Unsolved First start from the mirror does not work
I have not in the folder modules I 've added the left so !
I can make it wenistens indicating to me and does not remain black : O -
@samydp I had this problem when I first installed it. It was a module problem for me. Can you comment out all of the modules from config.js except alert and see if if gives you the same error. If not, start enabling the modules one by one until you figure out which is the problem.
-Luke
how exactly do you mean? !
I would now delete all modules except the komentare . or how to do it ?
and thank you !!! -
Update:
can you show me how the modules in the config investing so that the screen indicating?:o -
@samydp, rename your
config.js
toconfig.js.old
and make this your newconfig.js
. Try running the program with this, if you see compliments on the bottom screen, you know that magicmirror works fine and the problem is in one of the other modules. It’s a place to start. If you’re still getting the electron errors, try rerunning npm install again in your MagicMirror directory.
var config = { port: 8080, language: 'en', timeFormat: 24, units: 'metric', modules: [ { module: 'alert', }, { module: 'compliments', position: 'lower_third' } ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== 'undefined') {module.exports = config;}
your config works !!! juhu thx but i have a other wrong :/
i will the language from the clock in germany
Module.register("clock",{ // Module config defaults. defaults: { timeFormat: config.timeFormat, displaySeconds: true, showPeriod: true, showPeriodUpper: false, clockBold: true }, // Define required scripts. getScripts: function() { return ["moment.js"]; }, // Define start sequence. start: function() { Log.info("Starting module: " + this.name); // Schedule update interval. var self = this; setInterval(function() { self.updateDom(); }, 1000); // Set locale. moment.locale(config.language); },
Note from Moderator: Please use proper Markdown on code snippets for easier reading.
@samydp all you should have to do is change the language portion of your
config.js
from
language: 'en',
->language: 'de',
As for the rest of your modules, I recommend adding them one by one to your
config.js
file to make sure they work. If you get that electron.js error, it was on the module you just added.-Luke
Many thanks for your help and your tip! but only tow module works =( the clock an the compliments why this ?
Whenever I will add another module of the screen black!
i have install the electron.js again but
the add the module as in the proceeds described readme does not work ! -
Beats me, did you run npm install in the MagicMirror folder?
yes i have install the npm in the MM Folder , only compliment, clock and news works other moduls come a error ( no config file )
