    MM screen doesn't start but can access through web browser
    6 Posts 2 Posters 1.4k Views 2 Watching
      sdetweil @DDE12
      @DDE12 see
      https://github.com/MichMich/MagicMirror/issues/3083
      I thought you fixed that already
      https://forum.magicmirror.builders/topic/17807/config-template-file-not-exists-no-ensubst/7?_=1685358870752
        DDE12 @sdetweil
        @sdetweil It looks like electron.js in 2.23.0 already has those changes except for
        let config = await core.start()
        https://forum.magicmirror.builders/topic/17807/config-template-file-not-exists-no-ensubst/7?_=1685358870752 had the default settings for address and ipWhitelist. The new problem arises when I add my information.
        Changing config to
        address: "0.0.0.0",
        ipWhitelist: [],
        results in a blank electron screen:
        npm run start
        magicmirror@2.23.0 start
        .\node_modules.bin\electron js\electron.js
        [29.05.2023 11:15.38.750] [LOG] Starting MagicMirror: v2.23.0
        [29.05.2023 11:15.38.760] [LOG] Loading config …
        [29.05.2023 11:15.38.764] [DEBUG] config template file not exists, no envsubst
        [29.05.2023 11:15.38.772] [LOG] Loading module helpers …
        [29.05.2023 11:15.38.772] [LOG] No helper found for module: alert.
        [29.05.2023 11:15.38.791] [LOG] Initializing new module helper …
        [29.05.2023 11:15.38.792] [LOG] Module helper loaded: updatenotification
        [29.05.2023 11:15.39.107] [LOG] Initializing new module helper …
        [29.05.2023 11:15.39.107] [LOG] Module helper loaded: calendar
        [29.05.2023 11:15.39.617] [LOG] Initializing new module helper …
        [29.05.2023 11:15.39.618] [LOG] Module helper loaded: MMM-Wallpaper
        [29.05.2023 11:15.39.619] [LOG] No helper found for module: MMM-CalendarExt3Agenda.
        [29.05.2023 11:15.39.623] [LOG] Initializing new module helper …
        [29.05.2023 11:15.39.623] [LOG] Module helper loaded: MMM-MoonPhase
        [29.05.2023 11:15.39.623] [LOG] No helper found for module: MMM-FlipClock.
        [29.05.2023 11:15.40.400] [LOG] Initializing new module helper …
        [29.05.2023 11:15.40.400] [LOG] Module helper loaded: MMM-Gas
        [29.05.2023 11:15.40.515] [LOG] Initializing new module helper …
        [29.05.2023 11:15.40.515] [LOG] Module helper loaded: MMM-OpenWeatherForecast
        [29.05.2023 11:15.40.516] [LOG] No helper found for module: MMM-CalendarExt3.
        [29.05.2023 11:15.40.517] [LOG] No helper found for module: MMM-Carousel.
        [29.05.2023 11:15.40.517] [LOG] All module helpers loaded.
        [29.05.2023 11:15.40.534] [LOG] Starting server on port 8080 …
        [29.05.2023 11:15.40.560] [WARN] You’re using a full whitelist configuration to allow for all IPs
        [29.05.2023 11:15.40.575] [LOG] Server started …
        [29.05.2023 11:15.40.576] [LOG] Connecting socket for: updatenotification
        [29.05.2023 11:15.40.576] [LOG] Starting module helper: updatenotification
        [29.05.2023 11:15.40.576] [LOG] Connecting socket for: calendar
        [29.05.2023 11:15.40.577] [LOG] Starting node helper for: calendar
        [29.05.2023 11:15.40.577] [LOG] Connecting socket for: MMM-Wallpaper
        [29.05.2023 11:15.40.577] [LOG] Starting node helper for: MMM-Wallpaper
        [29.05.2023 11:15.40.578] [LOG] Connecting socket for: MMM-MoonPhase
        [29.05.2023 11:15.40.578] [LOG] Starting module helper: MMM-MoonPhase
        [29.05.2023 11:15.40.578] [LOG] Connecting socket for: MMM-Gas
        [29.05.2023 11:15.40.578] [LOG] Starting module: MMM-Gas
        [29.05.2023 11:15.40.579] [LOG] Connecting socket for: MMM-OpenWeatherForecast
        [29.05.2023 11:15.40.579] [LOG] ====================== Starting node_helper for module [MMM-OpenWeatherForecast]
        [29.05.2023 11:15.40.579] [LOG] Sockets connected & modules started …
        [29.05.2023 11:15.40.708] [LOG] Launching application.
        [29.05.2023 11:15.41.834] [ERROR] (node:6304) electron: Failed to load URL: http://0.0.0.0:8080/ with error: ERR_ADDRESS_INVALID
        (Use electron --trace-warnings ... to show where the warning was created)
          sdetweil @DDE12
          @DDE12 said in MM screen doesn't start but can access through web browser:
          well cool. no idea what’s causing that…
          but I had reported a failure with that setting last year but didn’t get that message…
          will put it on my list of things to look at.
            DDE12 @sdetweil
            @sdetweil Thanks! I’ll keep an eye out for a solution.
              sdetweil @DDE12
              @DDE12 try this
              edit js/electron.js
              and change this , approx line 70 in the develop branch
              let address = (config.address === void 0) | (config.address === "")  ? (config.address = "localhost") : config.address;
              to this
              let address = (config.address === void 0) | (config.address === "") | (config.address === "0.0.0.0") ? (config.address = "localhost") : config.address;
              previous issue, reopened
              https://github.com/MichMich/MagicMirror/issues/2550
