    First start from the mirror does not work
    36 Posts 6 Posters 30.4k Views 4 Watching
      samydp
      to only sorry for my bad english .
      I have made the manual installation and it is the fault (picture)
      The mirror is black and no module is loaded .
      • EoFE Offline
        EoF
        Hi. What is in the log file referenced? That may help us to determine what’s going on.
        Also I haven’t tried to run MM on linux yet, only windows, so I might be wrong on this part but you might have to have electron installed.
        • KirAsh4K Offline
          KirAsh4 Moderator
          Myah, MM runs just fine on Linux (following the manual installation instructions.) That’s how I have it running at my office since I don’t have an rPi here.
            samydp
            Hello I got the raspberry pi to 1000 times reinstalled and it’s nothing ! only MagicMirror v1 goes without problems ! In V2 the screen remains in black start even though I have the config edit : /
            • KirAsh4K Offline
              KirAsh4 Moderator
              If the process starts, but it stays black, there may be an error in your config which is getting it stuck. Have you looked at the console output or the log output for any messages?
                samydp
                so i tell you what I’ve done everything :
                MM V1
                1. Format card
                2. Install Raspbian
                3. Apache server and PHP5 Install
                4. Install Chomium browser
                5. Chomium browser Kisos - mode and autostart (sudo nano .config/lxsession/LXDE pi/autostart)
                6. Raspberry Update
                7. MM v1 copied to /var/www/html
                8. Change config
                9. finished
                MM V2
                1. MM v1 Clear
                2. Install node
                3. MM clone (git clone https://github.com/MichMich/MagicMirror)
                4. Navigate to folder (cd /home/pi/Magic Mirror)
                5. npm install && npm start
                6. Error
                7. npm log
                what can I do now ?
                Note from admin: Please use Markdown on shell commands so they are easier to read!
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  I think we have to get @MichMich or @paviro in on this. I don’t know Electron enough to know why it’s failing.
                  • paviroP Offline
                    paviro
                    I hate those node error outputs… 😔 it could be that one of your module helpers fails to start. Have you installed any modules?
                    – The Doctor
                      samydp
                      can you tell me what all modules I exactly need. ? I make every time you install an update
                      paviroP 1 Reply Last reply Reply Quote 0
                      • paviroP Offline
                        paviro @samydp
                        @samydp you do not need any modules. Did you add anything to the modules folder?
                        – The Doctor
                          samydp
                          I have not in the folder modules I 've added the left so !
                          I can make it wenistens indicating to me and does not remain black : O
                          • mochmanM Offline
                            mochman Module Developer
                            @samydp I had this problem when I first installed it. It was a module problem for me. Can you comment out all of the modules from config.js except alert and see if if gives you the same error. If not, start enabling the modules one by one until you figure out which is the problem.
                            -Luke
                              samydp
                              how exactly do you mean? !
                              I would now delete all modules except the komentare . or how to do it ?
                              and thank you !!!
                                samydp
                                Update:
                                can you show me how the modules in the config investing so that the screen indicating?:o
                                • mochmanM Offline
                                  @samydp, rename your config.js to config.js.old and make this your new config.js. Try running the program with this, if you see compliments on the bottom screen, you know that magicmirror works fine and the problem is in one of the other modules. It’s a place to start. If you’re still getting the electron errors, try rerunning npm install again in your MagicMirror directory.
                                  var config = {
                                  	port: 8080,
                                  	language: 'en',
                                  	timeFormat: 24,
                                  	units: 'metric',
                                  			module: 'alert',
                                  			module: 'compliments',
                                  			position: 'lower_third'
                                    samydp
                                    your config works !!! juhu thx but i have a other wrong :/
                                    i will the language from the clock in germany
                                    Module.register("clock",{
                                    	// Module config defaults.
                                    	defaults: {
                                    		timeFormat: config.timeFormat,
                                    		displaySeconds: true,
                                    		showPeriod: true,
                                    		showPeriodUpper: false,
                                    		clockBold: true
                                    	// Define required scripts.
                                    	getScripts: function() {
                                    		return ["moment.js"];
                                    	// Define start sequence.
                                    	start: function() {
                                    		// Schedule update interval.
                                    		var self = this;
                                    		setInterval(function() {
                                    			self.updateDom();
                                    		}, 1000);
                                    		// Set locale.
                                    		moment.locale(config.language);
                                    Note from Moderator: Please use proper Markdown on code snippets for easier reading.
                                    • mochmanM Offline
                                      @samydp all you should have to do is change the language portion of your config.js from
                                      language: 'en', -> language: 'de',
                                      As for the rest of your modules, I recommend adding them one by one to your config.js file to make sure they work. If you get that electron.js error, it was on the module you just added.
                                      -Luke
                                        samydp
                                        Many thanks for your help and your tip! but only tow module works =( the clock an the compliments why this ?
                                        Whenever I will add another module of the screen black!
                                        i have install the electron.js again but
                                        the add the module as in the proceeds described readme does not work !
                                        • mochmanM Offline
                                          Beats me, did you run npm install in the MagicMirror folder?
                                            samydp
                                            yes i have install the npm in the MM Folder , only compliment, clock and news works other moduls come a error ( no config file )
