    MMM-DarkSkyForecast
    4 Posts 4 Posters 1.2k Views 4 Watching
      MiPraSo
      I have updated to 2.23.0.
      Now I have a problem with MMM-DarkSkyForecast, which was still working before the update. At the moment nothing is displayed anymore, except loading…
      The log file tells me:
      <!DOCTYPE "... is not valid JSON
          at JSON.parse (<anonymous>)
          at Request._callback (/home/pi/MagicMirror/modules/MMM-DarkSkyForecast/node_helper.js:57:29)
          at self.callback (/home/pi/MagicMirror/modules/MMM-DarkSkyForecast/node_modules/request/request.js:185:22)
          at Request.emit (node:events:513:28)
          at Request.<anonymous> (/home/pi/MagicMirror/modules/MMM-DarkSkyForecast/node_modules/request/request.js:1154:10)
          at IncomingMessage.<anonymous> (/home/pi/MagicMirror/modules/MMM-DarkSkyForecast/node_modules/request/request.js:1076:12)
          at Object.onceWrapper (node:events:627:28)
          at IncomingMessage.emit (node:events:525:35)
          at endReadableNT (node:internal/streams/readable:1358:12)
          at process.processTicksAndRejections (node:internal/process/task_queues:83:21)
      [06.04.2023 10:45.14.538] [ERROR] MagicMirror² will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [06.04.2023 10:45.14.540] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [06.04.2023 10:55.11.221] [ERROR] Whoops! There was an uncaught exception...
      [06.04.2023 10:55.11.224] [ERROR] SyntaxError: Unexpected token '<', "
      I have carried out a new update of MMM-DarkSkyForecast, unfortunately without success.
      Can anyone help me?
      • karsten13K
        karsten13 @sdetweil
        dark sky api was switched off on March 31st, 2023
        swvalentiS 1 Reply Last reply Reply Quote 0
          sdetweil @MiPraSo
          @MiPraSo i do not know, as there is some missing info
          edit the module node_helper.js
          and change this code
                  // console.log("[MMM-DarkSkyForecast] Getting data: " + url);
                  request({url: url, method: "GET"}, function( error, response, body) {
                    if(!error && response.statusCode == 200) {
                      //Good response
                      var resp = JSON.parse(body);
                      resp.instanceId = payload.instanceId;
                      self.sendSocketNotification("DARK_SKY_FORECAST_DATA", resp);
                    } else {
                      console.log( "[MMM-DarkSkyForecast] " + moment().format("D-MMM-YY HH:mm") + " ** ERROR ** " + error );
          to look like this
          (just copy/paste after selecting or deleting the old code above)
                    if(!error){
                      if(response.statusCode == 200) {
                        //Good response
                      else {
                        console.log( "[MMM-DarkSkyForecast] " + moment().format("D-MMM-YY HH:mm") + " ** unexpected response code ** " + response.statusCode + " data="+body );
                    } else {
          then run mm again so we can see what the api is complaining about
          • karsten13K
            karsten13 @sdetweil
            • swvalentiS
              swvalenti Project Sponsor @karsten13
              https://github.com/jclarke0000/MMM-OpenWeatherForecast
