    Calendar and Font Awesome - no icons
    22 Posts 4 Posters 9.8k Views 4 Watching
      sdetweil @RGN01
      @RGN01 i just installed a new instance of MM, and used your settings for symbol, color and symbolClassName. and they all worked.
      I only used this classname
      symbolClassName: “fas fa-”, the other works too “fas fa-fw fa-”
        RGN01 @BKeyport
        @BKeyport Thank you - perhaps that is my path of least resistance - reinstall MM.
        I’ll give that a go on the weekend, if I don’t figure this out before.
          sdetweil @RGN01
          @RGN01 what version are you running?
          see the startup messages or the top of package.json
          R 1 Reply Last reply
            RGN01 @sdetweil
            @sdetweil thanks for your reply.
            	"name": "magicmirror",
            	"version": "2.23.0",
              sdetweil @RGN01
              @RGN01 so reinstalling won’t help … as u have the latest
              how did u install?? manual??
              do this , reinstall the fonts
              cd ~/MagicMirror/fonts
              rm -rf node_modules
              rm package-lock.json
              npm install
              then try MM again
              R 2 Replies Last reply
                RGN01 @sdetweil
                @sdetweil Thank you. I have done the font reinstall and rebooted. Still the same, unfortunately.
                When you said “then try MM again” did you mean reinstall or just see if it works?
                  sdetweil @RGN01
                  @RGN01 just see if it works
                    RGN01 @sdetweil
                    @sdetweil Thanks for clarifying. Unfortunately, no, it did not.
                      sdetweil @RGN01
                      @RGN01 ok, lets open the developers window (ctrl-shift-i on the MM keyboard) , select the elements tab , select the pointer top left and use the mouse to position over the icon in the 1st element
                      see where its looking
                        RGN01 @sdetweil
                        @sdetweil Thank you so much for your assistance - I really do appreciate it!
                                {keyword: 'Recycling', symbol: 'fas fa-house', color: 'Red'},
                                {keyword: 'Rubbish', symbol: 'fas fa-person', color: 'Gold'}
                                    url: 'https://calendar.google.com//Calendar1Redacted/basic.ics',
                                    symbol: 'fa-house',
                        It is matching to the ‘Rubbish’ keyword.
                          sdetweil @RGN01
                          @RGN01 said in Calendar and Font Awesome - no icons:
                          there is the problem…
                          u need to split the class and the symbol
                                          symbol: 'person',
                                          symbolClassName: "fas fa-fw fa-",
                          the system appends the symbol name TO the classname
                          here is the default value
                          defaultSymbolClassName: “fas fa-fw fa-”,
                          so, if it doesn’t need to be different (paid for icons use a different prefix)
                          then don’t set it…
                          and U can set the prefix (classname) once per calendar in the list of calendars
                          symbolClassName: “fas fa-fw fa-”,
                          NOT on every symbol entry
                            RGN01 @sdetweil
                            @sdetweil Thank you. You have helped a lot but I’m still battling. I’ve had a long day and am struggling to concentrate so will resume this tomorrow.
                              sdetweil @RGN01
                              @RGN01
                              this
                              should be this
                              symbol: 'house'
                                RGN01 @sdetweil
                                @sdetweil Thanks again. I went back to basics and removed all ‘my’ entries from config.js and replaced them with the config from the reference page, slightly edited. This is what I now have:
                                    position: "bottom_left",
                                	   coloredText: false,
                                	   coloredBorder: false,
                                	   coloredSymbol: false,
                                	   coloredBackground: false,
                                			  url: 'https://calendar.google.com/calendar/ical/Calendar1Redacted/basic.ics',
                                			  symbol: 'calendar',
                                Which delivers: Cal3.png
                                Looking at the developers window, I see: Cal4.png
                                  sdetweil @RGN01
                                  @RGN01 I reviewed on my system, used the same symbol
                                  same content… mine shows the icon
                                  edit: one question… do you have any font definitions in your custom.css?
                                  SO, this tells me the fonts didn’t get installed, so do
                                  edit… note I am adding on the vendor folder … as that is where the fontawesome css comes from
                                  rm -rf node_modules
                                  npm install
                                  cd ../vendor
                                  rm -rf node_modules
                                  ls
                                  npm install
                                  then check the folder contents this is what mine looks like
                                  (base) sam@sams:~/MagicMirror/fonts$ ls
                                  node_modules  package.json  package-lock.json  roboto.css
                                  (base) sam@sams:~/MagicMirror/fonts$ ls node_modules/
                                  @fontsource
                                  (base) sam@sams:~/MagicMirror/fonts$ ls node_modules/@fontsource/
                                  roboto  roboto-condensed
                                  my MagicMirror/vendor folder looks like this
                                  (base) sam@sams:~/MagicMirror/vendor$ ls
                                  css  node_modules  package.json  package-lock.json  vendor.js
                                  (base) sam@sams:~/MagicMirror/vendor$ ls css
                                  font-awesome.css
                                  and my calendar config
                                  			header: "US Holidays",
                                  				coloredSymbol:true,
                                  					symbol: 'calendar',
                                  					color: 'pink',
                                  						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                                  the top of the MM web page shows the includes for font and css
                                  this is what the default looks like
