    Calendar and Font Awesome - no icons
    22 Posts 4 Posters 9.8k Views 4 Watching
      RGN01 @sdetweil
      @sdetweil thanks for your reply.
      	"name": "magicmirror",
      	"version": "2.23.0",
        sdetweil @RGN01
        @RGN01 so reinstalling won’t help … as u have the latest
        how did u install?? manual??
        do this , reinstall the fonts
        cd ~/MagicMirror/fonts
        rm -rf node_modules
        rm package-lock.json
        npm install
        then try MM again
        R 2 Replies Last reply
          RGN01 @sdetweil
          @sdetweil Thank you. I have done the font reinstall and rebooted. Still the same, unfortunately.
          When you said “then try MM again” did you mean reinstall or just see if it works?
            sdetweil @RGN01
            @RGN01 just see if it works
              RGN01 @sdetweil
              @sdetweil Thanks for clarifying. Unfortunately, no, it did not.
                sdetweil @RGN01
                @RGN01 ok, lets open the developers window (ctrl-shift-i on the MM keyboard) , select the elements tab , select the pointer top left and use the mouse to position over the icon in the 1st element
                see where its looking
                R 1 Reply Last reply
                  RGN01 @sdetweil
                  @sdetweil Thank you so much for your assistance - I really do appreciate it!
                          {keyword: 'Recycling', symbol: 'fas fa-house', color: 'Red'},
                          {keyword: 'Rubbish', symbol: 'fas fa-person', color: 'Gold'}
                              url: 'https://calendar.google.com//Calendar1Redacted/basic.ics',
                              symbol: 'fa-house',
                  It is matching to the ‘Rubbish’ keyword.
                    sdetweil @RGN01
                    @RGN01 said in Calendar and Font Awesome - no icons:
                    there is the problem…
                    u need to split the class and the symbol
                                    symbol: 'person',
                                    symbolClassName: "fas fa-fw fa-",
                    the system appends the symbol name TO the classname
                    here is the default value
                    defaultSymbolClassName: “fas fa-fw fa-”,
                    so, if it doesn’t need to be different (paid for icons use a different prefix)
                    then don’t set it…
                    and U can set the prefix (classname) once per calendar in the list of calendars
                    symbolClassName: “fas fa-fw fa-”,
                    NOT on every symbol entry
                      RGN01 @sdetweil
                      @sdetweil Thank you. You have helped a lot but I’m still battling. I’ve had a long day and am struggling to concentrate so will resume this tomorrow.
                        sdetweil @RGN01
                        @RGN01
                        this
                        should be this
                        symbol: 'house'
                          RGN01 @sdetweil
                          @sdetweil Thanks again. I went back to basics and removed all ‘my’ entries from config.js and replaced them with the config from the reference page, slightly edited. This is what I now have:
                              position: "bottom_left",
                          	   coloredText: false,
                          	   coloredBorder: false,
                          	   coloredSymbol: false,
                          	   coloredBackground: false,
                          			  url: 'https://calendar.google.com/calendar/ical/Calendar1Redacted/basic.ics',
                          			  symbol: 'calendar',
                          Which delivers: Cal3.png
                          Looking at the developers window, I see: Cal4.png
                            sdetweil @RGN01
                            @RGN01 I reviewed on my system, used the same symbol
                            same content… mine shows the icon
                            edit: one question… do you have any font definitions in your custom.css?
                            SO, this tells me the fonts didn’t get installed, so do
                            edit… note I am adding on the vendor folder … as that is where the fontawesome css comes from
                            rm -rf node_modules
                            npm install
                            cd ../vendor
                            rm -rf node_modules
                            ls
                            npm install
                            then check the folder contents this is what mine looks like
                            (base) sam@sams:~/MagicMirror/fonts$ ls
                            node_modules  package.json  package-lock.json  roboto.css
                            (base) sam@sams:~/MagicMirror/fonts$ ls node_modules/
                            @fontsource
                            (base) sam@sams:~/MagicMirror/fonts$ ls node_modules/@fontsource/
                            roboto  roboto-condensed
                            my MagicMirror/vendor folder looks like this
                            (base) sam@sams:~/MagicMirror/vendor$ ls
                            css  node_modules  package.json  package-lock.json  vendor.js
                            (base) sam@sams:~/MagicMirror/vendor$ ls css
                            font-awesome.css
                            and my calendar config
                            			header: "US Holidays",
                            				coloredSymbol:true,
                            					symbol: 'calendar',
                            					color: 'pink',
                            						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                            the top of the MM web page shows the includes for font and css
                            this is what the default looks like
