    Stock Market Module
    10 Posts 4 Posters 3.0k Views 4 Watching
    • L Offline
      lhops @sdetweil
      @sdetweil I am suing MMM-MktIndex (Thess)
      It does not require a API
      S T 2 Replies Last reply Reply Quote 0
        sdetweil @lhops
        @lhops it does call yahoo finance API
        also, if you look at the messages from npm start you may see output from the module API handler
        • L Offline
          lhops @sdetweil
          @sdetweil I have added the API to the main config file module but still no numbers. Do I have to configure any other file? It has been so long ago that I got the MM working I have forgotten a lot of the procedures.
            sdetweil @lhops
            @lhops no idea. I would look at the message
            L 2 Replies Last reply Reply Quote 0
            • L Offline
              lhops @sdetweil
              @sdetweil Sorry I don’t know what message npm is or where to find it. But I do appreciate all the help I can get. Thanks
              • L Offline
                lhops @sdetweil
                @sdetweil I have found the npm message by typing “npm list” but still no sure what I am looking for. And how to fix it.
                • bheplerB Offline
                  bhepler Module Developer @lhops
                  @lhops I think what he means is to type npm start and then see what the mirror logs as it starts the framework and modules. Running the mirror from the command line will output the messages back at you so you can look for problems.
                  Specifically, look for any line that begins with “error”.
                  • T Offline
                    thess @lhops
                    @lhops - MMM-MktIndex (1.3.0) updated to use a working API (yahoo-finance2).
                    You should re-install the module from Github since the package requirements have changed.
