    MMM-CalendarEXT2 - Calendar Read Failing When Time Value Is Missing from ics file
    28 Posts 3 Posters 17.5k Views 3 Watching
      sdetweil @edd189
      @edd189 generally yes, regardless of where it is…
      no, no need to do any compile
      sory, forgo this darned forum changes quotes not in a code block …
      make sure they are the straight up and down ones
      look back at my example
      E 2 Replies Last reply Reply Quote 0
      • E Offline
        edd189 @sdetweil
        @sdetweil Doh, the error reporter already shows me the aValue.
        aValue = 2022-01-01T::
        By my count, that is 13 characters. Let me see if simply changing 10 to 13 in the above code fixes it.
        • E Offline
          edd189 @sdetweil
          @sdetweil Is this right?
          ICAL.Time.fromString = function fromString(aValue) {
          if (aValue.length > 10) {
          return ICAL.Time.fromDateTimeString(aValue);
          Log.log([CALEXT2] calendar: >> greater 10);
          Console.log($avalue.length );
          } else {
          return ICAL.Time.fromDateString(aValue);
          Log.log([CALEXT2] calendar: >> less 10);
            sdetweil @edd189
            @edd189 said in MMM-CalendarEXT2 - Calendar Read Failing When Time Value Is Missing from ics file:
            no… those new statements are after the return… so will never be executed
            Log.log and console.log are the same here …
            • E Offline
              edd189 @sdetweil
              Thanks for your help. Not sure I’m finding the right place where the call is made to fromDateTimeString. I found a few more instances in a file under the build directory. I was previously only looking under the lib directory.
              Not sure how I missed it, but I need to take a break for the evening. Pick it back up later.
              • E Offline
                edd189 @sdetweil
                Look at file design.js here: https://github.com/kewisch/ical.js/tree/main/lib/ical
                What does line 401 do? The call on line 403 is where I get the error. I’m not familiar enough with java to know what decorate means.
                  sdetweil @edd189
                  @edd189 sorry. no idea
                  • E Offline
                    edd189 @sdetweil
                    Ok, plan B – read the ICS files, save them locally, append the time to the DTSTART and DTEND fields.
                    Create a script to do this automatically every 24 hours.
                    Wish me luck! I’m in over my head, but its kinda fun.
                    Any advice? I am running this on linux, so figured I can just run a cronjob every 24 hours. What’s the best service to language to use to write such a simple script?
                      sdetweil @edd189
                      @edd189 people write in python, I do most of mine in bash shell.
                        MMRIZE
                        Sorry for late reply. I was outside in holidays. I’ll study what your issue is tomorrow.
                        • E Offline
                          edd189 @sdetweil
                          I went with an sh script. I run this every morning at 3am. Does the trick by fixing the calendar file (appends a made up time to the end where its missing) and saving locally. I had to point CX2 to a local file instead of the webcal link, but that is no problem.
                          The worst part was that the two calendars had slightly different formatting. The US Holidays had some sort of hidden return character at the end of the string, and it took me forever to figure out how awk should deal with that.
                          #!/bin/sh
                          #download files
                          curl “https://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics” --output us_holidays_raw.ics
                          curl “https://api.team-manager.gc.com/ics-calendar-documents/user/6e0678b2-2e99-44ce-9e3a-e32ac9ff6e78.ics?teamId=secret_id_string&token=secret_id_string” --output baseball_raw.ics
                          #clean files
                          awk ‘{if(($1 ~ /DTSTART/) && length($1)==16) {print $0"T050000Z"} else {print $0}}’ dirtdawgs_raw.ics > baseball_awk1.ics
                          awk ‘{if(($1 ~ /DTEND/) && length($1)==14) {print $0"T195959Z"} else {print $0}}’ dirtdawgs_awk1.ics > baseball_awk2.ics
                          awk ‘{if(($1 ~ /DTSTART/) && length($1)==17) {print substr($0,1,16)“T050000Z”} else {print $0}}’ us_holidays_raw.ics > us_holidays_awk1.ics
                          awk ‘{if(($1 ~ /DTEND/) && length($1)==15) {print substr($0,1,14)“T195959Z”} else {print $0}}’ us_holidays_awk1.ics > us_holidays_awk2.ics
                          #copy and delete temp files
                          /bin/cp us_holidays_awk2.ics us_holidays.ics
                          /bin/cp baseball_awk2.ics baseball.ics
                          /bin/cp us_holidays.ics /home/edd/MagicMirror/config/us_holidays.ics
                          /bin/cp dirtdawgs.ics /home/edd/MagicMirror/config/baseball.ics
                          rm us_holidays_awk1.ics
                          rm us_holidays_awk2.ics
                          rm baseball_awk1.ics
                          rm baseball_awk2.ics
                          exit
                            sdetweil @edd189
                            @edd189 nice work!
                              MMRIZE
                              Sorry for my late reply.
                              First, I’m apologize for neglecting management. I was so tired to maintain it.
                              Second,
                              DTSTART:20220101
                              is not a valid format by specification(RFC 5545). The default value of DTSTART MUST be date-time format({DATE + “T” + TIME) and, when DATE format is used, it SHOULD be described.
                              The valid format of this case would be;
                              DTSTART;VALUE=DATE:20220101
                              However, many ical providers don’t follow standard rules, and many ical parsers generally are parsing some non-standard formats. Unfortunately in this case, the parser that this module depends on, doesn’t accept this kind of non-standards.
                              The parser (kewisch/ical.js) was formerly maintained by Mozilla, so I thought this parser would be promising and better than node-ical of default MM’s caledar lays on. Well, somehow it would be better. Still ical.js is more popular, more times downloaded than node-ical.
                              But there is no perfect thing. I was tired to report/fix all the bugs which are not derived from me, so that’s why I gave up and delegated ical parsing to the other(default calendar/MMM-GoogleCalendar, …) in CX3.
                              Anyway, what I suggest is, how about using different ics for US holidays? Especially if only this calendar would be a problem.
                              • E Offline
                                edd189 @MMRIZE
                                @MMRIZE
                                Thanks for looking into it. Over the weekend I did determine that its was the ical.js node module that you referenced being the source of the error. I tried to understand the code and edit it myself, but gave up and just applied a bandaid to the problematic calendars (see my post above with the sh script).
                                I actually have multiple calendars that are problematic, so I needed the fix to be universal. I think my script works pretty well for a novice who hasn’t done much programming since college 20+ years ago!
                                I tried to use your CX3 module, but for some reason it won’t display on my Chromecast. It pops up fine on a web browser on my computer. My setup is a linux VM running the magic mirror software and then using Cast All The Things (CATT) to push the MM through a Chromecast to my display in the kitchen. I don’t think there is anything to dig into here, because I imagine the Chromecast is not a common method for this software. I may eventually migrate to a local RPI anyways, because the Chromecast seems to be limited to a 720p resolution.
                                  sdetweil @edd189
                                  @edd189 the problem on chromecast w EXT3 is the javascript es6 chaining operator
                                  https://forum.magicmirror.builders/topic/17677/mirror-showing-not-all-modules-on-all-devices/11?_=1686341739088
