    Testing my module, it is stuck loading
    31 Posts 2 Posters 12.0k Views 2 Watching
      sdetweil @l0zarus
      @l0zarus ok, no headers set it to “”
      you use that code to build your fetch url (and put it in the original_url variable)
      I just created the JS code to do the build from the parts
      the comment in the linked file just doesn’t help me at all…
      and when you execute the fetch, it sends it to magic mirror code that forwards on supposedly to avoid the cors problem…
      • L Offline
        l0zarus @sdetweil
        @sdetweil I’m going to try to fill it out like a template, let me know if I’m following.
        let header = "",
        let original_url = "https://api.seatgeek.com/2/events?client_id=MYCLIENTID&client_secret=MYCLIENTSECRET "
        let cors_url = "http://" + config.address==="IP ADDRESS HERE"?"localhost":config.address + ":" + config.port + "/cors?" + header + "&url=" + original_url
        and then I fetch(cors_url)?
        Is this right?
          sdetweil @l0zarus
          @l0zarus said in Testing my module, it is stuck loading:
          Is this right?
          yes
          almost …
          "IP ADDRESS HERE"
          MUST be
          "0.0.0.0"
          (which is the MM value for listen on any network adapter)
          • L Offline
            l0zarus @sdetweil
            // this next block is to deal with a CORS permissions issue with the API
            let header = “”;
                // this is the API call url
                let original_url = "http://api.seatgeek.com/2/events?lat=" + self.config.latitude + "&lon=" + self.config.longitude + "&per_page=" + self.config.eventCount + "&datetime_utc.gte=" + today + "&datetime_utc.lte=" + oneweek + "&range=" + self.config.range + "&type=concert" + "&client_id=" + self.config.clientID + "&client_secret=" + self.config.clientSecret;
                // this is the cors URL
                let cors_url = "http://" + config.address==="0.0.0.0"?"localhost":config.address + ":" + config.port + "/cors?" + header + "&url=" + original_url;
              sdetweil @l0zarus
              @l0zarus looks good
              • L Offline
                l0zarus @sdetweil
                @sdetweil I got a new console error:
                  sdetweil @l0zarus
                  @l0zarus you did NOT add let config= right? (or var, or const)
                  config is already defined for you
                  this.config is the stuff from your module entry
                  config. is ALL the config.js
                  L 2 Replies Last reply Reply Quote 0
                  • L Offline
                    l0zarus @sdetweil
                    I added let header = “” and let cors_url = jdhflrkgd. I did not add anything else at all.
                    exact code below:
                            let header = "";
                            // fetching the data from seatgeek
                            fetch(cors_url)
                    • L Offline
                      l0zarus @sdetweil
                      strange… I just found the following code at the top of my file. I did not add it there. Going to delete it now.
                      const config = require("../../config/config");
                        sdetweil @l0zarus
                        config.address===“0.0.0.0”?“localhost”:config.address
                        oops
                        need parens around that…
                        • L Offline
                          l0zarus @sdetweil
                          @sdetweil aha!!! This did it! It’s ugly but it is working… now to spend time improving the design of the table and make my code more effective.
                          THANK YOU SO MUCH! I will probably be back with more questions, but not around this issue.
                            sdetweil @l0zarus
                            @l0zarus woohoo… thx for the feedback
