    First start from the mirror does not work
    36 Posts 6 Posters 31.7k Views 4 Watching
      paviro @samydp
      @samydp you do not need any modules. Did you add anything to the modules folder?
      – The Doctor
        samydp
        I have not in the folder modules I 've added the left so !
        I can make it wenistens indicating to me and does not remain black : O
          mochman Module Developer
          @samydp I had this problem when I first installed it. It was a module problem for me. Can you comment out all of the modules from config.js except alert and see if if gives you the same error. If not, start enabling the modules one by one until you figure out which is the problem.
          -Luke
            samydp
            how exactly do you mean? !
            I would now delete all modules except the komentare . or how to do it ?
            and thank you !!!
              samydp
              Update:
              can you show me how the modules in the config investing so that the screen indicating?:o
                @samydp, rename your config.js to config.js.old and make this your new config.js. Try running the program with this, if you see compliments on the bottom screen, you know that magicmirror works fine and the problem is in one of the other modules. It’s a place to start. If you’re still getting the electron errors, try rerunning npm install again in your MagicMirror directory.
                var config = {
                	port: 8080,
                	language: 'en',
                	timeFormat: 24,
                	units: 'metric',
                			module: 'alert',
                			module: 'compliments',
                			position: 'lower_third'
                  samydp
                  your config works !!! juhu thx but i have a other wrong :/
                  i will the language from the clock in germany
                  Module.register("clock",{
                  	// Module config defaults.
                  	defaults: {
                  		timeFormat: config.timeFormat,
                  		displaySeconds: true,
                  		showPeriod: true,
                  		showPeriodUpper: false,
                  		clockBold: true
                  	// Define required scripts.
                  	getScripts: function() {
                  		return ["moment.js"];
                  	// Define start sequence.
                  	start: function() {
                  		// Schedule update interval.
                  		var self = this;
                  		setInterval(function() {
                  			self.updateDom();
                  		}, 1000);
                  		// Set locale.
                  		moment.locale(config.language);
                  Note from Moderator: Please use proper Markdown on code snippets for easier reading.
                    @samydp all you should have to do is change the language portion of your config.js from
                    language: 'en', -> language: 'de',
                    As for the rest of your modules, I recommend adding them one by one to your config.js file to make sure they work. If you get that electron.js error, it was on the module you just added.
                    -Luke
                      samydp
                      Many thanks for your help and your tip! but only tow module works =( the clock an the compliments why this ?
                      Whenever I will add another module of the screen black!
                      i have install the electron.js again but
                      the add the module as in the proceeds described readme does not work !
                        Beats me, did you run npm install in the MagicMirror folder?
                          samydp
                          yes i have install the npm in the MM Folder , only compliment, clock and news works other moduls come a error ( no config file )
                          • E
                            EoF
                            Hi I am having this same issue. Did you ever get it working?
                            • MichMichM
                              MichMich
                              Maybe I’m missing something here, but it seems you try to run npm start from a remote shell. That does not work since it doesn’t know on which screen to start. Try: DISPLAY=:0 npm start
                              E 1 Reply Last reply
                              • E
                                EoF @MichMich
                                @MichMich Hi! I am running npm start directly on the pi, and I get the same exact error.
                                • E
                                  EoF
                                  As an update to my situation, I was able to get mine working by installing electron dependencies.
                                  sudo apt-get install libgtk2.0-0 libnotify4 libgconf2-4 libnss3
                                  I am running a pi 3 with Jessie by the way.
                                  FYI @MichMich @paviro
                                  • K
                                    KirAsh4 Moderator
                                    Interesting as I didn’t have to do that as a separate step. However, as I posted in a different thread yesterday, keeping the base software on your Raspberry Pi is important.
                                      paviro
                                      Mhh maybe we should add those dependencies and/or apt-get upgrade to the installer script?
                                      – The Doctor
                                      • K
                                        KirAsh4 Moderator
                                        I vote no because that’s outside the scope of MM. However, we could adjust the installer to pause and ask the user if they have performed an update/upgrade on their base rpi before continuing on with the MM install. This gives the user an opportunity to exit the installer and do the requires prerequisites before returning to the installer (at which point they can then say ‘yes’ to the question.)
                                        • E
                                          EoF @KirAsh4
                                          @KirAsh4 I did the manual install for mine anyways, but I could have sworn I did an update / upgrade but I may be wrong.
                                          Maybe it’s something that can just be added to the install instructions as a small note.
                                          • K
                                            KirAsh4 Moderator
                                            You know, I have a spare rpi-3 sitting at home. I’ll wipe it clean and start fresh when I get home later and see if I run into issues. All in the name of science!
