    First start from the mirror does not work
    36 Posts 6 Posters 28.9k Views 4 Watching
      samydp
      so i tell you what I’ve done everything :
      MM V1
      1. Format card
      2. Install Raspbian
      3. Apache server and PHP5 Install
      4. Install Chomium browser
      5. Chomium browser Kisos - mode and autostart (sudo nano .config/lxsession/LXDE pi/autostart)
      6. Raspberry Update
      7. MM v1 copied to /var/www/html
      8. Change config
      9. finished
      MM V2
      1. MM v1 Clear
      2. Install node
      3. MM clone (git clone https://github.com/MichMich/MagicMirror)
      4. Navigate to folder (cd /home/pi/Magic Mirror)
      5. npm install && npm start
      6. Error
      7. npm log
      what can I do now ?
      Note from admin: Please use Markdown on shell commands so they are easier to read!
      • KirAsh4K Offline
        KirAsh4 Moderator
        I think we have to get @MichMich or @paviro in on this. I don’t know Electron enough to know why it’s failing.
        • paviroP Offline
          paviro
          I hate those node error outputs… 😔 it could be that one of your module helpers fails to start. Have you installed any modules?
          – The Doctor
            samydp
            can you tell me what all modules I exactly need. ? I make every time you install an update
            paviroP 1 Reply Last reply Reply Quote 0
            • paviroP Offline
              paviro @samydp
              @samydp you do not need any modules. Did you add anything to the modules folder?
              – The Doctor
                samydp
                I have not in the folder modules I 've added the left so !
                I can make it wenistens indicating to me and does not remain black : O
                • mochmanM Offline
                  mochman Module Developer
                  @samydp I had this problem when I first installed it. It was a module problem for me. Can you comment out all of the modules from config.js except alert and see if if gives you the same error. If not, start enabling the modules one by one until you figure out which is the problem.
                  -Luke
                    samydp
                    how exactly do you mean? !
                    I would now delete all modules except the komentare . or how to do it ?
                    and thank you !!!
                      samydp
                      Update:
                      can you show me how the modules in the config investing so that the screen indicating?:o
                      • mochmanM Offline
                        @samydp, rename your config.js to config.js.old and make this your new config.js. Try running the program with this, if you see compliments on the bottom screen, you know that magicmirror works fine and the problem is in one of the other modules. It’s a place to start. If you’re still getting the electron errors, try rerunning npm install again in your MagicMirror directory.
                        var config = {
                        	port: 8080,
                        	language: 'en',
                        	timeFormat: 24,
                        	units: 'metric',
                        			module: 'alert',
                        			module: 'compliments',
                        			position: 'lower_third'
                        • 1 / 4
