    Easy Center Resizing?
    6 Posts 4 Posters 1.4k Views 4 Watching
      sdetweil @amarand
      @amarand sadly there is no ‘easy’ way
      the default section/position/regions layout is like this
      https://forum.magicmirror.builders/topic/286/regions?_=1683231109633
      no two authors do styling the same way. every thing u tweak makes trouble somewhere else…
      using the developers console is one good tool, but its all still hard work.
      https://forum.magicmirror.builders/topic/14862/help-with-a-couple-css-issues?_=1683231109642
        sdetweil @amarand
        @amarand ps. I’ve been here since 2017, and do a lot of css, and modules… but I couldn’t tell you how to do it, cause I can’t myself.
        • BKeyportB Offline
          @amarand I’d do it like this:
          .region.right {
          	min-width: 450px;
          .region.left {
          	min-width: 450px;
          there’s also max-width if you want to lock it solid.
          Easy.
            MMRIZE
            The center position is the weirdest thing of MM. The width of center is decided by this code;
            .region.top.center,
            .region.bottom.center {
              left: 50%;
              transform: translateX(-50%);
            This code looks so intuitive, but not so really. It is calculated and applied after rendering, so that makes some issues;
            Anyway, this code would be a help for what you want;
            .region.left {
              width: 50%;
              background-color: rgba(255,0,0, 0.2); /* to check how it shows visibly; remove this line later. */
            .region.right {
              width: 50%;
              background-color: rgba(0,255,0, 0.2); /* to check how it shows visibly; remove this line later. */
            .region.center {
              display:none;
            By the way, current structure of MM’s positioning becomes a bit old and stubborn legacy.(almost 7 or 8 years old) Maybe we need to progress with more modern techs.
            BKeyportB 1 Reply Last reply Reply Quote 1
            • BKeyportB Offline
              BKeyport Module Developer @MMRIZE
              @MMRIZE I would love to see it reworked, mostly to add the missing 2 positions. (middle left, middle right)
