    Mirror showing not all modules on all devices
    14 Posts 3 Posters 9.5k Views 3 Watching
      sangroma
      @sdetweil thank you!
      very strange.
      after
      Load script: modules/default/weather/weather.js
      i get the following error
      Uncaught SyntaxError: Unexpected token .
        sangroma
        Hmmm… on load up after the weather.js the foowing error occure only on the raspi. On all other clients i can call the script without errors
        Load script: modules/default/weather/weatger.js
          sdetweil @sangroma
          @sangroma what version of node do you have installed,
          node -v
          but electron should have the right node version
          what browser are you using?
          the error is that the nodejs version is downlevel, not supporting the es6 idioms we are using
            sangroma
            currently running v16.19.0 of node
            browser is chromium latest version 72.0.3626.121
            Just installed latest version of firefox. Same issue
              sdetweil @sangroma
              @sangroma on the error line, what is the line number next to the name. weather.js:xxx
              what os version are u running?
              lsb_release -a
              uname -a
                sangroma @sdetweil
                weather.js:159
                device where the magic mirror docker container is running on
                Linux nas 6.0.0-0.deb11.6-amd64 #1 SMP PREEMPT_DYNAMIC Debian 6.0.12-1~bpo11+1 (2022-12-19) x86_64 GNU/Linux
                device on which i am trying to call the mirror via chromium
                Linux raspberrypi 4.19.66-v7+ #1253 SMP Thu Aug 15 11:49:46 BST 2019 armv7l GNU/Linux
                  sdetweil @sangroma
                  @sangroma what version of MagicMirror are you running
                  line 159 is empty in the latest release
                    sangroma @sdetweil
                    magicmirror:v2.21.0
                    i dont know why, but in your file it is line 165
                      sdetweil @sangroma
                      @sangroma yes. that is one of the new es6 idioms. ?., the chaining operator
                      on
                      https://developer.mozilla.org/en-US/docs/Web/JavaScript/Reference/Operators/Optional_chaining
                      chrome needs version 80, u have only v 72
                        sangroma
                        @sdetweil Oh wow. Many thanks!!
                        Will do this.
                        Topic can be closed
                        • KristjanESPERANTOK Offline
                          KristjanESPERANTO Module Developer @sangroma
                          @sangroma Out of curiosity: How come you used a browser version from 4 years ago?
                            sangroma @KristjanESPERANTO
                            @KristjanESPERANTO as far as i remember i installed some kind of raspbian light version because i dont need much on the device. just wanted to show the internal webpage of the docker.
                            as it got deprecated i couldnt update to a higher version. need to set up a complete fresh OS :D
