    ChatGpt developed Module MMM-Dockerstat
    27 Posts 4 Posters 10.3k Views 4 Watching
      Rags @mumblebaj
      @mumblebaj {
      module: ‘MMM-Dockerstat’,
      header: ‘Docker Status’,
      position: ‘top_right’,
      host: ‘192.168.1.200’, // IP address of the second Pi running Docker
      interval: 600000, //60 seconds
      user:‘pi’,
      password:‘mypass’,
      container: ‘wireguard’, // just added to check
      offlineIcon: ‘fa-times-circle’, // Font Awesome icon for offline status
      onlineIcon: ‘fa-check-circle’ // Font Awesome icon for online status
      Yes i added the name of the container. It is still not displaying the status. Anyways the idea was for the module to probe and display the status of all containers running in docker.
        Rags @sdetweil
        @sdetweil said in ChatGpt developed Module MMM-Dockerstat:
        @mumblebaj can u see the container names from inside a container?
        ‘Docker ps’ command list all the containers that are currently running. So i guess the command will execute and should be able to confirm the status with the command
        " ‘.exec(sudo docker ps -f name=${payload.container} --format "{{.Names}} {{.Status}}")’"
        This command uses the Docker CLI (Command Line Interface) to list the running Docker containers on a host, filtering the results by the name of the container specified in payload.container. The --format option specifies how to format the output of the docker ps command. In this case, {{.Names}} {{.Status}} is used to output only the names and statuses of the containers that match the specified filter. The output is then captured and processed by the SSH library used in the code.
        anyways " work in progress ".
        • mumblebajM
          mumblebaj Module Developer @Rags
          @Rags The output from the query does not return a Status of “Online”
          See below what it returns.
            Rags @mumblebaj
            @mumblebaj said in ChatGpt developed Module MMM-Dockerstat:
            Yes you are right even i got a similar output when the command was run on the second pi directly. So at least we are getting somewhere. Good news.
            sudo docker ps -f name=wireguard --format “{{.Names}} {{.Status}}”
            wireguard Up 36 hours.
            so now i have to figure out a command line to get status of all containers in a table form with name of container and the uptime.
            S mumblebajM 2 Replies Last reply Reply Quote 0
              sdetweil @Rags
              @Rags but are you running this on the docker host? outside any container?
              if u run this from INSIDE the container (where MM is running) , does it work?
              as I recall, it does not.
              I think the command (on the host) is
              Usage:  docker exec [OPTIONS] CONTAINER COMMAND [ARG...]
              docker exec container_id “docker -ps … rest of parms”
              but you will have to use docker command to get the container_id from the name to use in the exec
              long time ago, 9 years now, I wrote a whole bunch of scripts to support using docker to deploy and manage a software api testing service…
              • mumblebajM
                @Rags you can drop the -f name portion which will then list all containers running. Maybe change the query to something like the following which should give you some JSON type object which you can then work with.
                docker ps --format '{"ID":"{{ .ID }}", "Image": "{{ .Image }}", "Names":"{{ .Names }}, "Status": {{.Status}}"}'
                This will return something like the below:
                {"ID":"4c57d2ba3fd8", "Image": "getting-started", "Names":"silly_hodgkin, "Status": Up 44 minutes"}
                From this you can then extract the container you want and check the status. What I have seen the query only returns all running containers
                  sdetweil @mumblebaj
                  @mumblebaj but you don’t need to do all that fancy formatting if you are going to extract the info
                  awk can do that
                  11e836525b8d   jshridha/blueiris   "/usr/bin/supervisord"   2 years ago   Up 8 months   0.0.0.0:82->81/tcp, :::82->81/tcp, 0.0.0.0:5901->5900/tcp, :::5901->5900/tcp, 0.0.0.0:8280->8080/tcp, :::8280->8080/tcp   blueiris
                  (base) sam@sams:~/MagicMirror/config$
                  docker ps | awk ‘{print $1}’
                  awk can split a string into parts (using some separator char (-F parm, space is default) and then u can print out just the parm u want
                  also docker ps -q
                  only displays the container ids.
                  • mumblebajM
                    @sdetweil Thanks Sam. I just installed Docker for the first time earlier and also learning. :-) Looks fun though. I was looking jq but can’t get that to work, How do i install jq on Docker? Or get it to work off the command line?
                      sdetweil @mumblebaj
                      @mumblebaj sorry, no idea on jq
                      i use terminal commands all the time… jq only in nodejs
                      when I have a terminal command i need output of, I use terminal command tools.
                      the thing about docker is you can make an image of a ‘thing’ you want to run, and run it everywhere that supports that processor type. independent of OS and you can run multiple instance at the same time (scale up server?) without changing anything inside the image
                      start up a web server with this content (mapped source folder)
                      or that content , or both poof a docker command and up you go.
                      getting the folders mapped to the right place for the ‘thing’ in the container takes a little (tiny amount) work
                        Rags @sdetweil
                        Sorry if i have not been clear. My MagicMirror is in the living room. The MM is running on the first pi( standalone ) not in any container. The second pi in my network is tucked away in my study. This machine is installed with Docker containing multiple containers, which include pihole, wireguard, nginx, apache etc. Occasionally, one or two containers would quit running and I would realise quite late that a particular service is down. That’s why i was trying to build this module so that the status of all containers are known in a jiffy on the MM display.
                        So when the MM docker module probes the second pi it should just ssh into it and retrieve the docker status easily, format the info in an array and display it. Simple (apparently ).
                        S karsten13K 2 Replies Last reply Reply Quote 0
                          sdetweil @Rags
                          @Rags got it…
                          ssh will be the fun part (I think!)
                          • karsten13K
                            karsten13 @Rags
                            @Rags said in ChatGpt developed Module MMM-Dockerstat:
                            then docker ps --format "{{.Names}} {{.State}}" maybe is the better choice, State can be one of the following: (created|restarting|running|removing|paused|exited|dead)
                              Rags @karsten13
                              @karsten13 said in ChatGpt developed Module MMM-Dockerstat:
                              should this command produce an output when run directly on the docker machine? I am not getting any output.!
                              Docker ps -a gives this output listing all containers whether up or exited. I need to just pickup name and status
                              Now just need to workout (as Sam says ‘the fun part’) ssh into second pi retrieve the docker ps -a and display.
                              • karsten13K
                                karsten13 @Rags
                                @Rags
                                missed the -a
                                ❯ docker ps -a --format "{{.Names}} {{.State}}"
                                magicmirror running
                                watchtower running
                                traefik running
                                  Rags @karsten13
                                  @Rags
                                  missed the -a
                                  magicmirror running
                                  watchtower running
                                  traefik running
                                  Great !
                                  Yes the command is working now but locally on the docker machine only. It needs to work from the first machine after ssh ing into docker machine.
                                  ssh
                                  .exec (‘docker ps -a --format “{{.Names}} {{.State}}”’)
                                  .on(‘error’, (err) => {
                                  console.error(Error: ${err});
                                  this.status = ‘Error’;
                                  this.sendSocketNotification(‘STATUS_UPDATE’, { status: this.status, icon: this.offlineIcon });
