can be found under Input Search Number.
      Installation Steps:
      cd ~/MagicMirror/modules
      git clone https://github.com/mumblebaj/MMM-Growatt.git
      cd MMM-Growatt
      npm install
      For any issues please open an issue on the module Github Issues page
      A mumblebajM N 5 Replies Last reply Reply Quote 5
        andersfalt @mumblebaj
        @mumblebaj I am just getting a blank screen. I have added all the information in the config file but nothing is showing up. Can you please help me?
        • mumblebajM Online
          mumblebaj Module Developer @andersfalt
          @andersfalt Good evening. I just replied on Github Issue. Please check there and advise.
          • mumblebajM Online
            mumblebaj Module Developer @mumblebaj
            @mumblebaj
            Changes
            Updated module to no longer require user to specify plantId and deviceSerial. The values will be automatically obtained.
            Future updates
            Investigate adding multiple device support.
            • mumblebajM Online
              Update v2.0.0
              • Module updated to cater for different Growatt Inverter Types.
                Different Growatt Inveters models return different datasets. The update now caters for some of the models. Models catered for is storage, tlx and tlxh. Others can be added as and when required. Log an issue on the modules github issues.
              • npm module growatt updated to v0.5.6
                Updated the npmjs module growatt to the latest version which caters for the different inverter types.
              • plantId and deviceSerrial no longer required as part of the module config.
              • New Config would look like the below
                         disabled: false,
              New Module Created for Totals
              Created a new module, MMM-Growatt-Stats which now displays only totals.
              You can run both modules at the same time if required. Just follow the installation and or upgrade steps in both modules.
              • mumblebajM Online
                Update v2.0.1 = 2023/08/31
                • Had a request from user ruralbrewer to add support for https://server-us.growatt.com.
                • Users in the US registered on the US Growatt Server are now able to use the module.
                • A new Config option usServer: true must be added to the config/config.js. Users registered on the https://server.growatt.com need not add this option.
                            disabled: false,
                                usServer: true, // only used by US Registered users
                                debug: false, // set to true if you want to create a debug log
                                mode: "dual", // Specify 'dual' when running https://github.com/mumblebaj/MMM-Growatt.git and https://github.com/mumblebaj/MMM-Growatt-Stats.git together else specify 'single'
                                updateInterval: 1000*60*30 //Update every 30 minutes
                • mumblebajM Online
                  @mumblebaj There were changes to Growatt API and the current version of the module has stopped working throwing errors.
                  Please update to the latest version of the module, v2.0.5 which now works,
                  BM
                  • N Offline
                    nowayto @mumblebaj
                    @mumblebaj Hello, can I ask you if there is a way to change module appearance?
                    I like your graphics but I need to run it on a small display, so I wanna ask you if there is a way to have a simplified text+number visualization or if I can get rid of battery power, because I don’t own it.
                    Your other module “MMM- GrowattStats” could be good for me, but only if I can get rid of “charged” and “discharged” icons.
                    A sort of Triangle with “solar” “imported” “load” will be perfect for me.
                    Thank you a lot for your nice work
                    • mumblebajM Online
                      mumblebaj Module Developer @nowayto
                      @nowayto Hi. As it stands it is probably not possible. Am I right that you are looking for a scaled down version? There is another MMM-Growatt module out there that does that. You can check it out. I can build a smaller version that would give a similar tabular view but will take some time.
                      • N Offline
                        nowayto @mumblebaj
                        @mumblebaj I tried Dekinets’s one but it doesn’t work. login issues, screen stay without infos.
                        [LOG] Error: The server sent an unexpected response: /error.do?errorMess=errorNoLogin
                        at /home/MIRASPNAME/MagicMirror/modules/MMM-Growatt/node_modules/growatt/lib/growatt.js:302:22
                        at process.processTicksAndRejections (node:internal/process/task_queues:95:5)
                        He told me to try an API update and I’ll do it when I have 1 minute
                        In the past I tried your module and it worked, but I need a simple visualization and honestly I don’t wanna bother you for a new build.
                        Thank you a lot
                        mumblebajM 2 Replies Last reply Reply Quote 0
