    [INFO] Be careful to use iCal sample of config.js
    Scheduled Pinned Locked Moved Forum
    26 Posts 5 Posters 18.2k Views 6 Watching
    • BKeyportB
      BKeyport Module Developer @MMRIZE
      @MMRIZE It could also be with as many MM systems out there a simple timing issue. every 5 minutes, bam 3000 systems flood CL with requests. Maybe start changing default to once a week on holiday calendar at most.
      ankonaskiff17A 1 Reply Last reply Reply Quote 0
      • ankonaskiff17A
        ankonaskiff17 @BKeyport
        @BKeyport @MMRIZE I think the problem is that calendar.js default fetch interval is set to 5 minutes.
        When you set about to build a MM and you install the core system, Calendar.js fetchinterval is set to 5 minutes by default.
        If I install MM AND I’m content with the presentation of the calendar AS IS and do nothing at all, calendar.js is going to reach for an update every 5 minutes.
        BKeyportB S 2 Replies Last reply Reply Quote 0
        • BKeyportB
          BKeyport Module Developer @ankonaskiff17
          @ankonaskiff17 … ahh, good point, forgot the fetch interval is not per item. Hey, @sdetweil - it’s your baby, you want to add a fetchInterval override variable per calendar, and default in the sample config.js to once a week or more for the holidays calendar? This would solve the issue CL is having with at least new installs…
          As for the old ones, could we check to see if CL 's holiday calendar is being used, and inform or force an override for fetchInterval to solve for most?
          (Just did a check and I’m not using CL’s holiday calendar, so whew)
            sdetweil @ankonaskiff17
            @ankonaskiff17 we are changing the default to days I think. this for es u to make it faster if u want
            I think the minimum should be 5 minutes
            • ankonaskiff17A
              ankonaskiff17 @sdetweil
              @sdetweil Back when I first started messing with MM’s the calendar module was faulting out towards the end of that calendar year and it turned out that however many I had set as how many to show, say for example 5 holidays but at some point there were not 5 holidays left in the year but CL had not yet published the next years calandar.
              My config.js is wanting 5 holes it needed to fill, there weren’t 5 holidays left so down it would go.
              That calendar, because it is US Holidays, behaves like a photograph. It is static. There is no need to have it looking for changes like a volatile personal calendar that is going to change continuously.
              US Holidays you could have a fetchInterval: ONCE EVERY 3 MONTHS and it would still be overkill. Some of your religious holidays like Easter float around because they aren’t date oriented. But even it has been calculated in advance
              It doesn’t require the same level of refreshing as where someone is pulling in their personal Google or Outlook calendar where things like doctors appointments, dinner dates will change quite rapidly…
                @ankonaskiff17 this issue with refresh rate per calendar is because you can do
                			header: "US Holidays",
                                                 updateInterval:  7*24*60*60*1000  // 7days
                				coloredSymbol:true,
                					symbol: 'calendar',
                					//symbolClassName: "fas fa-fw fa-",
                					color: 'pink',
                						url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics",
                						url: "some otherr url ",
                						url: "some otherr url  again",
                and ALL those calendars get the SAME/ONLY refresh rate
                so currently u would have to do
                				coloredSymbol:true,
                					symbol: 'calendar',
                					color: 'pink',
                                                 updateInterval: 6*60*60*1000  // 6 hours
                				coloredSymbol:true,
                						url: "some other url ",
                                                 updateInterval:  1*60*60*1000  // 1 hour
                				coloredSymbol:true,
                						url: "some other url again"
                now you have three separate lists, not merged
                • ankonaskiff17A
                  @sdetweil I had used a second calendar module to pull in my personal calendar information and was using the ical link that you can get off of Google if I remember correctly.
                  Sort of along the lines of using multiple weather modules for daily and hourly.
                  Then Google did something that broke the module. I fought with it for a while, gave up and have never tried to get it back running again.
                    @ankonaskiff17 google changed their url content a while back, so u had to go get it again
                    ankonaskiff17A 2 Replies Last reply Reply Quote 0
                    • ankonaskiff17A
                      @sdetweil My issue was a bit more complicated.
                      My PRIMARY calendar is my phone but it is Samsungs built in calendar not Google calendar
                      I was hopping in and out Samsung, Google and Outlook although I don’t remember the sequence of hops.
                      I was dumbfounded that it even worked at the time.
                      One of those things where only so many minutes in the day so it was relegated to back burner status.
                      • ankonaskiff17A
                        @sdetweil That was a good memory jogger because I had completely forgotten about the broken calendar issue.
                        I suspect I will go with a second calendar module like before
                          @ankonaskiff17 we are adding interval by url too
                                     fetchInterval:
                                      url:
                          • ankonaskiff17A
                            @sdetweil Any functional difference between updateInterval and fetchInterval
                            • ankonaskiff17A
                              @sdetweil I asked question because I learned way back that programs are VERY unforgiving when you put a period, colon, semicolon, anything out of place. you have no idea how often things like colons or semi-colons have whipped me for hours.
                                @ankonaskiff17 computers do things very fast. EXACTLY as you tell them…
                                figuring out WHAT you told them is always a challenge!
                                the devil is in the details…
                                • ankonaskiff17A
                                  @sdetweil I’m going to take a crack at loading a personal calendar but have a question that maybe you can answer. really relates to the Google side of things.
                                  Google has public and or share with certain people that I equate to a private view.
                                  In a home network environment is there a tangible benefit of one over the other. Both are hopefully behind a firewall, you are using good password security.
                                  Everyone in IT security always going to default to private being safer and I do not disagree but curious if there is a real difference since you are hopefully doing the proper security within your home network
                                    @ankonaskiff17 I use the secret url … not sure how that is useful… if one can see inside the file system they can read the config.js and then the url works for them too…
                                    but its something…
                                    ankonaskiff17A M 2 Replies Last reply Reply Quote 0
                                    • ankonaskiff17A
                                      @sdetweil Kind of my thinking too.
                                        MMRIZE @sdetweil
                                        The secret URL of Google Calendar could be reset and invalidated.
