    MM screen doesn't start but can access through web browser
    6 Posts 2 Posters 1.5k Views 2 Watching
      DDE12
      On a Win10 machine, MM doesn’t display the screen but I can access it through a web browser. Let me know if I can provide further info that will help troubleshoot this. Thank you for taking a look at this issue.
      let config = {
          address: ["localhost", "192.168.100.11"],
          port: 8080,
          basePath: "/",
          ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.100.0/24"]
      $ npm run start
      magicmirror@2.23.0 start
      .\node_modules.bin\electron js\electron.js
      [28.05.2023 23:56.25.585] [LOG] Starting MagicMirror: v2.23.0
      [28.05.2023 23:56.25.593] [LOG] Loading config …
      [28.05.2023 23:56.25.597] [DEBUG] config template file not exists, no envsubst
      [28.05.2023 23:56.25.607] [LOG] Loading module helpers …
      [28.05.2023 23:56.25.607] [LOG] No helper found for module: alert.
      [28.05.2023 23:56.25.627] [LOG] Initializing new module helper …
      [28.05.2023 23:56.25.628] [LOG] Module helper loaded: updatenotification
      [28.05.2023 23:56.25.945] [LOG] Initializing new module helper …
      [28.05.2023 23:56.25.945] [LOG] Module helper loaded: calendar
      [28.05.2023 23:56.26.443] [LOG] Initializing new module helper …
      [28.05.2023 23:56.26.444] [LOG] Module helper loaded: MMM-Wallpaper
      [28.05.2023 23:56.26.447] [LOG] No helper found for module: MMM-CalendarExt3Agenda.
      [28.05.2023 23:56.26.500] [LOG] Initializing new module helper …
      [28.05.2023 23:56.26.501] [LOG] Module helper loaded: MMM-MoonPhase
      [28.05.2023 23:56.26.502] [LOG] No helper found for module: MMM-FlipClock.
      [28.05.2023 23:56.27.283] [LOG] Initializing new module helper …
      [28.05.2023 23:56.27.284] [LOG] Module helper loaded: MMM-Gas
      [28.05.2023 23:56.27.399] [LOG] Initializing new module helper …
      [28.05.2023 23:56.27.399] [LOG] Module helper loaded: MMM-OpenWeatherForecast
      [28.05.2023 23:56.27.400] [LOG] No helper found for module: MMM-CalendarExt3.
      [28.05.2023 23:56.27.401] [LOG] No helper found for module: MMM-Carousel.
      [28.05.2023 23:56.27.401] [LOG] All module helpers loaded.
      [28.05.2023 23:56.27.418] [LOG] Starting server on port 8080 …
      [28.05.2023 23:56.27.441] [LOG] Server started …
      [28.05.2023 23:56.27.442] [LOG] Connecting socket for: updatenotification
      [28.05.2023 23:56.27.443] [LOG] Starting module helper: updatenotification
      [28.05.2023 23:56.27.443] [LOG] Connecting socket for: calendar
      [28.05.2023 23:56.27.443] [LOG] Starting node helper for: calendar
      [28.05.2023 23:56.27.444] [LOG] Connecting socket for: MMM-Wallpaper
      [28.05.2023 23:56.27.444] [LOG] Starting node helper for: MMM-Wallpaper
      [28.05.2023 23:56.27.445] [LOG] Connecting socket for: MMM-MoonPhase
      [28.05.2023 23:56.27.445] [LOG] Starting module helper: MMM-MoonPhase
      [28.05.2023 23:56.27.446] [LOG] Connecting socket for: MMM-Gas
      [28.05.2023 23:56.27.446] [LOG] Starting module: MMM-Gas
      [28.05.2023 23:56.27.446] [LOG] Connecting socket for: MMM-OpenWeatherForecast
      [28.05.2023 23:56.27.446] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
      [28.05.2023 23:56.27.447] [LOG] Sockets connected & modules started …
      [28.05.2023 23:56.27.600] [LOG] Launching application.
        sdetweil @DDE12
        @DDE12 see
        https://github.com/MichMich/MagicMirror/issues/3083
        I thought you fixed that already
        https://forum.magicmirror.builders/topic/17807/config-template-file-not-exists-no-ensubst/7?_=1685358870752
          DDE12 @sdetweil
          @sdetweil It looks like electron.js in 2.23.0 already has those changes except for
          let config = await core.start()
          https://forum.magicmirror.builders/topic/17807/config-template-file-not-exists-no-ensubst/7?_=1685358870752 had the default settings for address and ipWhitelist. The new problem arises when I add my information.
