    PM2 beendet und startet MM andauernd nach Update
    5 Posts 2 Posters 1.2k Views 2 Watching
      Guten Morgen, mein MM funktioniert nachdem Update nicht mehr richtig.
      Es wird automatisch beendet und neugestartet von pm2.
      Hier der PM2 LOG:
      0|mm     | > magicmirror@2.23.0 start
      0|mm     | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      0|mm     | [15.04.2023 11:09.43.757] [LOG]   Starting MagicMirror: v2.23.0
      0|mm     | [15.04.2023 11:09.43.773] [LOG]   Loading config ...
      0|mm     | [15.04.2023 11:09.43.781] [DEBUG] config template file not exists, no envsubst
      0|mm     | [15.04.2023 11:09.43.793] [LOG]   Loading module helpers ...
      0|mm     | [15.04.2023 11:09.43.836] [LOG]   Initializing new module helper ...
      0|mm     | [15.04.2023 11:09.43.839] [LOG]   Module helper loaded: updatenotification
      0|mm     | [15.04.2023 11:09.43.841] [LOG]   No helper found for module: clock.
      0|mm     | [15.04.2023 11:09.43.850] [LOG]   Initializing new module helper ...
      0|mm     | [15.04.2023 11:09.43.852] [LOG]   Check MagicMirror² version for node helper 'MMM-Fuel' - Minimum version: 2.15.0 - Current version: 2.23.0
      0|mm     | [15.04.2023 11:09.43.856] [LOG]   Version is ok!
      0|mm     | [15.04.2023 11:09.43.859] [LOG]   Module helper loaded: MMM-Fuel
      0|mm     | [15.04.2023 11:09.44.347] [LOG]   Initializing new module helper ...
      0|mm     | [15.04.2023 11:09.44.349] [LOG]   Module helper loaded: calendar
      0|mm     | [15.04.2023 11:09.44.350] [LOG]   No helper found for module: compliments.
      0|mm     | [15.04.2023 11:09.44.353] [LOG]   No helper found for module: weather.
      0|mm     | [15.04.2023 11:09.44.358] [LOG]   Initializing new module helper ...
      0|mm     | [15.04.2023 11:09.44.359] [LOG]   Module helper loaded: MMM-DWD-WarnWeather
      0|mm     | [15.04.2023 11:09.45.297] [LOG]   Initializing new module helper ...
      0|mm     | [15.04.2023 11:09.45.302] [LOG]   Module helper loaded: MMM-Jast
      0|mm     | [15.04.2023 11:09.45.304] [LOG]   All module helpers loaded.
      0|mm     | [15.04.2023 11:09.45.332] [LOG]   Starting server on port 8080 ...
      0|mm     | [15.04.2023 11:09.45.871] [LOG]   Server started ...
      0|mm     | [15.04.2023 11:09.45.876] [LOG]   Connecting socket for: updatenotification
      0|mm     | [15.04.2023 11:09.45.878] [LOG]   Starting module helper: updatenotification
      0|mm     | [15.04.2023 11:09.45.879] [LOG]   Connecting socket for: MMM-Fuel
      0|mm     | [15.04.2023 11:09.45.880] [LOG]   Starting module helper: MMM-Fuel
      0|mm     | [15.04.2023 11:09.45.882] [LOG]   Connecting socket for: calendar
      0|mm     | [15.04.2023 11:09.45.884] [LOG]   Starting node helper for: calendar
      0|mm     | [15.04.2023 11:09.45.885] [LOG]   Connecting socket for: MMM-DWD-WarnWeather
      0|mm     | [15.04.2023 11:09.45.887] [LOG]   MMM-DWD-WarnWeather helper started...
      0|mm     | [15.04.2023 11:09.45.890] [LOG]   Connecting socket for: MMM-Jast
      0|mm     | [15.04.2023 11:09.45.892] [LOG]   MMM-Jast helper method started...
      0|mm     | [15.04.2023 11:09.45.894] [LOG]   Sockets connected & modules started ...
