    Testing my module, it is stuck loading
    31 Posts 2 Posters 11.3k Views 2 Watching
      sdetweil @l0zarus
      @l0zarus said in Testing my module, it is stuck loading:
      Is this right?
      yes
      almost …
      "IP ADDRESS HERE"
      MUST be
      "0.0.0.0"
      (which is the MM value for listen on any network adapter)
      • L Offline
        l0zarus @sdetweil
        // this next block is to deal with a CORS permissions issue with the API
        let header = “”;
            // this is the API call url
            let original_url = "http://api.seatgeek.com/2/events?lat=" + self.config.latitude + "&lon=" + self.config.longitude + "&per_page=" + self.config.eventCount + "&datetime_utc.gte=" + today + "&datetime_utc.lte=" + oneweek + "&range=" + self.config.range + "&type=concert" + "&client_id=" + self.config.clientID + "&client_secret=" + self.config.clientSecret;
            // this is the cors URL
            let cors_url = "http://" + config.address==="0.0.0.0"?"localhost":config.address + ":" + config.port + "/cors?" + header + "&url=" + original_url;
          sdetweil @l0zarus
          @l0zarus looks good
          • L Offline
            l0zarus @sdetweil
            @sdetweil I got a new console error:
              sdetweil @l0zarus
              @l0zarus you did NOT add let config= right? (or var, or const)
              config is already defined for you
              this.config is the stuff from your module entry
              config. is ALL the config.js
              L 2 Replies Last reply Reply Quote 0
              • L Offline
                l0zarus @sdetweil
                I added let header = “” and let cors_url = jdhflrkgd. I did not add anything else at all.
                exact code below:
                        let header = "";
                        // fetching the data from seatgeek
                        fetch(cors_url)
                • L Offline
                  l0zarus @sdetweil
                  strange… I just found the following code at the top of my file. I did not add it there. Going to delete it now.
                  const config = require("../../config/config");
                    sdetweil @l0zarus
                    config.address===“0.0.0.0”?“localhost”:config.address
                    oops
                    need parens around that…
                    • L Offline
                      l0zarus @sdetweil
                      @sdetweil aha!!! This did it! It’s ugly but it is working… now to spend time improving the design of the table and make my code more effective.
                      THANK YOU SO MUCH! I will probably be back with more questions, but not around this issue.
                        sdetweil @l0zarus
                        @l0zarus woohoo… thx for the feedback
