calendar
10 Posts 3 Posters 1.6k Views 3 Watching
  • V Offline
    videogame95
    Re: CSS 101 - Getting started with CSS and understanding how CSS works
    I have no under standing how to change my calendar ,
    what do put at beginning of the custom css to select Calendar to make board black or gray around it,
    I have read you help but not were to start
    sorry ,any help please
    S 1 Reply Last reply May 8, 2023, 1:08 AM Reply Quote 0
      JohnGalt
      You can try the following in your custom.css file. The first 3 lines are comments, explaining what is happening. Next the background is applied to the clock module. Finally it is applied to the calendar module, with a different transparency - it produces a dark grey background.
      // background-color: rgba(red, green, blue, alpha)
      // red, green, blue: 0 - 255
      // alpha: 0 -1 (0=transparent, 1=opaque)
      .module.clock {
        background-color:rgba(0,0,0,0.4);
        border-radius:8px;
        padding:8px;
      .module.calendar {
        background-color:rgba(0,0,0,0.6);
        border-radius:8px;
        padding:8px;
      S 1 Reply Last reply May 8, 2023, 1:02 AM Reply Quote 0
        sdetweil @JohnGalt
        @JohnGalt dont need .module
        J 2 Replies Last reply May 8, 2023, 1:30 AM Reply Quote 0
          sdetweil @videogame95
          @videogame95 sorry, I missed your question
          https://docs.magicmirror.builders/modules/customcss.html#target-a-specific-module
          .modulename .... {
          like
          .clock {
          applies to the stuff in the clock module output
          the .modulename … before the { is called the css selector clause… it ‘selects’ the elements the data inside the {} will apply to
          I use this to remind me of the things that can go there …
          https://www.w3schools.com/cssref/css_selectors.php
          here is a clause in my MMM-Config module form to hide a useless element I have no control over
          .possibly-hidden-tab div:nth-child(2)  > div > div >div >ul >li:only-child >a[rel*="Item 1"] {
            display: none;
          the selector clause ALWAYS selects ALL elements in the document that match the selector… SO .modulename prefix means u only mess up your stuff!
            JohnGalt @sdetweil
            @sdetweil - Thanks! I will clean up my code some, when I get a chance. I appreciate the input.
              JohnGalt @sdetweil
              @sdetweil – BTW, it this also true for all modules? That is, also for non-default modules? [Somehow I had internalized that even if default modules could be addressed this way, others required something like the following]:
              .module.MMM-WeatherAlerts header {text-align: left;
              .module.MMM-WeatherAlerts {  background-color:rgba(255,255,255,0.2);
              S 1 Reply Last reply May 8, 2023, 1:37 AM Reply Quote 0
                sdetweil @JohnGalt
                @JohnGalt its the same for all modules…
                .clock
                .calendar
                .MMM-Config
                whatever
                when MM puts the content in a section it adds a class (.modulename) to that block of content
                J 1 Reply Last reply May 8, 2023, 1:38 AM Reply Quote 0
                  JohnGalt @sdetweil
                  @sdetweil - Great, good to know.
                  S 1 Reply Last reply May 8, 2023, 1:42 AM Reply Quote 0
                    sdetweil @JohnGalt
                    @JohnGalt here is a copy out of some of the content for a weather module
                    <div class="container" style="display: block;">
                         <div id="module_5_weather" class="module weather weather">
                             <header class="module-header" style="display: none;"></header>
                               <div class="module-content">
                                   // module content would go here
                                  <div class="dimmed light small"> Cargando … </div>
                              </div>
                        </div>
                    </div>
                    on this line
                    you have the modulename as a class
                    and the id “module_5_weather”
                    as the selectable elements to target the content inside
                    module_5 is the count of modules top down starting at 0
                    good if u had multiple instances of a module and wanted to target different ones for different styles
                    J 1 Reply Last reply May 24, 2023, 2:24 AM Reply Quote 0
                    • S sdetweil referenced this topic on May 8, 2023, 11:14 AM
                      JohnGalt @sdetweil
                      @sdetweil - Thanks Sam. This will help when I work on cleaning up my display overall, as i do have multiple instances of both calendar and weather running!
