    MM-MQTT module connect into Magic Mirro
    4 Posts 3 Posters 1.4k Views 3 Watching
    • V Offline
      vpanse
      I have installed Magic mirror and then added MM-MQTT module.
      Now I want to send message from outside client , let say from python client.
      and Magic Mirror should show me values I send , some how it’s not working.
      Any idea?
      S bheplerB 2 Replies Last reply Reply Quote 0
        sdetweil @vpanse
        @vpanse did u adjust the mm address and. ipWhitelist to allow outside the mirror access? by default it is set to.only apps INSIDE the same machine can connect
        set address :“0.0.0.0”
        and to test, ipWhitelist to []
        this allows any app on any system on your network to connect
        • bheplerB Offline
          bhepler Module Developer @vpanse
          @vpanse - The MMM-MQTT module is an MQTT client. You need to configure it to connect to a MQTT broker (aka, server) and subscribe to one or more topics. Then you should have your outside client broadcast to the broker.
          It’s easy enough to install a MQTT broker on your mirror. I personally use Mosquitto. Like so:
          sudo apt update
          sudo apt install mosquitto -y
          That will install mosquitto as a service on your mirror. Then you can point your MMM-MQTT module at the local host on the listener port. Follow the documentation on MMM-MQTT to get you connected to Mosquitto.
          • V Offline
            vpanse @bhepler
            @bhepler , @sdetweil
            Thanks , Looks like it’s working now , I’m able to send message from other PC on same
            wifi and it show on Magic Miror