      0|mm     | [15.04.2023 11:09.46.027] [LOG]   Launching application.
      0|mm     | [15654:0415/110946.854883:ERROR:viz_main_impl.cc(186)] Exiting GPU process due to errors during initialization
      0|mm     | [15689:0415/110947.076938:ERROR:gpu_memory_buffer_support_x11.cc(44)] dri3 extension not supported.
      0|mm     | [15662:0415/110947.157042:ERROR:command_buffer_proxy_impl.cc(128)] ContextResult::kTransientFailure: Failed to send GpuControl.CreateCommandBuffer.
      0|mm     | [15.04.2023 11:09.50.379] [LOG]   Create new calendarfetcher for url: https://calendar.google.com/calendar/ical/ZEICHENFOLGEgroup.calendar.google.com/private-ZEICHENFOLGE/basic.ics - Interval: 300000
      0|mm     | [15.04.2023 11:09.53.215] [WARN]  MMM-Fuel: Filtered stationIds list is empty
      0|mm     | [15.04.2023 11:09.55.354] [INFO]  Calendar-Fetcher: Broadcasting 134 events.
      0|mm     | [15.04.2023 11:09.55.570] [INFO]  Checking git for module: MMM-Fuel
      0|mm     | [15.04.2023 11:09.55.666] [INFO]  Checking git for module: MMM-DWD-WarnWeather
      0|mm     | [15.04.2023 11:09.55.727] [INFO]  Checking git for module: MMM-Jast
      0|mm     | [15.04.2023 11:09.55.782] [INFO]  Checking git for module: MagicMirror
      PM2      | pm2 has been killed by signal, dumping process list before exit...
      PM2      | Deleting process 0
      PM2      | Stopping app:mm id:0
      0|mm     | [15.04.2023 11:11.04.768] [LOG]   Shutting down server...
      0|mm     | [15.04.2023 11:11.04.772] [LOG]   Stopping module helper: updatenotification
      0|mm     | [15.04.2023 11:11.04.773] [LOG]   Stopping module helper: MMM-Fuel
      0|mm     | [15.04.2023 11:11.04.774] [LOG]   Stopping module helper: calendar
      0|mm     | [15.04.2023 11:11.04.776] [LOG]   Stopping module helper: MMM-DWD-WarnWeather
      0|mm     | [15.04.2023 11:11.04.777] [LOG]   Stopping module helper: MMM-Jast
      0|mm     | [15.04.2023 11:11.04.779] [LOG]   Node_helpers stopped ...
      PM2      | App [mm:0] exited with code [0] via signal [SIGTERM]
      0|mm     | [15620:0415/111104.849464:ERROR:zygote_communication_linux.cc(291)] Failed to send GetTerminationStatus message to zygote
      0|mm     | [15620:0415/111104.871342:ERROR:network_service_instance_impl.cc(521)] Network service crashed, restarting service.
      0|mm     | [15620:0415/111104.886158:ERROR:zygote_communication_linux.cc(291)] Failed to send GetTerminationStatus message to zygote
      0|mm     | [15620:0415/111104.897434:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
      0|mm     | [15620:0415/111104.905143:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
      0|mm     | [15620:0415/111104.910341:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
      0|mm     | [15620:0415/111104.917887:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
      0|mm     | [15620:0415/111104.922896:ERROR:gpu_process_host.cc(985)] GPU process launch failed: error_code=1002
      PM2      | pid=15596 msg=process killed
      PM2      | Exited peacefully
      Hat jemand zufällig eine Idee was los ist??
        sdetweil @35110
        @35110 how did u update mm?
        can u provide output of
        node -v
        npm -v
        3 1 Reply Last reply Reply Quote 0
          35110 @sdetweil
          NODE v16.19.0
          NPM v 8.19.3
          Update via Script
          bash -c  "$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)" force
            sdetweil @35110
            @35110 can u email me the ~/MagicMirror/installers/upgrade.log
            same userid at gmail
              Ich hab jetzt den Raspberry komplett neu aufgesetzt und MM neu installiert - jetzt geht es wieder
