Unsolved MMM-OpenWeatherMapForecast loading issue?
@sdetweil the file is there, I just can seem to figure out what line to put it at, I have tried a couple spots but all it does is kill the module?
@croc_dad72 eh?
just edit the file with nano and add that stuff to the end on new lines
I just read it take 2 hours for your app to be activated so put a new one in . You can delete you old one in weather maps creat a new one like say
Romford it should then appear and say activated
Add to your file again wait .
I am having a simpler problem as mine isn’t loading
So going try again tomorrow.Best of luck lots of people are having similar issues.
If in the UK make shore its not us . Its easy make that mistake. ID 2639192 Romford test this ID -
@croc_dad72
Hi yes mine not loading try reloading a new app key from open weather maps wait 2 hour before starting it up . create a new api you can delete you old one
Add I’d try Romford 2639192
Test
Get eventing read go out shopping or if your like I can wait ha haNot sure if it’s going to work I am going to try this on my one tomorrow.
Good luck
It may be broke . -
Once your git things working get mini adapter use copy sd card on the pi it take a while but things go wrong you can start agin with your copy .
Yes it happen to me . -
@videogame95 watch out, there are limited number of requests per day. once you hit it, nothing…
