    MMM-CalendarExt3 month header and current date format
    8 Posts 4 Posters 2.9k Views 4 Watching
      jdcpuwiz
      I am new to MM and I am trying to get things styled the way I want. I am trying to make some changes using custom.css but there are a couple options I cannot seem to track down. I want to change the month name title on month view. Here is what I have right now, however it does not seem to be working.
      for the month title in custom.css
      .CX3 .title {
      color: rgba(255,255,255,1);
      font-family: “Verdana”, “sans-serif”;
      font-size: 20px;
      I also want to change the way the current day displays the date. I want it to display the same format as the rest of the dates in month view. ie: April 1st is displayed as 4/1/2023. The rest of the days display just 2, 3 ,4, etc.
      Can anyone help with this?
      M 1 Reply Last reply
        MMRIZE
        @jdcpuwiz
        Or what you want to display is just numeric day only,
        just set configuration like this;
        cellDateOptions: {day: 'numeric'},
        J R 3 Replies Last reply
          MMRIZE @jdcpuwiz
          @jdcpuwiz
          1.
          You mean this? (ABRIL in the picture)
          .MMM-CalendarExt3 .module-header {
            color: gold;
            font-family: "Verdana", "sans-serif";
            font-size: 20px;
            font-weight: bold;
          1. For your second question;
            What you want is to show same? or different?
            Each .cellDate has parts to control displaying.
            For example;
            These two days (Apr 3 and 4) have same HTML structure like this;
          <div class="cellDate">
            <span class="dateParts month seq_0">Apr</span>
            <span class="dateParts literal seq_1"> </span>
            <span class="dateParts day seq_2">4</span>
          </div>
          And then, they are controlled by CSS.
          .CX3 .cellDate :not(.day) {
            display: none;
          } /* Hide all parts not `.day`... (i.e: `month` or `year` or any `literal` marks)*/
          .CX3 .today .cellDate :not(.day) {
            display: inline-block;
          } /* But in `.today` cell, show all the parts. */
          .CX3 .date_1 .cellDate :not(.day) {
          } /* and in `.date_1` (first day) of the month */
          So you can override CSS as you want in your custom.css
            MMRIZE
            @jdcpuwiz
              jdcpuwiz @MMRIZE
              @MMRIZE Thanks for the help, I am going to give this a try and get back to you.
                jdcpuwiz @MMRIZE
                @MMRIZE That worked perfectly. Thank you so much!
                  reverendz @MMRIZE
                  @MMRIZE said in MMM-CalendarExt3 month header and current date format:
                  cellDateOptions: {day: ‘numeric’},
                  This works great! Is there any way I can keep this bit:
                  } /* and in .date_1 (first day) of the month */
                  But not show the same information in today?
                  Or, is there a way to put a red circle around the numeric bit of the date?
                  plainbrokeP 1 Reply Last reply
                  • plainbrokeP
                    plainbroke @reverendz
                    @reverendz
                    @MMRIZE
                    Following I would like to Circle the current date also.
                    Would make it easier to find todays date for me I tend to loose track of date.
                      MMRIZE @plainbroke
                      @plainbroke @reverendz
                      Instead of .date_xx, use .today to point today’s cell.
                      And about the circle; https://forum.magicmirror.builders/topic/18324/mmm-calendarext3-show-color/11?_=1736098133616
