    MMM-GrafanaChart doesn't display my Grafana Dashboard
    4 Posts 3 Posters 2.1k Views 3 Watching
    • A
      alphanet
      Hello
      I would like to embed a Grafana Dashboard in my Magic Mirror with the module : MMM-GrafanaChart.
      So I have installed the MMM-GrafanaChart module.
      I have changed the settings in the grafana.ini as specified :
      [auth.anonymous]
      enable anonymous access
      enabled = true
      specify role for unauthenticated users
      org_role = Viewer
      [security]
      allow_embedding = true
      My config.js file for this module is simply:
      module: ‘MMM-GrafanaChart’,
      position: ‘top_right’, // This can be any of the regions.
      url: “https://localhost:5000/…”, // see below on how to get the URL from Grafana
      width: “100%”, // Optional. Default: 100%
      height: “100%”, // Optional. Default: 100%
      scrolling: “no”, // Optional. Default: no
      refreshInterval: 900 //Optional. Default: 900 = 1/4 hour
      I have put the Link URL that I found in the Share menu of the Dashboard in url:
      Unfortunately on the Magic Mirror I only get a “Welcome to Grafana” window asking for login,and can’t go further, when entering login/password ?
      How could I have access and display my dashboard directly without this login from Grafana ?
      Thank you very much in advance for your help.
      B wishmaster270W A 3 Replies Last reply
        barnosch @alphanet
        @alphanet
        I also did not get that to work, so i use
        “MMM-iFrameReload”
        That works without issues
        Looks like this
        		disabled: false,
        		module: 'MMM-iFrameReload',
        		position: 'top_left',
        		//header: 'Graph',
        			url: "http://YourIP:3000/d/99SonoTEST/overview?orgId=1&kiosk",
        			width: "365px", // Optional. Default: 400px
        			height: "320px", // Optional. Default: 800px
        			refreshInterval: 300,  //300= 5min . Default: 3600 = 1 hour
        • wishmaster270W
          wishmaster270 Module Developer @alphanet
          @alphanet
          Hi, you can use my MMM-EmbedURL module for this job.
          I wrote a tutorial of how to do it.
          Reply Quote 2
          • A
            alphanet @alphanet
            Thank you very much for your help barnosh and wishmaster.
            I have tried MMM-iFrameReload and MMM-EmbedURL, but still cannot display my Grafana dashboard in the MM.
            The modules work very well but not with my Grafana dashboard link ?
            I have to try again and find the reason of this issue.
            Gratefully yours.
            alphanet