          Changing config to
          address: "0.0.0.0",
          ipWhitelist: [],
          results in a blank electron screen:
          npm run start
          [29.05.2023 11:15.38.750] [LOG] Starting MagicMirror: v2.23.0
          [29.05.2023 11:15.38.760] [LOG] Loading config …
          [29.05.2023 11:15.38.764] [DEBUG] config template file not exists, no envsubst
          [29.05.2023 11:15.38.772] [LOG] Loading module helpers …
          [29.05.2023 11:15.38.772] [LOG] No helper found for module: alert.
          [29.05.2023 11:15.38.791] [LOG] Initializing new module helper …
          [29.05.2023 11:15.38.792] [LOG] Module helper loaded: updatenotification
          [29.05.2023 11:15.39.107] [LOG] Initializing new module helper …
          [29.05.2023 11:15.39.107] [LOG] Module helper loaded: calendar
          [29.05.2023 11:15.39.617] [LOG] Initializing new module helper …
          [29.05.2023 11:15.39.618] [LOG] Module helper loaded: MMM-Wallpaper
          [29.05.2023 11:15.39.619] [LOG] No helper found for module: MMM-CalendarExt3Agenda.
          [29.05.2023 11:15.39.623] [LOG] Initializing new module helper …
          [29.05.2023 11:15.39.623] [LOG] Module helper loaded: MMM-MoonPhase
          [29.05.2023 11:15.39.623] [LOG] No helper found for module: MMM-FlipClock.
          [29.05.2023 11:15.40.400] [LOG] Initializing new module helper …
          [29.05.2023 11:15.40.400] [LOG] Module helper loaded: MMM-Gas
          [29.05.2023 11:15.40.515] [LOG] Initializing new module helper …
          [29.05.2023 11:15.40.515] [LOG] Module helper loaded: MMM-OpenWeatherForecast
          [29.05.2023 11:15.40.516] [LOG] No helper found for module: MMM-CalendarExt3.
          [29.05.2023 11:15.40.517] [LOG] No helper found for module: MMM-Carousel.
          [29.05.2023 11:15.40.517] [LOG] All module helpers loaded.
          [29.05.2023 11:15.40.534] [LOG] Starting server on port 8080 …
          [29.05.2023 11:15.40.560] [WARN] You’re using a full whitelist configuration to allow for all IPs
          [29.05.2023 11:15.40.575] [LOG] Server started …
          [29.05.2023 11:15.40.576] [LOG] Connecting socket for: updatenotification
          [29.05.2023 11:15.40.576] [LOG] Starting module helper: updatenotification
          [29.05.2023 11:15.40.576] [LOG] Connecting socket for: calendar
          [29.05.2023 11:15.40.577] [LOG] Starting node helper for: calendar
          [29.05.2023 11:15.40.577] [LOG] Connecting socket for: MMM-Wallpaper
          [29.05.2023 11:15.40.577] [LOG] Starting node helper for: MMM-Wallpaper
          [29.05.2023 11:15.40.578] [LOG] Connecting socket for: MMM-MoonPhase
          [29.05.2023 11:15.40.578] [LOG] Starting module helper: MMM-MoonPhase
          [29.05.2023 11:15.40.578] [LOG] Connecting socket for: MMM-Gas
          [29.05.2023 11:15.40.578] [LOG] Starting module: MMM-Gas
          [29.05.2023 11:15.40.579] [LOG] Connecting socket for: MMM-OpenWeatherForecast
          [29.05.2023 11:15.40.579] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
          [29.05.2023 11:15.40.579] [LOG] Sockets connected & modules started …
          [29.05.2023 11:15.40.708] [LOG] Launching application.
          [29.05.2023 11:15.41.834] [ERROR] (node:6304) electron: Failed to load URL: http://0.0.0.0:8080/ with error: ERR_ADDRESS_INVALID
          (Use electron --trace-warnings ... to show where the warning was created)
            sdetweil @DDE12
            @DDE12 said in MM screen doesn't start but can access through web browser:
            well cool. no idea what’s causing that…
            but I had reported a failure with that setting last year but didn’t get that message…
            will put it on my list of things to look at.
              DDE12 @sdetweil
              @sdetweil Thanks! I’ll keep an eye out for a solution.
                sdetweil @DDE12
                @DDE12 try this
                edit js/electron.js
                and change this , approx line 70 in the develop branch
                let address = (config.address === void 0) | (config.address === "")  ? (config.address = "localhost") : config.address;
                to this
                let address = (config.address === void 0) | (config.address === "") | (config.address === "0.0.0.0") ? (config.address = "localhost") : config.address;
                previous issue, reopened
                https://github.com/MichMich/MagicMirror/issues/2550
