    First start from the mirror does not work
    36 Posts 6 Posters 31.3k Views 4 Watching
      mochman Module Developer
      @samydp I had this problem when I first installed it. It was a module problem for me. Can you comment out all of the modules from config.js except alert and see if if gives you the same error. If not, start enabling the modules one by one until you figure out which is the problem.
      -Luke
        samydp
        how exactly do you mean? !
        I would now delete all modules except the komentare . or how to do it ?
        and thank you !!!
          samydp
          Update:
          can you show me how the modules in the config investing so that the screen indicating?:o
            @samydp, rename your config.js to config.js.old and make this your new config.js. Try running the program with this, if you see compliments on the bottom screen, you know that magicmirror works fine and the problem is in one of the other modules. It’s a place to start. If you’re still getting the electron errors, try rerunning npm install again in your MagicMirror directory.
            var config = {
            	port: 8080,
            	language: 'en',
            	timeFormat: 24,
            	units: 'metric',
            			module: 'alert',
            			module: 'compliments',
            			position: 'lower_third'
              samydp
              your config works !!! juhu thx but i have a other wrong :/
              i will the language from the clock in germany
              Module.register("clock",{
              	// Module config defaults.
              	defaults: {
              		timeFormat: config.timeFormat,
              		displaySeconds: true,
              		showPeriod: true,
              		showPeriodUpper: false,
              		clockBold: true
              	// Define required scripts.
              	getScripts: function() {
              		return ["moment.js"];
              	// Define start sequence.
              	start: function() {
              		// Schedule update interval.
              		var self = this;
              		setInterval(function() {
              			self.updateDom();
              		}, 1000);
              		// Set locale.
              		moment.locale(config.language);
              Note from Moderator: Please use proper Markdown on code snippets for easier reading.
                @samydp all you should have to do is change the language portion of your config.js from
                language: 'en', -> language: 'de',
                As for the rest of your modules, I recommend adding them one by one to your config.js file to make sure they work. If you get that electron.js error, it was on the module you just added.
                -Luke
                  samydp
                  Many thanks for your help and your tip! but only tow module works =( the clock an the compliments why this ?
                  Whenever I will add another module of the screen black!
                  i have install the electron.js again but
                  the add the module as in the proceeds described readme does not work !
                    Beats me, did you run npm install in the MagicMirror folder?
                      samydp
                      yes i have install the npm in the MM Folder , only compliment, clock and news works other moduls come a error ( no config file )
                      • E Offline
                        EoF
                        Hi I am having this same issue. Did you ever get it working?
                        • MichMichM Offline
                          MichMich
                          Maybe I’m missing something here, but it seems you try to run npm start from a remote shell. That does not work since it doesn’t know on which screen to start. Try: DISPLAY=:0 npm start
                          • E Offline
                            EoF @MichMich
                            @MichMich Hi! I am running npm start directly on the pi, and I get the same exact error.
                            • E Offline
                              EoF
                              As an update to my situation, I was able to get mine working by installing electron dependencies.
                              sudo apt-get install libgtk2.0-0 libnotify4 libgconf2-4 libnss3
                              I am running a pi 3 with Jessie by the way.
                              FYI @MichMich @paviro
                              • K Offline
                                KirAsh4 Moderator
                                Interesting as I didn’t have to do that as a separate step. However, as I posted in a different thread yesterday, keeping the base software on your Raspberry Pi is important.
                                  paviro
                                  Mhh maybe we should add those dependencies and/or apt-get upgrade to the installer script?
                                  – The Doctor
                                  • K Offline
                                    KirAsh4 Moderator
                                    I vote no because that’s outside the scope of MM. However, we could adjust the installer to pause and ask the user if they have performed an update/upgrade on their base rpi before continuing on with the MM install. This gives the user an opportunity to exit the installer and do the requires prerequisites before returning to the installer (at which point they can then say ‘yes’ to the question.)
                                    • E Offline
                                      EoF @KirAsh4
                                      @KirAsh4 I did the manual install for mine anyways, but I could have sworn I did an update / upgrade but I may be wrong.
                                      Maybe it’s something that can just be added to the install instructions as a small note.
                                      • K Offline
                                        KirAsh4 Moderator
                                        You know, I have a spare rpi-3 sitting at home. I’ll wipe it clean and start fresh when I get home later and see if I run into issues. All in the name of science!
                                        • E Offline
                                          EoF @KirAsh4
                                          @KirAsh4 haha alright go for it! Let us know what comes of it.
                                          • K Offline
                                            KirAsh4 Moderator
                                            Will do. Right after I inspect the 3D print that I left going since last night, and I start the next print. And after I swap a laptop with a friend. And after I have dinner. And after I help another friend with their phone. And after i do some laser cutting of mock up pieces for an art piece. And after I dig up the electronic bits I need for a kid’s costume. And after I … and after … and … oh you’ll hear from me some time in 2036. Really, I promise.
                                            (Is there ever such a thing as having too many projects going at the same time?)
